POV-Ray : Newsgroups : povray.newusers : Declaration type Server Time
10 Apr 2026 12:33:05 EDT (-0400)
  Declaration type (Message 1 to 4 of 4)
Subject: Declaration type
Date: 16 Nov 2002 00:23:56
Message: <1flqk0y.1vw6141xu6fckN%kaveh@delete_this.focalimage.com>
I find that I can use the following code:
#declare a = 1;
#sphere {a,a pigment{color rgb a}}
Furthermore, the following code:
#declare a = 1;
#sphere {a.x,a pigment{color rgb a}}
gives the same result, i.e. a.x gives the x component, which is 1, which
is then re-interpreted as the vector <1,1,1>
Obviously not good style, but is "a" held internally both as a float and
as a vector? I appreciate any insight into this.
Kaveh
Subject: Re: Declaration type
Date: 16 Nov 2002 01:14:02
Message: <3dd5e22a$1@news.povray.org>
"Kaveh" <kav### [at] delete_thisfocalimagecom> wrote in message
news:1flqk0y.1vw6141xu6fckN%kaveh@delete_this.focalimage.com...
> #declare a = 1;
I believe it is interpreted at the place where it is used, as in the
position of a sphere being a vector if given only a float and same for
color. I don't think a declared float is stored as a vector since it would
be an error if used for other things that require a nonvector.
Date: 16 Nov 2002 23:36:55
Message: <pan.2002.11.17.04.35.51.438570.214@gte.net>
On Sat, 16 Nov 2002 00:23:50 -0500, Kaveh quoth:
> #declare a = 1;
This creates a variable named "a" that stores the value "1" as a
double-precision floating-point number.
This uses "a" as a color, so it gets promoted to the 5 component vector
<1,1,1,0,0> temporarily.  It's still stored as a float.
> #declare a = 1;
a.x is a vector expression, so "a" gets promoted to the 3 component
vector <1,1,1>.  It's still a float.  See section 6.1.4.4 "Operator
promotion" of the manual for more information.
Mark
Date: 17 Nov 2002 04:47:28
Message: <1flst3j.1wg16mg1qgkbuoN%kaveh@delete_this.focalimage.com>
Thank you Mark. It's the 'temporary promotion' that explains it. I will
look at the manual.
Kaveh
