POV-Ray : Newsgroups : povray.general : odd behavior of photon reflection/refraction defaults Server Time
11 Mar 2026 03:22:53 EDT (-0400)
  odd behavior of photon reflection/refraction defaults (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: odd behavior of photon reflection/refraction defaults
Date: 11 Dec 2025 13:35:00
Message: <web.693b0e24874e57e8e83955656e066e29@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> > > [Kenneth wrote:]
> > > Would these be more appropriate for the docs' default?:
> > > target 1.0     When 'spacing' is used in the global photons block
> > > target on     When 'count' is used in the global photons block
> why 'on' ??
> (do you actually want to add further "ambiguities" to the parsing ?)
> > > Kenneth wrote:]
> why 'on' ??
Sorry to say that I did not do much testing of 'target' behavior until now-- and
it is also a bit confusing to me.
Given that the docs say that the default for an object is 'target 1.0'-- which
should mean ON as I understand it (when *either* 'count' or 'spacing' is used in
the global photons block, both of which I tested) -- here are my current
parse/render results in both 3.7 and 3.8 beta 1. I used my test code posted
earlier.
photons{} -- an empty photon block-- the default for 'target' is actually OFF,
not ON.
With NO photons block in an object, the default is likewise OFF, not ON.
photons{target} -- neither 1.0 nor ON explicitly stated-- the object *is* a
photon target, as expected from the explicit use of the keyword
photons{target 1.0} or photons{target on} -- likewise ON as expected.
So it seems that the target default is OFF for an object-- unless I am
completely mistaken as the what 'default of target 1.0' means in the docs (other
than as an explicit 'spacing divisor').
Date: 11 Dec 2025 15:10:01
Message: <web.693b2471874e57e8475fba6a6cde94f1@news.povray.org>
hi,
> > > > Kenneth wrote:]
> > why 'on' ??
> should mean ON as I understand it (when *either* 'count' or 'spacing' is used ...
"The keyword target makes this object a target."  note, keyword alone.
<wiki.povray.org/content/Reference:Photons#Photon_Global_Settings>
as I wrote, the syntax diagram says 'target [float]', a value of '1.0' simply
ensures (I think) that "nothing changes" by default wrt photon spacing.
there isn't a photons "default" either w/out corresponding block, iiuc.  unsure
how 'collect' plays with 'target', but, again aiui, 'refraction' and
'reflection' do not require the object to be a target.
also, fwiw, the documentation calls it a "spacing multiplier", rather than
"divisor".  luckily, with '1.0', no difference :-).
regards, jr.
Date: 11 Dec 2025 17:40:00
Message: <web.693b4820874e57e8e83955656e066e29@news.povray.org>
You're right about that. Although-- at the risk of sounding pedantic-- the
'default' block in the docs does not actually state it in an immediately useful
way. Instead, the only given default for target is 'target 1.0'.  In my ideal
world, I wish it was clearer:
target: OFF when no explicit target keyword is specified
target spacing: 1.0
Yes, that's my understanding as well, and tests confirm it.
Actually, an explicit 'target' *is* required (if my tests are any indication.)
In my test code earlier, in the photon blocks, use 'refraction on' in both the
light_source and the translucent box. Then comment-out 'target' in the
translucent box. The result: no refraction effects.
Ah, yes, you're correct. I was thinking in terms of 'number' of photons rather
than spacing:
target 0.5-- the spacing between photons is reduced by half...whereas the number
of photons is...either doubled or quadrupled(?)-- like spacing/2
(or spacing/4 ?)
Sorry for the confusion.
Date: 11 Dec 2025 18:35:00
Message: <web.693b5520874e57e81f9dae3025979125@news.povray.org>
I had a window of time today, and set The AI to work on this.
I have diagrams and charts and flowcharts and code.
Still need to go through it all and test it out.
I can post or forward the zips if you'd like.
- BE
Date: 12 Dec 2025 05:50:00
Message: <web.693bf28f874e57e8e83955656e066e29@news.povray.org>
> than spacing:
> (or spacing/4 ?)
"...like spacing/2 or spacing/4" ???
Please ignore that bad analogy and arithmetic-- a result of 'over-thinking' :-[
Date: 12 Dec 2025 06:45:00
Message: <web.693bff1f874e57e8475fba6a6cde94f1@news.povray.org>
hi,
> > than spacing:
> > (or spacing/4 ?)
no worries (hope that sort of thing doesn't keep you awake at night </grin>).
agree re the 'target', its description, will do that in the coming days.  how do
you fancy "having a go" at turning the "Perfect Mirror" thread in to a "FAQ"
item ?  (or a draft for an added "Tip" based on your observations ?)
regards, jr.
Message: <web.693bffc6874e57e8475fba6a6cde94f1@news.povray.org>
hi,
keep "us" in the loop please, wrt testing etc.
regards, jr.
Date: 12 Dec 2025 08:45:00
Message: <web.693c1b98874e57e89839f6ab25979125@news.povray.org>
I have a lot of running around to do, so I'll only be able to sporadically play
with the output.
I'll post a zip of all the files that were generated, and maybe we can all
run/edit/debug the code, etc. and come up with something that makes sense.
One thing that I did was have it generate ALL the possible permutations of light
source and object, and I would suggest that part of the distribution be a scene
that renders all the permutations.  That ought to put an end to any questions
about how povray actually operates.
- BE
Download 'photons.zip' (1058 KB)
Date: 13 Dec 2025 03:20:00
Message: <web.693d20d5874e57e8475fba6a6cde94f1@news.povray.org>
hi,
yes agree, a simple, "good" .pov/.ini combo which generates a corresponding set
of images would be very useful to have.  (if we had one "in hand", we could
start "badgering" Chris :-))
regards, jr.
Date: 18 Dec 2025 15:00:00
Message: <web.69445bb5874e57e8e83955656e066e29@news.povray.org>
> How do you fancy "having a go" at turning the "Perfect Mirror" thread into
> a "FAQ" item ?  (or a draft for an added "Tip" based on your observations ?)
12/18/25
Sorry for the delay in responding...real-life and holiday chores took over.
Perhaps a combination of FAQ and B.E.'s all-inclusive test-scene idea would be
the best approach to a better understanding of the current photons behavior; I
will try to put together a draft FAQ (or addition to 'photon tips and tricks')
after the New Year...once I get a clear scenario in my head of how best to
approach it.
Meanwhile, I continued testing in v3.8 beta 1-- and came across some
*really* odd behavior of photons interacting with objects (which proved to be
TEMPORARY, I am happy to say.)
Essentially, the parse time for my earlier test scene here wildly increased-- by
about 15X-- when I simply added an additional box object to the scene, on the
left side of my  light_source, and with no photons block in that object (thus
as a photon 'collector', the default behavior.) But such a gigantic parse-time
increase  made no sense whatsoever, and  I spent the better part of *three days*
trying to understand why it was occurring and how to eliminate it, running test
after test. (Adding a photon block with 'collect OFF' solved it..but that should
not have made such a big difference.)
Near the end of this testing process, I decided to shut down v3.8 and run the
scene in v3.7 instead, to compare results: NO odd behavior there, which was a
good sign. So I brought it back to 3.8... and the problem had suddenly
DISAPPEARED! I could not even reproduce it by fiddling with photon settings.
(At some point prior to my v3.7 test, I *might* have shut down my computer--
which I do on occasion, when I know I will be away from it for hours..but I
don't remember if or when.)  So did shutting it down 'fix' something in the
Windows registry? And/or did running 3.7 correct some temporary glitch in the
3.8 code? Or did Microsoft sneak-in a 'silent' Windows update while I wasn't
looking, breaking (OR fixing) something?
Or was it just 'gremlins and goblins' playing with me?? I think that's the
likely answer.  :-o
So my new and painfully-learned philosophy concerning the current 3.8 betas (1,
and most likely 2 as well) is this:
When unexpected  and unexplainable scene behavior suddenly occurs that makes no
sense, first RESTART the computer (or just POV-ray?) and test again!
Now that all is well, I continue testing photons...   :-)
