POV-Ray : Newsgroups : povray.general : odd behavior of photon reflection/refraction defaults Server Time
16 Apr 2026 09:42:40 EDT (-0400)
  odd behavior of photon reflection/refraction defaults (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: odd behavior of photon reflection/refraction defaults
Date: 12 Dec 2025 05:50:00
Message: <web.693bf28f874e57e8e83955656e066e29@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> I was thinking in terms of 'number' of photons rather
> than spacing:
> target 0.5-- the spacing between photons is reduced by half...whereas the number
> of photons is...either doubled or quadrupled(?)-- like spacing/2
> (or spacing/4 ?)
"...like spacing/2 or spacing/4" ???
Please ignore that bad analogy and arithmetic-- a result of 'over-thinking' :-[
Date: 12 Dec 2025 06:45:00
Message: <web.693bff1f874e57e8475fba6a6cde94f1@news.povray.org>
hi,
> > than spacing:
> > (or spacing/4 ?)
no worries (hope that sort of thing doesn't keep you awake at night </grin>).
agree re the 'target', its description, will do that in the coming days.  how do
you fancy "having a go" at turning the "Perfect Mirror" thread in to a "FAQ"
item ?  (or a draft for an added "Tip" based on your observations ?)
regards, jr.
Message: <web.693bffc6874e57e8475fba6a6cde94f1@news.povray.org>
hi,
> I had a window of time today, and set The AI to work on this.
> I have diagrams and charts and flowcharts and code.
> Still need to go through it all and test it out.
> I can post or forward the zips if you'd like.
keep "us" in the loop please, wrt testing etc.
regards, jr.
Date: 12 Dec 2025 08:45:00
Message: <web.693c1b98874e57e89839f6ab25979125@news.povray.org>
I have a lot of running around to do, so I'll only be able to sporadically play
with the output.
I'll post a zip of all the files that were generated, and maybe we can all
run/edit/debug the code, etc. and come up with something that makes sense.
One thing that I did was have it generate ALL the possible permutations of light
source and object, and I would suggest that part of the distribution be a scene
that renders all the permutations.  That ought to put an end to any questions
about how povray actually operates.
- BE
Download 'photons.zip' (1058 KB)
Date: 13 Dec 2025 03:20:00
Message: <web.693d20d5874e57e8475fba6a6cde94f1@news.povray.org>
hi,
yes agree, a simple, "good" .pov/.ini combo which generates a corresponding set
of images would be very useful to have.  (if we had one "in hand", we could
start "badgering" Chris :-))
regards, jr.
Date: 18 Dec 2025 15:00:00
Message: <web.69445bb5874e57e8e83955656e066e29@news.povray.org>
> How do you fancy "having a go" at turning the "Perfect Mirror" thread into
> a "FAQ" item ?  (or a draft for an added "Tip" based on your observations ?)
12/18/25
Sorry for the delay in responding...real-life and holiday chores took over.
Perhaps a combination of FAQ and B.E.'s all-inclusive test-scene idea would be
the best approach to a better understanding of the current photons behavior; I
will try to put together a draft FAQ (or addition to 'photon tips and tricks')
after the New Year...once I get a clear scenario in my head of how best to
approach it.
Meanwhile, I continued testing in v3.8 beta 1-- and came across some
*really* odd behavior of photons interacting with objects (which proved to be
TEMPORARY, I am happy to say.)
Essentially, the parse time for my earlier test scene here wildly increased-- by
about 15X-- when I simply added an additional box object to the scene, on the
left side of my  light_source, and with no photons block in that object (thus
as a photon 'collector', the default behavior.) But such a gigantic parse-time
increase  made no sense whatsoever, and  I spent the better part of *three days*
trying to understand why it was occurring and how to eliminate it, running test
after test. (Adding a photon block with 'collect OFF' solved it..but that should
not have made such a big difference.)
Near the end of this testing process, I decided to shut down v3.8 and run the
scene in v3.7 instead, to compare results: NO odd behavior there, which was a
good sign. So I brought it back to 3.8... and the problem had suddenly
DISAPPEARED! I could not even reproduce it by fiddling with photon settings.
(At some point prior to my v3.7 test, I *might* have shut down my computer--
which I do on occasion, when I know I will be away from it for hours..but I
don't remember if or when.)  So did shutting it down 'fix' something in the
Windows registry? And/or did running 3.7 correct some temporary glitch in the
3.8 code? Or did Microsoft sneak-in a 'silent' Windows update while I wasn't
looking, breaking (OR fixing) something?
Or was it just 'gremlins and goblins' playing with me?? I think that's the
likely answer.  :-o
So my new and painfully-learned philosophy concerning the current 3.8 betas (1,
and most likely 2 as well) is this:
When unexpected  and unexplainable scene behavior suddenly occurs that makes no
sense, first RESTART the computer (or just POV-ray?) and test again!
Now that all is well, I continue testing photons...   :-)
Date: 19 Dec 2025 17:05:00
Message: <web.6945cb26874e57e852af7e976cde94f1@news.povray.org>
hi,
> approach it.
thank you very much.  on "second thought" :-), or perhaps as a wiki "How To"
item ?  (more "elbow room")
> likely answer.  :-o
agree, they (machines) can have "a mind of their own", it seems at times.
regards, jr.
Date: 2 Jan 2026 20:45:00
Message: <web.695872e3874e57e8e83955656e066e29@news.povray.org>
Alain Martel <kua### [at] videotronca> wrote:
> > BTW:
> > I think that the docs'  'target' default of 1.0 [the numerical multiplier]
> > also needs a small clarification (...) The 1.0 value also works when
> > 'count' is used [instead of 'spacing'] but incrementally changing the float
> > value has no effect.
> The value after target has an effect on the density of the photons for
> the target object.
> Even when using count, target 0.5 should cause that object to receive 4
> times as many photons compared to target 1/on/true. When using count,
> this only has an effect when there are at least two target objects.
My original tests used only one 'target' object, so I tested again using two,
and you're right: A changed multiplier value does work now (for both targets),
even when 'count' is used in the global photons block. This little 'switch' in
behavior is undocumented, as far as I can tell.
However: Given two (or more) 'target' objects in a scene, the photon behavior
for each can be unexpectedly different, depending on whether 'count' vs.
'spacing' is used:
A) With 'count':
     If two targets both use a value of 1.0 (or simply 'on'), the 'count' of
     photons is *split up evenly* between the two; each target gets half the
     count. But if one target uses 1.0 and the other 0.2, the 0.2 target *robs*
     photons from the 1.0 target, with the resulting visual caustic effect on
     surfaces looking different from each one. But the total photon
    'count' remains the same.
B) With 'spacing':
     Each target is *independent*-- they each respond to their individual
     spacing-multiplier values, no 'robbing' of photons...which means the total
     NUMBER of photons can increase, to suit the situation. This would
     produce a more logical and visually realistic result than 'count'.
Some of these behavioral differences are undocumented as well, or at least not
clearly.
Date: 3 Jan 2026 11:15:11
Message: <6959408f$1@news.povray.org>
> 'spacing' is used:
> A) With 'count':
>       photons is*split up evenly* between the two; each target gets half the
>       count. But if one target uses 1.0 and the other 0.2, the 0.2 target*robs*
> B) With 'spacing':
>       Each target is*independent*-- they each respond to their individual
Re: (A) Interesting & news to me. I thought the count applied
independently to each target. Thanks for digging into the behavior!
Bill P.
Date: 3 Jan 2026 13:41:11
Message: <695962c7$1@news.povray.org>
>> using two,
>> targets),
>> 'switch' in
>> behavior
>> 'spacing' is used:
>> A) With 'count':
>> 'count' of
>> half the
>> target*robs*
>> effect on
>> B) With 'spacing':
>> the total
> Bill P.
When you use count, the count value is the total number of photons to be
shot, distributed between all targets and all lights. The area, or
angular size, of the targets also play a role. A big target will tend to
get more photons than a small target next to it.
The photon shooting always try to keep the photon density constant
between all targets.
count 1 000 000
two lights and two targets of roughly the same size, and each light will
shoot about 250 000 photons at each target.
Have three targets, and you shoot about 166 666 photons per light at
each target.
