POV-Ray : Newsgroups : povray.general : Media: rendering needs verry long for the last few percent Server Time
17 May 2024 06:54:19 EDT (-0400)
  Media: rendering needs verry long for the last few percent (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Media: rendering needs verry long for the last few percent
Date: 5 May 2022 13:45:47
Message: <62740d4b$1@news.povray.org>
Le 2022-05-04 à 14:40, Kenneth a écrit :
> I have noticed some kind of similar media-rendering behavior, especially with
> scattering media (but also with emission + absorption.)
> I'm running V3.8.0 beta 1  (Windows), on a core I7 8-core/16-thread machine.
> I currently use the default 'render block size' of 32X32 pixels and no 'mosaic
> preview'. The last few 'render blocks' that get processed in my images (which
> are in areas where there is media) seem to cause my machine to work *extremely*
> hard. I have noticed this in two different ways: My machine's cooling-fan speed
> greatly increases; and the Windows 'Task Manager' app shows that those last few
> blocks cause the processor to suddenly jump to nearly 100% use.
> On my machine, there does not seem to be an actual slowdown in the render-- just
> some very hard processor work behind-the-scenes.
> This is my *guess* as to what is going on (simply from a user's standpoint, and
> not a programmer's):
> Due to symmetric multi-processing, it would seem that each 'render block' in the
> image is being processed by a particular core/thread(?)-- or, the blocks for
> most of the render are being shared among those. But for the very last block--
> or last few blocks-- the SMP process is reducing the number of threads(?) to
> process those... in other words, maybe the last block is using only one core,
> and trying to make it do *all* of the processing... resulting in a slowdown (or
> overheating of the processor, in my case.)
> Again, this is purely guesswork. I don't know the inner workings of processors
> or POV-ray's SMP stuff ;-)
Each render block is rendered by a single core. So, your supposition is
correct.
In cases similar to this one, reducing the render blocks MAY improve the
performance by forcing those problematic blocks to get rendered by more
than a single core.
So, try using +rb16 or +rb12 and see if there is any improvement.
Also, changing the rendering pattern so that the rendering start near
the centre could help to at least hide some of the slowdown by having
the problem blocks starting to get rendered sooner.
Date: 5 May 2022 17:10:00
Message: <web.62743c28dbd7fa052eadabda6e066e29@news.povray.org>
Thorsten <tho### [at] trfde> wrote:
> If you want a better distribution of the computational load, you should
> decrease the render block size such that your object gets distributed
> between multiple render blocks.
> Thorsten
That works very well, thanks! From my own 'naive' analysis, I had been wondering
if a smaller block size would help, but I never tried it. (For my tests, I
forgot to mention that my media object occupies about 50% of the screen space--
unlike the OP's small object that is probably 'enclosed' by a single render
block.) Your suggestion works in both cases, of course.
A smaller render-block size has another great advantage: The scene renders
faster.
Here is my example (using scattering media):
block size of 64 pixels: 2 mins 16 sec
block size of 8 pixels:  1 min 10 sec
That's a definite improvement! And my machine's processor seems to run less hot,
based on the cooling-fan speed.
Date: 5 May 2022 17:35:00
Message: <web.627442a0dbd7fa052eadabda6e066e29@news.povray.org>
Thanks Alain.
The 'extra' benefit that never occurred to me was the faster rendering time when
using a smaller block size. I thought the result might be the
opposite...probably based on my old and fuzzy memories of running media on
single-core machines, before POV-ray's SMP implementation.
Date: 6 May 2022 02:00:56
Message: <6274b998$1@news.povray.org>
Op 05/05/2022 om 23:05 schreef Kenneth:
>> Thorsten
> faster.
Ha! Never thought about that 'trick'!
Date: 6 May 2022 02:55:41
Message: <6274c66d$1@news.povray.org>
Op 05/05/2022 om 19:45 schreef Alain Martel:
Just nitpicking: +rb should be +bs
Date: 6 May 2022 08:11:52
Message: <62751088$1@news.povray.org>
Op 5-5-2022 om 09:35 schreef Thorsten:
Is this also true when doing a stochastic render? Generally, I use:
+am3 +a0.03 +ac0.90 +r3
Is adding +bs12 (for instance) relevant in that case?
Thanks
Date: 6 May 2022 09:25:41
Message: <627521d5$1@news.povray.org>
Sorry :(
Date: 6 May 2022 09:28:25
Message: <62752279$1@news.povray.org>
>>> Thorsten
>> wondering
>> tests, I
>> screen space--
>> render
>> renders
>> faster.
>> less hot,
It's highly scene dependent.
On some scenes that already render fast, it can cause the renter time to
increase.
Then, there are cases where it don't have a significant effect.
Date: 6 May 2022 09:31:17
Message: <62752325$1@news.povray.org>
>> should decrease the render block size such that your object gets
>> distributed between multiple render blocks.
> Thanks
Yes. It is relevant in most scene where the time needed to render a
block varies greatly.
If all blocks take about the same amount of time to render, it will have
little to no effect.
Date: 7 May 2022 02:11:51
Message: <62760da7$1@news.povray.org>
Op 06/05/2022 om 15:31 schreef Alain Martel:
>> Thanks
Thanks! Good to know. I shall jot this down along with my other notes.
