POV-Ray : Newsgroups : povray.general : Example of .obj import please Server Time
24 Feb 2026 11:53:01 EST (-0500)
  Example of .obj import please (Message 1 to 10 of 11)
Subject: Example of .obj import please
Date: 30 Sep 2021 17:05:00
Message: <web.61562502751880cedd31149be3dfee7c@news.povray.org>
Howdy folks,
Would some kind soul please post a short, simple code example for importing an
...obj file into 3.7.1? I'm consistently getting this error: Parse Error: No
triangles in triangle mesh. I don't understand why as the .obj file is properly
formed and is imported without problems by a number of 3D modeling programs. I'm
using the "boilerplate" code example from the wiki with the parameters changed
for my testing:
#declare MyTexture = texture { ... }
#declare MyMaterial = material { ... }
mesh {
  obj "MyMesh.obj"
  texture_list {
    "Foo" texture { MyTexture }
    "Bar" material { MyMaterial }
    prefix "Tx"
    suffix "_"
  inside_vector y
Thanks in advance.
Subject: Re: Example of .obj import please
Date: 30 Sep 2021 17:29:38
Message: <61562c42$1@news.povray.org>
Are you aware that 3.7.1 has been retracted?  Approved versions are
3.7.0.* and 3.8.0-beta.2.
Date: 30 Sep 2021 17:40:00
Message: <web.61562e42cc8d58d2dd31149be3dfee7c@news.povray.org>
I wasn't. My bad though. I've been experimenting with 3.8.0-b2 but it's giving
me some .ini file parsing problems so I actually have 3.7.0 installed.
Date: 30 Sep 2021 17:45:00
Message: <web.61562f02cc8d58d2dd31149be3dfee7c@news.povray.org>
"Version 3.7.1 extended the mesh object by adding a New feature that supports
importing Wavefront (OBJ) files."
So it appears I'll need to use 3.8.0-b2 as .obj import isn't in 3.7.0 ...
Date: 30 Sep 2021 18:00:00
Message: <web.6156331acc8d58d2dd31149be3dfee7c@news.povray.org>
3.8.0-b2 gives the same error.
Date: 30 Sep 2021 18:15:00
Message: <web.61563627cc8d58d21f9dae3025979125@news.povray.org>
IIRC, Cousin Ricky and I both resort to using spreadsheets to convert STL files
to proper POV-Ray mesh {} syntax.
Roland Smith also has a python script on GitHub:
https://github.com/rsmith-nl/stltools
But probably the easiest and most used way to do it is to use PoseRay.
https://sites.google.com/site/poseray/
Date: 30 Sep 2021 18:50:00
Message: <web.61563dcbcc8d58d2dd31149be3dfee7c@news.povray.org>
Thanks guys. Poseray is not an option as I'm on Linux and would prefer not to
load WINE to run it. I've been eyeballing the .stl format which is the native
output 3d format for the program I'm using (Mandelbulber) so I may end up coding
a stl2mesh2 converter in C with the Qt toolkit eventually.
MeshLab runs under Linux and converts .stl very nicely to .obj and I was hoping
it worked in 3.8.0-b2 but apparently no dice ...
Thanks for the heads up on the the Roland Smith script. I'll may give it a go. I
know Python so if I hit a snag I can probably fix it or port it to pyQt for
a nice GUI interface.
Cheers.
Date: 30 Sep 2021 20:00:00
Message: <web.61564edbcc8d58d2dd31149be3dfee7c@news.povray.org>
One note, the Roland Smith script does work fairly well so there's a solution
for the time being. The files are fairly large and parsing the .inc file that
the script produces takes some time.
I may have to resort to Blender as it has no issues with importing the original
..stl file and has provision to use Povray for it's renderer.
Ah, light at the end of the tunnel perhaps. Listen, is that a train ... ?
Cheers.
Date: 1 Oct 2021 11:13:08
Message: <61572584$1@news.povray.org>
> Howdy folks,
> for my testing:
.OBJ often don't contain triangles but polys. Most are composed of a
collection of quadrangles.
That mean that they need to be loaded as unions of bicubic patches.
Date: 1 Oct 2021 16:25:00
Message: <web.61576dc0cc8d58d2dd31149be3dfee7c@news.povray.org>
Alain Martel <kua### [at] videotronca> wrote:
> > Howdy folks,
> > for my testing:
Generally I tessellate the mesh beforehand and insure its well formed. No
surprises that way ... Cheers.
