POV-Ray : Newsgroups : povray.general : About camera reference frame Server Time
17 Nov 2025 15:07:00 EST (-0500)
  About camera reference frame (Message 1 to 4 of 4)
Subject: About camera reference frame
Date: 13 Feb 2020 08:40:00
Message: <web.5e45510429aa81a5376b2b10@news.povray.org>
Hello !!
Today I was thinkering about camera reference frames and I had a little bit of
confusion.
Which three vectors define the frame of reference of the camera? I took as
granted that the z direction  was the one exiting from the camera, so the result
of the difference between the vectors "look_at" and "location". But in this way
the "right" and "up" directions (both defined or as default) are not
perpendicular to the z direction. So what is it? Are the right and up directions
(and the cross product of them) the reference frame of the camera (so the z
direction is not perpendicular to the image plane) or is it otherwise and the
right and up direction are not defining the camera reference frame?
Thanks in advance !!!!
Subject: Re: About camera reference frame
Date: 13 Feb 2020 09:35:00
Message: <web.5e455e25f196bd6c451952ca0@news.povray.org>
hi,
> confusion.
> Which three vectors define the frame of reference of the camera? ...
<http://wiki.povray.org/content/Reference:Camera#Placing_the_Camera>
regards, jr.
Date: 13 Feb 2020 19:00:39
Message: <5e45e327$1@news.povray.org>
Le 2020-02-13 à 08:37, Francescodario Cuzzocrea a écrit :
> Hello !!
> confusion.
In the default camera, up is +y and right is along the x axis, making
them all perpendicular.
The frame of reference is the rectangle of size right by up situated at
distance direction from the camera's location, unless you use the angle
parameter. In that case, the size of the frame is adjusted as needed to
ensure that right is correct relative to angle.
Date: 13 Feb 2020 21:05:01
Message: <web.5e45ffd8f196bd6c4eec112d0@news.povray.org>
> Hello !!
> confusion.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5d881ea3763463c54eec112d0%40news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5880b8311652a4dcc437ac910%40news.povray.org%3E/
The camera defaults are pretty straightforward, it's only once you start moving
things around that it can get tricky.
I would also take a look at the screen.inc file - as that has a lot of
definitions and transformations in it that can be instructive.
and links in this thread:
http://news.povray.org/povray.general/thread/%3Cweb.5b9ed475f76fb4baa47873e10%40news.povray.org%3E/?mtop=424446
and maybe you may find _something_ of use here:
http://news.povray.org/povray.binaries.images/thread/%3C5baddad1%40news.povray.org%3E/?mtop=424795
