POV-Ray : Newsgroups : povray.general : Trying to Apply Focal Blur on an Orthographic Projection Server Time
28 Sep 2024 18:33:44 EDT (-0400)
  Trying to Apply Focal Blur on an Orthographic Projection (Message 1 to 6 of 6)
Subject: Trying to Apply Focal Blur on an Orthographic Projection
Date: 12 Nov 2019 19:55:01
Message: <web.5dcb53c163abcc5387560a5b0@news.povray.org>
The language allows me to define focal blur on an orthographic projection but
the results i'm getting are meaningless images of the scene blurred out of
existence (I used lots of aperture values and they where all this way). I know
focal blur doesn't make physical sense for orthographic projection. I would
define focal blur here as each ray is parallel except for a bit of a random
angle. I'm trying to simulate rays from the sun. (Like a blurred out image from
the perspective of the sun.) Has anyone gotten focal blur to produce something
good in orthographic, otherwise could I define my own camera to do this?
Subject: Re: Trying to Apply Focal Blur on an Orthographic Projection
Date: 12 Nov 2019 20:25:09
Message: <5dcb5b75$1@news.povray.org>
Never experimented with that, but...
Make the aperture small. Start with 1/10 of the smallest value that you
tried or smaller.
Do set look_at.
Make the focal point the same as the look_at.
Things on the plane defined by the focal point perpendicular to the
camera's location to the focal point vector SHOULD be in focus.
Date: 12 Nov 2019 21:25:01
Message: <web.5dcb6921c35fe2b54eec112d0@news.povray.org>
> existence
I suppose there might be a way to make a user-defined camera, but maybe you
might think of physically creating a thin sheet of transparent material with an
IOR > 1 to act as a blurring "lens".
Possibly as an isosurface made with a noise function.
Date: 12 Nov 2019 22:40:00
Message: <web.5dcb7adac35fe2b54eec112d0@news.povray.org>
Try this for starters:
// Bill Walker "Bald Eagle" November 2019
// for user Drawliphant
// in thread
http://news.povray.org/povray.general/thread/%3Cweb.5dcb6921c35fe2b54eec112d0%40news.povray.org%3E/
#version 3.8;
global_settings {assumed_gamma 1.0 }
#include "functions.inc"
#include "math.inc"
#declare Zoom = 50;
 orthographic
 right     x*image_width/Zoom
 up   y*image_height/Zoom
 location <0, 0, -10>
 look_at  <0, 0, 0>
sky_sphere {pigment {rgb 1}}
light_source {<2, 5, -10> rgb 1 shadowless}
//light_source {<-10, 8, -1> rgb 0.8} // fill light
#declare Tan = texture {pigment {rgb <0.92, 0.60, 0.20>} finish {specular 0.2}}
#declare Tan2 = texture {pigment {rgb <0.92, 0.60, 0.20>} finish {diffuse 0.7
specular 0.2 reflection 0.02}}
#declare Gray = texture {pigment {rgb 0.5}}
#declare Gray2 = texture {pigment {rgb 0.5}finish {diffuse 0.7 specular 0.2
reflection 0.02}}
#declare Shade = 1;
#declare   _Red = texture {pigment {rgb <1, 0, 0>*Shade} finish {diffuse 0.7}}
#declare _Green = texture {pigment {rgb <0, 1, 0>*Shade} finish {diffuse 0.7}}
#declare  _Blue = texture {pigment {rgb <0, 0, 1>*Shade} finish {diffuse 0.7}}
#declare Checker = texture {pigment {checker rgb 0 rgb 1} scale 2 finish
{diffuse 1}}
//##########POV-RAY###############Bald
Eagle##############2019###################
#declare Square = union {
 triangle {<-5, 0, -5>, <-5, 0, 5>, <5, 0, -5>}
 triangle {<5, 0, -5>, <-5, 0, 5>, <5, 0, 5> }
 texture {Checker}
#declare Axes =
 union {
  #declare Line = 0.1;
  #declare Base = Line*3;
  #declare Length = 3.5;
  #declare Ext = 0.5;
  cylinder {<0, 0, 0>, <Length, 0, 0>, Line texture {_Red}}
   cone {<Length, 0, 0>, Base, <Length+Ext, 0, 0>, 0 texture {_Red}}
   text {ttf "timrom.ttf", "Blur       No Blur", 0.02, 0.0 texture {_Red}
    translate <-2, -1.125, 0>
  cylinder {<0, 0, 0>, <0, Length, 0>, Line texture {_Green}}
   cone {<0, Length, 0>, Base, <0, Length+Ext, 0>, 0 texture {_Green}}
  cylinder {<0, 0, 0>, <0, 0, Length>, Line texture {_Blue}}
   cone {<0, 0, Length>, Base, <0, 0, Length+Ext>, 0 texture {_Blue}}
  //no_shadow
object {Square rotate -x*90 translate z*6}
object {Axes}
#declare T_Glass=texture{
   pigment{
     color rgbt 1
   finish {
     diffuse 0.04
     //reflection{ 0.5 fresnel on }
     //conserve_energy
#declare I_Glass=interior{
   ior 1.005   // <--- change the IOR
   fade_power 2 //1.5
   fade_distance 1
   fade_color <0.70, 0.7, 0.9>
   //dispersion 1.01
   //dispersion_samples 100
#declare Thickness = 0.01;
#declare BlurPlane = function {z + f_noise3d(x, y, z)}
  #declare Range = 1;
  #declare Whole = yes;
  #declare Label = no;
  #declare Gradient = 50;
  #declare Min_factor= 0.6;
// for scaling the noise function
#declare XS = 0.001;
#declare YS = 0.001;
#declare ZS = 0.01;
  isosurface {
    function {abs (BlurPlane (x/XS, y/YS, z/ZS)) - Thickness}
    //open
    threshold 0.5
    //max_gradient 10
    accuracy     0.01
    evaluate Gradient*Min_factor,  sqrt(Gradient/(Gradient*Min_factor)),  min
(0.7, 1.0)
    contained_by {box {<-3, -2, -1>*Range, <Whole*3, 2.3, 1>*Range}}
    hollow
      texture {T_Glass}
      interior {I_Glass}
      //texture {Tex1}
     scale 1
     rotate x*1 // Seems absolutely essential!  :O
     translate <-1.5, -0.5, -7>
Date: 13 Nov 2019 09:55:07
Message: <web.5dcc1822c35fe2b53cd9f1c00@news.povray.org>
> #declare ZS = 0.01;
>   isosurface {
>     //open
>     threshold 0.5
>     //max_gradient 10
>     accuracy     0.01
> (0.7, 1.0)
>     hollow
>       texture {T_Glass}
>       interior {I_Glass}
>       //texture {Tex1}
>      scale 1
This is great! If I can't get focal blur working how I want it I can blur it
with this. I'm pretty new so when people where talking about a blur plane I had
no idea how to make that. I'll try veeery small aperatures first then try this
one
Date: 13 Nov 2019 13:40:01
Message: <web.5dcc4d9fc35fe2b54eec112d0@news.povray.org>
> This is great!
Glad you like  :)
No worries.  Always just ask and someone can chime in at some point with an
explanation, a link, or some code.
> I'll try veeery small aperatures first then try this one
I don't really use focal blur - but when I took real photographs and developed
and printed real film and paper, the smaller the aperture, the more things were
in focus.   A greater depth of field.
So I'd tend to suggest the opposite - use a huge aperture, and look_at something
other than what you want to be out of focus.
Dan Byers just posted a great little animation - maybe poke him and ask him what
his secret is.   :)
http://news.povray.org/povray.binaries.images/message/%3Cweb.5dcb2ab9d5e268cc44b457e10%40news.povray.org%3E/#%3Cweb.5dc
