POV-Ray : Newsgroups : povray.general : Roots of a function Server Time
30 Apr 2024 20:38:38 EDT (-0400)
  Roots of a function (Message 11 to 15 of 15)
Subject: Re: Roots of a function
Date: 1 Oct 2019 08:04:04
Message: <5d9340b4@news.povray.org>
On 9/30/19 7:04 PM, Alain Martel wrote:
> Le 2019-09-29 à 08:48, William F Pokorny a écrit :
>> A declare without the leading # works too but we get:
>> File 'tmp.pov' line 40: Parse Warning: Should have '#' before 'declare'.
>> File 'tmp.pov' line 40: Possible Parse Error: 'declare' should be
>> changed to
>>   '#declare'. Future versions may not support 'declare' and may require
>>   '#declare'.
> Using declare instead of #declare can result in an error at parse time.
If you have an example which results in an actual error at parse time,
I'd like to get it.
I have a collection of parser test cases and I spent time yesterday
capturing/creating parser test cases for these '#' variants. I didn't
come up with anything that generated an actual parse error - or render
problem - only the warnings above.
I did come up with a case with isolated #s ahead of a bare 'declare'
which did NOT generate the warnings above (I found a parser bug) though
the render result was still fine.
>> Given this warning, I'd think we should be getting one on #object {}
>> and the like too as the other side of the syntax change push - now
>> that I understand there is another side.
> #object should generate a warning.
> Same for #Primitive_Name
Unsure if you were agreeing we should be getting such warnings, or
saying POV-Ray does generate such a warning. If the latter, I never saw
that while trying different things. If warnings for #Primitive_Name do
sometimes happen, I'd like an example test case for my collection.
Also had the thought last night, Does say '#accuracy 0.001' work..? It
does.
Aside: I've converted to vim/gvim for my editor. Still working to get
back up to speed, but, vim itself ships with syntax highlighting and
indenting for POV-Ray v3.7(1) and, interestingly, it specifically
supports the '#<zero or as many spaces as you want>local' type syntax
for the language control elements (and #default{} and not default{} if
wondering - matching our current documentation).
Bill P.
(1) - There are some issues with it as others have noted. I might have
go at my own v3.8 version adding error indications for bad # use along
with v3.8 plus experimental feature support.
Date: 1 Oct 2019 13:50:01
Message: <web.5d9390cbb127c26ffeeb22ff0@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> Aside: I've converted to vim/gvim for my editor. ...
in case you don't already know: ":he tcl"  ;-)
regards, jr.
Date: 2 Oct 2019 05:40:00
Message: <web.5d946f7db127c26f2d4647f30@news.povray.org>
Alain Martel <kua### [at] videotronca> wrote:
> Why that «#» in front of «object» and that other one in front of
> «cylinder» ?
> The «#» is needed in front of directives, never in front of a primitive.
My bad habit... I use # in front of primitives since I started playing with
povray, for uniformity. Now I know it's strongly discouraged.
Date: 3 Oct 2019 08:44:19
Message: <5d95ed23$1@news.povray.org>
On 10/1/19 1:45 PM, jr wrote:
> hi,
> regards, jr.
Yes! Not yet done anything with the capability, but certainly one of the
reasons I went to vim/gvim over other options. Relatively strong
coupling/behavioral similarities to the bash shell another.
Aside: I bought the book you recommended and found it useful. Thanks. In
fact I should probably read through it again.
More than two months and the old muscle habits are still tripping me up
all the time! The deeper I am in thought about something else, the less
conscious I am about the editor, the more I trip. It really bugs me
because it rips apart my concentration. The screen changes and I have no
idea what I did! "Oh, yeah..." I found too my touch typing skills had
drifted over the years due - whatever - I guess. Trying to reign in
those bad habits too.
Bill P.
Date: 4 Oct 2019 17:50:06
Message: <web.5d97bdb6b127c26ffeeb22ff0@news.povray.org>
hi,
> Yes!
I go through .. phases where the book is next to the keyboard for days on end.
the book's subtitle applies, it would seem.  :-)
regards, jr.
