POV-Ray : Newsgroups : povray.general : How does bezier_spline work in prism? Server Time
19 May 2024 11:18:26 EDT (-0400)
  How does bezier_spline work in prism? (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: How does bezier_spline work in prism?
Date: 8 Sep 2019 17:30:04
Message: <web.5d757230cb41806efeeb22ff0@news.povray.org>
hi,
> "Kima" <nomail@nomail> wrote:
> > I tried to make a simple circle by bezier_spline,
> IIRC, you can't do it with a single spline, but can append 2 semicircle
> approximations.
> See if this helps any, and see if LeForgeron's wiki page helps any.
prisms with bezier_spline are also used in the distribution include file
'lemon.inc', under 'scenes/advanced/grenadine/'.
regards, jr.
Date: 8 Sep 2019 18:35:01
Message: <web.5d7581f3cb41806eecc0fada0@news.povray.org>
> approximations.
https://news.povray.org/povray.general/thread/%3Cweb.5c47356c36095c6fbe7517870%40news.povray.org%3E/
> http://wiki.povray.org/content/User:Le_Forgeron
I still don't understand why povray draws berzier curves this way.
Mathematically, the bezier curves of these points create a circle. See this
https://ibb.co/YykPGPM
Date: 8 Sep 2019 21:15:00
Message: <web.5d75a679cb41806e4eec112d0@news.povray.org>
> image
POV-Ray ought to draw Bezier curves the way all Bezier curves are drawn.
I'm not sure what your image is supposed to show, as there's no mathematical
data that relate it to Bezier curves.
Maybe try:
https://stackoverflow.com/questions/1734745/how-to-create-circle-with-b%C3%A9zier-curves
I've probably spent the last several years working on understanding Bezier
splines and patches.
Lods of mistakes and frustration and misconceptions, but eventually got it all
worked out in the end.
Tor Olav Kristensen (TOK) mentored me after I got my second wind and felt up to
attacking the topic again.
Cousin Ricky has a Bezier spline based sphere sweep in the object collection.
Jerome Grimbert (LeForgeron) likely also has some good Bezier spline/patch work
in his excellent collection of experiments.
Date: 8 Sep 2019 21:56:07
Message: <5d75b137$1@news.povray.org>
>      prism {
>        bezier_spline
>       0,-.3,32,
> <0.154,0.605>,<0.128,0.605>,<0.128,0.605>,<0.1105,0.6225>
> <0.1105,0.6225>,<0.093,0.64>,<0.093,0.64>,<0.093,0.666>
> <0.093,0.666>,<0.093,0.691>,<0.093,0.691>,<0.1105,0.709>
> <0.1105,0.709>,<0.128,0.727>,<0.128,0.727>,<0.154,0.727>
> <0.154,0.727>,<0.18,0.727>,<0.18,0.727>,<0.1975,0.709>
> <0.1975,0.709>,<0.215,0.691>,<0.215,0.691>,<0.215,0.666>
> <0.215,0.666>,<0.215,0.64>,<0.215,0.64>,<0.1975,0.6225>
> <0.1975,0.6225>,<0.18,0.605>,<0.18,0.605>,<0.154,0.605>
>        pigment { color rgb<1,0,0>}
> but instead of a circle, it gave me an octagon as it seems the control points
> are connected instead of start and end points.
> What is wrong with my setting <start,control1,control2,end>?
> Note that I want to understand bezier_spline rather than finding an alternative
> for creating a specific shape.
Your control points in each segment are identical.
The usual way to do circles with Bezier curves is with 4 segments using
the method from: Michael Goldapp, "Approximation of circular arcs by
cubic polynomials" Computer Aided Geometric Design (#8 1991 pp.227-238).
I'm lazy and keep a point list created by this method for a circle at a
radius of 1.0 at the origin laying around - which I can scale, move etc.
So a circle within a circle to create a prism ring of sorts becomes:
#declare Cheese = srgb <1,0.65098,0>;
#declare Prism00 = prism {
     bezier_spline
     linear_sweep
     -0.2, 0.2, 32,
     <1,0>,<1,0.552285>,<0.552285,1>,<0,1>
     <0,1>,<-0.552285,1>,<-1,0.552285>,<-1,0>
     <-1,0>,<-1,-0.552285>,<-0.552285,-1>,<0,-1>
     <0,-1>,<0.552285,-1>,<1,-0.552285>,<1,0>
     <0.5,0>,<0.5,0.276143>,<0.276143,0.5>,<0,0.5>
     <0,0.5>,<-0.276143,0.5>,<-0.5,0.276143>,<-0.5,0>
     <-0.5,0>,<-0.5,-0.276143>,<-0.276143,-0.5>,<0,-0.5>
     <0,-0.5>,<0.276143,-0.5>,<0.5,-0.276143>,<0.5,0>
     pigment { color Cheese }
Bill P.
Date: 8 Sep 2019 23:05:00
Message: <web.5d75c126cb41806eecc0fada0@news.povray.org>
> >      prism {
> >        bezier_spline
> >       0,-.3,32,
>      bezier_spline
>      linear_sweep
>      -0.2, 0.2, 32,
> Bill P.
Thanks, Bill. I got it that the problem is my points, but your answer came
before I correct myself. Like your set, the controls should have identical x OR
y, but mine has both together, and that was the problem.
Date: 14 Sep 2019 11:27:37
Message: <5d7d06e9$1@news.povray.org>
A little reading there :
<https://stackoverflow.com/questions/1734745/how-to-create-circle-with-b%C3%A9zier-curves>
Kurtz le pirate
Compagnie de la Banquise
Date: 18 Sep 2019 12:50:01
Message: <web.5d825f0dcb41806e610414250@news.povray.org>
This may be a little late to help you much.
So here it goes. A long ago I fell in love with Prisms and Polygons, or I should
say it was the shapes they created. I think one of my first POV files was a
snowflake maker using Polygons, then prisms. There are an infinite number of
shape s you can come up with. To keep up with all those shapes I came up with,
and make new ones I wrote a windows program.
You can find it at  http://leroyw.byethost15.com/
 But you where asking about a circle(really a cylinder) using Prism and
bezier_spline. We should be able to let POV make one of any size for us.
You know the basics data
point1, control1, control2, point2
point2, control1, control2, point3
pointN, controlNa, control1a, point1
if the prism is center is <0,0> and the number of points is N
 all the points are just point1 rotated around the center evenly
 the control points are a little more complicated
 if you use the formula with K=N
  control1(K)=(Pnt(N)+Pnt(N+1))*.333 and control2(K)=(Pnt(N)+Pnt(N+1))*.6666
  you will a n sided polygonal shape
 but if you adjust the control points out using
  L=vlength(Pnt(0))
  control1(K)=vnormalize(control1(K))*L
  control2(K)=vnormalize(control1(K))*L
 you should get a nice circle
This is just an over view. The code will have to be different. Prism doesn't
like 3d vectors and vnormalize outputs a 3d vector
I may be wrong, I haven't tried it.
Have Fun!
Date: 18 Sep 2019 18:59:16
Message: <5d82b6c4$1@news.povray.org>
>    L=vlength(Pnt(0))
> Have Fun!
If all your points share the same Y coordinate, there is no problem.
Same if they share the same X or Z.
You can multiply every point by <1,0,1> to ensure that you are on the
X-Z plane.
Date: 19 Sep 2019 14:20:00
Message: <web.5d83c551cb41806e561dc72c0@news.povray.org>
I couldn't let this go. I had to write the code!
 so here it is right from my editor
// round prism
// Vers: 3.7
// Auth: Leroy Whetstone
// Email whe### [at] gmailcom
#version 3.7;
global_settings {assumed_gamma 1 max_trace_level 20}
camera{ location <0,15,0>
        look_at <0,0,0>
 light_source{<0,20,0> color White}
//-------------change-------------
#declare Pnts=4;// points >=3  3 is a little funky
#declare Rad=3; // radius
//----------end of change----------
#declare Pa=array[Pnts];//points array
#declare Ca=array[2][Pnts];// control points array
#declare Td=4*Pnts;//prism entries
#declare An=360/Pnts;// angle to place points
#declare An2=An/3;// angle of control points
#declare CL=Rad/cos(radians(An2));// length of control points from <0,0,0>
//points
#for(a,0,Pnts-1)
 #declare Pa[a]=vrotate(x*Rad,y*a*An);
//Base of control points
 #declare D=vnormalize(vrotate(Pa[0],y*An2))*CL;
 #declare Ca[0][0]=D;
 #declare D=vnormalize(vrotate(Pa[0],y*An2*2))*CL;
 #declare Ca[1][0]=D;
// rest of control points
#for(a,1,Pnts-1)
 #declare Ca[0][a]=vrotate(Ca[0][0],y*a*An);
 #declare Ca[1][a]=vrotate(Ca[1][0],y*a*An);
//Show
prism{bezier_spline
      -1,1,Td
     #for(a,0,Pnts-1)
      <Pa[a].x,Pa[a].z>
      <Ca[0][a].x,Ca[0][a].z>
      <Ca[1][a].x,Ca[1][a].z>
      #if(a+1>Pnts-1) <Pa[0].x,Pa[0].z>
      #else <Pa[a+1].x,Pa[a+1].z>
     pigment{rgb <1,0,0>}
//show points
#for(a,0,Pnts-1)
  sphere{<Pa[a].x,1,Pa[a].z>,.1 pigment{Blue}}
  sphere{<Ca[0][a].x,1,Ca[0][a].z>,.1 pigment{Green}}
  sphere{<Ca[1][a].x,1,Ca[1][a].z>,.1 pigment{Yellow}}
   cylinder{<Pa[a].x,1,Pa[a].z> <Ca[0][a].x,1,Ca[0][a].z>,.05 pigment{Pink}}
   cylinder{<Ca[0][a].x,1,Ca[0][a].z> <Ca[1][a].x,1,Ca[1][a].z>,.05
pigment{Pink}}
  #if(a<Pnts-1)
   cylinder{<Ca[1][a].x,1,Ca[1][a].z><Pa[a+1].x,1,Pa[a+1].z> ,.05 pigment{Pink}}
  cylinder{<Ca[1][Pnts-1].x,1,Ca[1][Pnts-1].z><Pa[0].x,1,Pa[0].z> ,.05
pigment{Pink}}
 After writing this I thought of another feature to add. That is SCALE !
 You could make ovals.
Have Fun!
Date: 19 Sep 2019 15:35:00
Message: <web.5d83d80ecb41806e4eec112d0@news.povray.org>
Hi Leroy - I didn't work out your calculations, but comparing the result after
adding:
torus {3, 0.005 texture {pigment {White} finish {diffuse 1}} translate y}
Shows it to have a bit of a VISIO "squircle" thing going on.
[ site:visguy.com squircles ]
Adding #declare CL = CL*0.985;
Makes it noticeably more circular.
If you want to tweak it:
http://spencermortensen.com/articles/bezier-circle/
> Have Fun!
