POV-Ray : Newsgroups : povray.general : OBB to AABB question Server Time
22 Dec 2025 07:12:12 EST (-0500)
  OBB to AABB question (Message 1 to 3 of 3)
Subject: OBB to AABB question
Date: 23 Feb 2019 08:40:00
Message: <web.5c714cdab0e359c4bcd610c90@news.povray.org>
hi,
as a part of a process I calculate two random-ish 3d points which are the base
and cap centres of a cylinder.  I now want to transform the cylinder such that
the base is at origin and the Y axis is the centre axis.  after adding some
points relative to the centre axis, I need to transform the cylinder back to its
original position.
as the cylinder is "oriented", I cannot fathom how/where to get "my angles" wrt
the POV-Ray "world" axes.  can someone please take me through a worked example,
or point out a good www resource?  tia.
regards, jr.
Subject: Re: OBB to AABB question
Date: 23 Feb 2019 12:37:44
Message: <5c7184e8$1@news.povray.org>
Le 19-02-23 à 08:38, jr a écrit :
> hi,
> original position.
> regards, jr.
If you want an end of the cylinder to get moved to the origin, a simple
translate by the inverse of it's coordinate will do the trick :
You must set Range1, Range2, Offset1 and Offset2 to your needs.
#include "transforms.inc"
#declare R=seed(34);
#declare End1= <rand(R), rand(R), rand(R)>*Range1+Offset1
#declare End2= <rand(R), rand(R), rand(R)>*Range2+Offset2
#declare MyCylinder = cylinder{End1, End2, Radius}
//Move End1 to the origin :
#declare CylinderAtOrigin = object{MyCylinder translate -End1}
*//Reorient it to the Y axis :
#declare WorkCylinder = object{CylinderAtOrigin
transform{Reorient_Trans(End2, y)}}
Do whatever else you want here...
//Restore the original orientation :
#declare CylinderAtOrigin = object{WorkCylinder
transform{Reorient_Trans(y, End2)}}
//Bring back to the original location :
#declare MyCylinder = object{CylinderAtOrigin translate End1}
It can be shortened by combining the translations and rotations :
#declare WorkCylinder = object{MyCylinder translate -End1
// Restore original orientation and location :
#declare MyCylinder = object{WorkCylinder transform{Reorient_Trans(y,
End2)} translate End1}
Date: 23 Feb 2019 14:30:00
Message: <web.5c719e0821c80ddbbcd610c90@news.povray.org>
hi,
a perfect-for-my-needs reply, thank you.
(looking at 'transforms.inc' had not even occurred to me.  </sigh>)
regards, jr.
