POV-Ray : Newsgroups : povray.general : Parse Error: No matching } in 'union', object identifier found instead Server Time
17 Nov 2025 21:10:45 EST (-0500)
  Parse Error: No matching } in 'union', object identifier found instead (Message 1 to 5 of 5)
Subject: Parse Error: No matching } in 'union', object identifier found instead
Date: 20 Jan 2019 19:05:00
Message: <web.5c450a7271c191d5c059c35f0@news.povray.org>
I'm getting this error when trying to create a union of predefined objects.
#declare Foo = sphere { <0, 0, 0>, 0.1 };
#declare Bar = sphere { <1, 0, 0>, 0.1 };
union
    Foo
    Bar // Parse Error: No matching } in 'union', object identifier found
instead
This seems like it should be fine. It parses successfully if I put each
identifier inside object { }. Why isn't this allowed?
Subject: Re: Parse Error: No matching } in 'union', object identifier found instead
Date: 21 Jan 2019 03:52:04
Message: <5c458834$1@news.povray.org>
Am 21.01.2019 um 01:00 schrieb kendfrey:
> union
>      Foo
> instead
It's just how POV-Ray's language rolls: Pretty much wherever you use a
non-trivial variable (i.e. not a number, vector, colour or string), you
need to wrap that variable into a statement telling POV-Ray what to
expect in that variable.
For example, consider the following code:
     union {
         Foo
         Bar
         Fnord
If such code were allowed, you would have to take a closer look at the
variable `Fnord` to tell whether it is supposed to be another object, or
rather e.g. a texture, transformation or what-have-you.
As for why it was designed this way, I can only speculate; it might have
been intended to make scenes easier to read for humans (back in the days
when good variable names were short and cryptic), or easier to read for
the parser.
At any rate, this syntax quirk has survived the ages, and nobody has
ever bothered enough to actively do anything about it.
Date: 21 Jan 2019 07:10:01
Message: <web.5c45b60379c392cec059c35f0@news.povray.org>
>      union {
>          Foo
>          Bar
>          Fnord
> the parser.
Oh well, it's nice to know I wasn't just doing something dumb. Thanks!
Date: 21 Jan 2019 08:10:00
Message: <web.5c45c46879c392cecd98345b0@news.povray.org>
A simpler form of this quirk actually does work:
Foo // no object wrapper needed
But I don't know if this trick works if there is any intervening code between
the #declare and Foo. Give it a try ;-)
Date: 21 Jan 2019 10:59:50
Message: <5c45ec76$1@news.povray.org>
Am 21.01.2019 um 14:08 schrieb Kenneth:
Don't get used to it.
This works at the scene level, but not inside unions or the like.
Instead, when you use
     #declare Foo = sphere { ... }
     union { Foo }
this only works because it happens to be interpreted as
     object { Foo }
Also, this only works with a limited number of object keywords, and only
as an unintended side effect. The originally intended syntax seems to
have been:
     sphere { Foo }
     #declare Bar = box { ... }
     box { Bar }
     #declare Fnord = union { ... }
     union { Fnord }
This may have been the oldest form of the syntax, and `object` may have
been introduced later as an afterthought, to serve as a common alias for
`sphere`, `box`, etc. in such contexts.
This is just speculation though, and I'm not sure if even David K. Buck
remembers how this syntax feature evolved. In DKBTrace 2.01 (1990), it
had already taken pretty much the shape we see today.
