POV-Ray : Newsgroups : povray.general : parallel processing Server Time
22 Dec 2025 07:19:16 EST (-0500)
  parallel processing (Message 1 to 6 of 6)
Subject: parallel processing
Date: 13 Jan 2019 23:05:00
Message: <web.5c3c0949ffe3a207924dd5a0@news.povray.org>
What is the currently supported / generally accepted parallel implementation of
povray to render, for example, on a linux cluster? I'm looking for a visual
demonstration to persuade potential users to consider running their engineering
codes on a cluster versus individual node.
John McCulloch
Houston Texas
Subject: Re: parallel processing
Date: 14 Jan 2019 02:43:38
Message: <5c3c3daa$1@news.povray.org>
Am 14.01.2019 um 05:02 schrieb John McCulloch:
At the moment there is no official solution for distributed POV-Ray
rendering. Inofficial approaches usually use POV-Ray's command line or
INI file interface to have each node render only a subset of frames in
an animation, or only a rectangular portion of a still image.
Date: 14 Jan 2019 06:10:01
Message: <web.5c3c6d08b0db2a4948892b50@news.povray.org>
hi,
nothing supported/generally accepted, as clipka pointed out, but one of the
POV-Ray "regulars" runs a small render farm on his network, based I understand
on custom written software.  not the same as a cluster of course, but have a
browse for posts by "Dik Balaska"[*], they often have links to his
projects/site.
regards, jr.
[*] although regular, I haven't seen a post of his in the last few weeks, RL I
guess.
Date: 14 Jan 2019 11:41:26
Message: <5c3cbbb6$1@news.povray.org>
> guess.
I and my family have been sucked into Minecraft. I'm still reading here,
I just
haven't had much to say, and there's been no progress on my animation.
dik
Rendered 1024 of 921600 pixels (0%)
Date: 15 Jan 2019 12:00:08
Message: <web.5c3e1090b0db2a4997d76dec0@news.povray.org>
> Regards,
> John McCulloch
> Houston Texas
I appreciate the quick feedback!  Is there an option to display an image while
it is rendering?
I'm testing with this after running the samples:
https://github.com/christianbaun/task-distributor
John
Date: 15 Jan 2019 13:25:00
Message: <web.5c3e2520b0db2a4948892b50@news.povray.org>
hi,
> it is rendering?
with a "normal" installation that is the default.  does adding command-line
option '+D' help?
regards, jr.
