POV-Ray : Newsgroups : povray.general : Reflection of light due to difference in the index of refraction Server Time
17 Aug 2025 16:27:54 EDT (-0400)
  Reflection of light due to difference in the index of refraction (Message 1 to 8 of 8)
Subject: Reflection of light due to difference in the index of refraction
Date: 9 Jan 2019 03:05:00
Message: <web.5c35aac4892c9dda5e43241e0@news.povray.org>
Hello.
I've been trying to simulate a rather simple phenomenon in physics wherein some
light will be reflected and transmitted when passing through two media of
different indices of refraction, where the intensities of the
reflection/transmission depend on the how much the difference is. (pg. 405,
Introduction to Electrodynamics, Griffiths. Fourth Edition).
So, technically, if we have a glass box placed in air with an ior != 1 (say, ior
= 2) then, when we shine light on the box, we should get some reflection of
light.
I've been trying to recreate this phenomenon using the source code below, but I
could not get any sort of reflection. Could anyone please help me why it doesn't
work? Thank you so much in advance.
--- code ---
#include "Glass.inc"
#include "textures.inc"
global_settings {
 assumed_gamma 1.0
 photons
  { count 2000 }
camera {location <0,0,-9> look_at <0,0,1> }
light_source {
 <0,0,-10>
 color White
background { Black }
box {
 <-3,-3,0>, <3,3,3>
 pigment { Col_Glass_Clear } interior {ior 2}
 finish { reflection { fresnel on }}
 photons { target reflection on refraction on}
box {
 <-3,-3,3>, <3,3,6>
 pigment { Col_Glass_Clear } interior {ior 1}
Subject: Re: Reflection of light due to difference in the index of refraction
Date: 9 Jan 2019 04:59:59
Message: <5c35c61f$1@news.povray.org>
On 1/9/19 3:04 AM, hjkqed wrote:
> Hello.
> light.
> --- code ---
> global_settings {
>   assumed_gamma 1.0
>   photons
>    { count 2000 }
> light_source {
>   <0,0,-10>
>   color White
> box {
>   <-3,-3,0>, <3,3,3>
> box {
>   <-3,-3,3>, <3,3,6>
well i see at /least/ two issues ... no value for reflection and hollow
is missing from the boxes
http://wiki.povray.org/content/Reference:Finish#Specular_Reflection
http://wiki.povray.org/content/Reference:Hollow_Object_Modifier
Date: 9 Jan 2019 06:05:01
Message: <web.5c35d506ad35376448892b50@news.povray.org>
hi,
> different indices of refraction, ...
> I could not get any sort of reflection. Could anyone please help me why it doesn't
after adding the '#version' and lowercasing "Glass.inc" in your code, all I get
is black/nothing displayed.
regards, jr.
Date: 9 Jan 2019 07:30:00
Message: <web.5c35e825ad353764765e06870@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> regards, jr.
Because there's no light source?
Date: 9 Jan 2019 10:36:23
Message: <5c3614f7$1@news.povray.org>
Am 09.01.2019 um 09:04 schrieb hjkqed:
You need something to reflect.
This may sound trivial at first, but there's a catch: Light sources
don't show up directly in the image (unless you assign a `looks_like`
object), nor do they show up as reflections via the `reflection`
mechanism (or as refractions, for that matter).
The mechanism by which reflections of light sources are made visible is
via the specular highlights (`specular` and/or `phong`) mechanisms.
To better control the magnitude of specular highlights, I recommend
using the `albedo` keyword to get the same scale as the `reflection`
setting (otherwise the brightness is difficult to control and depends on
the tightness of the highlights, i.e. the `roughness` and/or
`phong_size` parameters). To make them conform to the Fresnel law you
need to specify `fresnel on` right in the `finish` block (as opposed to
the `reflection` block). (Requires POV-Ray v3.8.)
I recommend `specular` (being the more realistic model) with a very low
`roughness` setting.
Date: 9 Jan 2019 11:03:25
Message: <5c361b4d@news.povray.org>
Le 19-01-09 à 03:04, hjkqed a écrit :
> Hello.
> light.
> --- code ---
> global_settings {
>   assumed_gamma 1.0
>   photons
>    { count 2000 }
> light_source {
>   <0,0,-10>
>   color White
> box {
>   <-3,-3,0>, <3,3,3>
> box {
>   <-3,-3,3>, <3,3,6>
As Clipka said, plus, the camera can never directly see the photons.
When using photons, you need some surface for them to show on.
To «see» the light, the finish need to have highlights enabled using
specular or phong. Using a looks_like or associating some object with
the light_source using an union is also an option.
finish { reflection { fresnel on }} mean finish{reflection{ 0 fresnel}}
It need to be : finish { reflection{ 1  fresnel}}
The «on» is optional. Default to «off» when fresnel is absent, and to
«on» when present.
There is no need to use the hollow option. Here, it don't affect
anything. It's only use is to make an object able to contain some media.
Nothing else.
In the current sample, you don't need to include glass.inc and
texture.inc as you use nothing from those.
The box with an IOR of 1 can be removed as it's invisible and have no
effect at all. The whole environment have an IOR of 1 by default.
Date: 9 Jan 2019 13:50:01
Message: <web.5c36412ead35376448892b50@news.povray.org>
hi,
> > ... is black/nothing displayed.
it was a quick look just before RL activity, but reading subsequent posts,
likely, I'd have been stumped at that point anyway.  :-)
regards, jr.
Date: 9 Jan 2019 16:35:00
Message: <web.5c3668e8ad3537645e43241e0@news.povray.org>
> > Hello.
> > light.
> > --- code ---
> > global_settings {
> >   assumed_gamma 1.0
> >   photons
> >    { count 2000 }
> > light_source {
> >   <0,0,-10>
> >   color White
> > box {
> >   <-3,-3,0>, <3,3,3>
> > box {
> >   <-3,-3,3>, <3,3,6>
> «on» when present.
> Nothing else.
Thank you so much! I have fixed it as you've suggested and it works!
