POV-Ray : Newsgroups : povray.general : negative scale? Server Time
28 Sep 2024 22:14:06 EDT (-0400)
  negative scale? (Message 1 to 8 of 8)
Subject: negative scale?
Date: 23 Dec 2018 22:50:01
Message: <web.5c20573d380e028c291eeef00@news.povray.org>
when I use this
function{pigment{image_map scale<-1,-1,1>}}
I get artifacts around the edges.
Why is this? Any one else come across this and have a work around?
Have Fun!
Subject: Re: negative scale?
Date: 24 Dec 2018 02:45:09
Message: <5c208e85$1@news.povray.org>
On 24-12-2018 4:49, Leroy wrote:
> when I use this
> Have Fun!
Do you intend to use this function in a height_field? I do not know if
this is related, but I get artefacts around the edges of a image_map
function's height_field, independently of scale by the way. I solved it
by just intersecting away the height_field edges with a slightly smaller
box. Like this:
//start code
#declare F_hf =
function {
     image_map {
       tga "My_image.tga" gamma 1.0
       map_type 0
       interpolate 2
     //adding some warp
#local CuttingKnife = 0.994;	//find minimum value experimentally
#local HF_res = 2000;
#declare HF_base =
intersection {
   height_field {
     function HF_res, HF_res {F_hf(x,y,z).hf}
     smooth
     translate <-0.5, 0, -0.5>
   box {
     <-0.5, -0.5, -0.5>, <0.5, 0.5, 0.5>
     scale <CuttingKnife, 2, CuttingKnife>
   scale <1/CuttingKnife, 1, 1/CuttingKnife>
   scale SomeScale
   rotate SomeAngle*y
//end code
However, I do not know /why/ the artefacts happen, nor if this should be
expected or not.
Hope this helps.
Date: 24 Dec 2018 06:52:33
Message: <5c20c881$1@news.povray.org>
Am 24.12.2018 um 08:45 schrieb Thomas de Groot:
> #declare F_hf =
> function {
>    pigment {
>      image_map {
>        map_type 0
>        interpolate 2
>      //adding some warp
> expected or not.
Interpolation I presume. Unless you specify the "once" keyword, at the
edges the image is interpolated with the opposite edge.
Date: 25 Dec 2018 02:27:36
Message: <5c21dbe8$1@news.povray.org>
>> #declare F_hf =
>> function {
>>    pigment {
>>      image_map {
>>        map_type 0
>>        interpolate 2
>>      //adding some warp
>> be expected or not.
Ah! That is an interesting thought. Never thought of it but makes sense.
I shall investigate. I'll come back.
Thanks! and Merry Christmas!
Date: 25 Dec 2018 03:50:17
Message: <5c21ef49@news.povray.org>
>>> #declare F_hf =
>>> function {
>>>    pigment {
>>>      image_map {
>>>        map_type 0
>>>        interpolate 2
>>>      //adding some warp
>>> be expected or not.
Back again. The answer is yes and no. Yes, because interpolation
definitely creates artefacts from the opposite side of the image_map /
height_field; no, because adding the "once" keyword only makes the
artefacts in the x-axis direction disappear, but /not/ in the z-axis
direction.
To illustrate this, I add a test file with image_map. Run with "once"
(at line 65) commented out or not to see the difference.
Download 'hf_image_map_test.7z.zip' (3673 KB)
Date: 25 Dec 2018 03:53:57
Message: <5c21f025$1@news.povray.org>
And Merry Christmas from me. :-D
Regards
Date: 25 Dec 2018 16:25:00
Message: <web.5c229f9afbbfc375d335880@news.povray.org>
> > when I use this
> > Have Fun!
> box.
> Thomas
Merry Christmas :)
 I was using the function to make a color palette from any image.
I use that palette to convert the image into a 'pcx' file.
Then use the 'pcx' file to make a 'cin' video file.
Using POV  all the while.
 The function works fine if don't scale it negatively.
 Thanks for you input.
Have Christmas fun!
Date: 26 Dec 2018 16:23:36
Message: <5c23f158$1@news.povray.org>
>>> when I use this
>>> Have Fun!
>> box.
>> Thomas
> Merry Christmas :)
> Have Christmas fun!
In that case, you can «scale» the location instead of the image_map :
#declare Loc=Loc*<-1,-1,1>;
