POV-Ray : Newsgroups : povray.general : Colour from single trace Server Time
18 May 2024 22:34:51 EDT (-0400)
  Colour from single trace (Message 21 to 26 of 26)
Subject: Re: Colour from single trace
Date: 17 Nov 2018 05:31:10
Message: <5befedee$1@news.povray.org>
Am 16.11.2018 um 20:34 schrieb Alain:
> So, it should look somewhat like :
> #declare Location= trace( Object, Start, Dir, Normal, UV_Location );
Yes, that would be the trivial-to-implement solution.
> or
> #declare Location= trace( Object, Start, Dir, Normal, UV_colour );
In this case, it would be more like:
     #declare Location= trace( Object, Start, Dir, Normal, colour );
While I agree that this would be the most desirable solution, I'm not
sure whether it would be possible to implement in a fully consistent
manner. As someone hinted at earlier in this thread, objects don't have
pigments - they have textures, which may be arbitrarily complex. There
may be cases (either now or in the future) where there's no single
unambiguous colour associated with the ray-object intersection.
As an extreme example, take SSLT: In the first incarnation (somewhen
during the beta phase of POV-Ray v3.7.0) the colour of SSLT textures
wasn't controlled by a pigment, but was an emergent property of quite
different physics-based parameters.
While it may turn out to be possible to resolve this issue in a
well-defined manner, it certainly won't be trivial.
Date: 3 Dec 2018 09:50:00
Message: <web.5c05411d306629fe25503a850@news.povray.org>
> Am 17.11.2018 um 05:18 schrieb And:
> >> And it's a kind of 5 minutes patch, see at;
> >> https://github.com/LeForgeron/povray/tree/feature/traceUvMap
> > Sorry, how to use...
> > I mean github
> I guess the most important things to know (in this case):
> - What the link takes you to is GitHub's overview of a patched version
> of POV-Ray.
> - Clicking on the green "Clone or download" button and then "Download
> ZIP" (at the bottom of the pop-up) will download a ZIP package
> containing that version's complete source code.
> - The version does not come with binaries, so to use it on a Windows
> machine you would have to compile it yourself.
I think I will use this function in the future, but temporary not.
In fact I'm unable to compile it.
> > or
From my perspective UV_Location = trace_uv_map(Object, Start, Dir); is better,
after all not every objects have uv map.
#declare Location= trace( Object, Start, Dir, Normal, UV_Location ); does the
same function (for my needs)
At the beginning I want this function because I want to create some scene. E.g
fungus growing on a rock. And I want to produce the rock with a third party
software like blender, and paint a texture on it to design the density of
fungus. If I have the trace uv map function I can trace the rock to get the
color of texture, then use random() <? texture color to decide whether
is the fungus there to achieve my intention.
Date: 3 Dec 2018 10:00:01
Message: <web.5c0543d1306629fe25503a850@news.povray.org>
Inspired by these pictures
https://www.pinterest.com/pin/186617978287852820/
https://www.pinterest.com/pin/477663104213161095/
https://www.pinterest.com/pin/518265869605948864/
https://www.pinterest.com/pin/451837775112045194/
Date: 31 Dec 2018 06:44:23
Message: <5c2a0117$1@news.povray.org>
Le 15/11/2018 à 19:38, clipka a écrit :
> Am 15.11.2018 um 18:33 schrieb Le_Forgeron:
>> Now, let's fight about trace_uv_map or any better spelling or wording.
> Since you cannot compute an UV coordinate without computing an
> intersection, I would lean towards designing this as an extension to the
> existing `trace` function, via yet another optional parameter after the
> normal variable. That way we can avoid double work when the user wants
> both the intersection point's location and the UV coordinates.
> Also, if for some reason we need to implement it as a separate function,
> I would prefer `trace_uv`. We don't have the `map` appendix in any other
> UV mapping related stuff (e.g. it is `uv_vectors`, not
> `uv_map_vectors`), so adding it here would be inconsistent.
You can have the best of both world, now, at >
https://github.com/LeForgeron/povray/commit/cea994f8e69375f9de809bea5df241f1a269f702
(same branch as before):
* added uv-vector as optional parameter of trace(), after normal
* changed trace_uvmap to trace_uv, for the ones which only wants uv data
and do not care about intersection & normal.
Download 'traceuv.pov.txt' (1 KB)
Date: 2 Jan 2019 03:10:01
Message: <web.5c2c70e9306629feff23041c0@news.povray.org>
Date: 3 Jan 2019 06:15:00
Message: <web.5c2dee0c306629feff23041c0@news.povray.org>
Waiting a binary release
(Or should I understand how to compile a c++ program)
