POV-Ray : Newsgroups : povray.general : Holes in brick pattern Server Time
29 Sep 2024 00:18:35 EDT (-0400)
  Holes in brick pattern (Message 1 to 8 of 8)
Subject: Holes in brick pattern
Date: 20 Jun 2018 22:50:01
Message: <web.5b2b114e78756df8cd927dec0@news.povray.org>
For my RMS Titanic project I use the brick pattern for the deck planking.
However there are gaps in the mortar lines.
Here is a test scene that shows the problem:
#version 3.7;
global_settings
    assumed_gamma 1
#declare DeckTexture = texture
    pigment
        brick
        srgb <0, 0, 0>, srgb <1, 1, 1>
        brick_size <20, 1, 10>
        mortar 0.05
    rotate <90, 0, 0>
light_source
    <-150, 250, 0>
    color rgb <1, 1, 1>
camera
   location <-260, 38, 20>
   right x * image_width / image_height
   look_at <-240, 26, 10>
box
    <-250, 0, -50>, <0, 0, 50>
    texture
        DeckTexture
My povray version is
Persistence of Vision(tm) Ray Tracer Version 3.8.0-alpha.9606898.unofficial (g++
7.3.0 @ x86_64-pc-linux-gnu)
I have tried with maximum anit-aliasing (+a0.1 +r9), but I'm still having the
gaps. Is there any way I can fix this?
Thanks
Ton.
Subject: Re: Holes in brick pattern
Date: 21 Jun 2018 02:54:49
Message: <5b2b4bb9$1@news.povray.org>
[snip]
There are two ways:
1) increase the mortar size. Crude solution and you will still find
moire effects too.
2) Use stochastic anti-aliasing provided by UberPOV. This is, to my
knowledge, the best way although it may slow down your render ultimately.
To use this:
1) download UberPOV at: https://github.com/UberPOV/UberPOV/releases/
2) Change #version 3.7; to #version unofficial patch 3.71;
3) Stochastic ant-aliasing is provided by choosing one of the following
settings for your render (width and height to your convenience of course:
// +w800 +h600 +am3 +a0.1 +ac0.90 +r3
// +w800 +h600 +am3 +a0.01 +ac0.90 +r4
// +w800 +h600 +am3 +a0.01 +ac0.99 +r4
// +w800 +h600 +am3 +a0.01 +ac0.99 +r6
Explanation, in the words of Clipka:
[start citation]
As for the mode 3 oversampling, this mode is driven by a stochastic
algorithm, similar to focal blur;
the +a parameter specifies the /variance/, and the +ac parameter
specifies the /confidence/.
In layman's terms, the mode 3 is all about estimates: While it renders
pixels over and over again,
it estimates (A) the colour of the pixel, (B) the error in the estimated
colour,
i.e. how much it still differs from the actual value, and (C) the
reliability of the error estimate.
The +a parameter specifies the maximum estimated error you are willing
to accept, while the +ac parameter
specifies the minimum reliability you demand for that error estimate.
In even simpler terms, the +a parameter affects the amount of general
noise in the resulting image,
while the +ac parameter affects the amount of speckle artefacts.
(Last not least, the +r parameter puts a hard maximum on the number of
samples per pixel.
The effective limit is 4 to the power of the parameter value, making it
approximately the same as
for a worst-case scenario in anti-aliasing mode 2.)
[end citation]
Date: 21 Jun 2018 19:45:01
Message: <web.5b2c379ed92967a0524ae6190@news.povray.org>
Thanks Thomas.
D downloaded the uberpov sources and tried to compile it. but since version 1.65
the boost-libraries don't contain TR1 anymore. In the release notes they say
that it has been removed. Don't know why, but uberpov uses them, and the include
files are not there. Where can I file a bugreport for this? In bugreports, or
unofficial-patches?
I tried then the windows version. Wine is running almost everything, and uberpov
and the stochastic anti-aliasing did a good job. Are there any plans
incorporating this into POV-Ray?
Thanks
Ton.
Date: 23 Jun 2018 07:07:34
Message: <5b2e29f6@news.povray.org>
On 22-6-2018 1:41, Ton wrote:
> Thanks Thomas.
> unofficial-patches?
I cannot answer that. Those are questions for Clipka.
Date: 25 Jun 2018 10:30:00
Message: <web.5b30fc06d92967a0a47873e10@news.povray.org>
There's also the trick of running a very LARGE-sized render (with some good
anti-alias settings), and then *down-sampling* that image in another app as a
post-processing step, to make it smaller. This approach has been discussed from
time to time in the newsgroups, and I use it myself if I have a 'problem' image.
I tried your code example with a render size of 3840 X 2880 pixels, using AA
with an antialias_threshold of 0.05-- then downsized it in Photoshop to 1100 X
825 pixels (a purposely 'odd' size, so as not to be a strict 2:1 or 3:1
reduction.) This seems to eliminate any Moire patterns, as far as I can tell.
Some of the thin lines do disappear, though; I don't think there's a way around
that, because the lines are SO thin to begin with.
In Photoshop, I'm using the (default?) bi-cubic interpolation for the
down-sizing; but try bi-linear instead (if your image app has that), to see if
it produces better results.
Date: 25 Jun 2018 10:48:46
Message: <5b3100ce$1@news.povray.org>
Am 21.06.2018 um 08:54 schrieb Thomas de Groot:
BTW, an effect very similar to UberPOV's stochastic anti-aliasing can be
achieved by a very miniscule amount of focal blur with high-quality
settings.
Date: 26 Jun 2018 02:36:04
Message: <5b31ded4@news.povray.org>
> settings.
Indeed, yes. After taking my fish oil pill, the memory of that trick
just came back to me :-)
Date: 26 Jun 2018 06:40:01
Message: <web.5b321738d92967a072bd179f0@news.povray.org>
Thanks for all the tips. Uberpov with its stochastic anti-aliasing is doing a
good job. I think I'll stick with that.
