POV-Ray : Newsgroups : povray.general : motion blur by media Server Time
29 Sep 2024 00:19:55 EDT (-0400)
  motion blur by media (Message 1 to 3 of 3)
Subject: motion blur by media
Date: 28 May 2018 11:25:01
Message: <web.5b0c1e7a47d138933ce674f0@news.povray.org>
Following the suggestions made in
http://news.povray.org/povray.general/thread/%3Cweb.5b096a17747d6b9c3ce674f0%40news.povray.org%3E/
I tried to create a series of blur duplicates as the tail and came up with a
code of like
 sphere{ <0,0,0>,0.27 pigment{rgb <1,0,0>}}
 #declare Nr = 1;
 #while (Nr>0)
 sphere{ <0,0,0>,0.27 pigment{rgbf <1,1,1,Nr>}
        hollow
 interior{
  media{
   scattering{Nr,<1,1,1>}
   intervals 3
   samples 1,1
         translate <Nr,0,0>
 #declare Nr = Nr - 0.1;
It is getting close but far from a realistic motion blur. Any suggestion?
Subject: Re: motion blur by media
Date: 28 May 2018 12:40:01
Message: <web.5b0c2ff0d6fa6c8c10874a080@news.povray.org>
What you're doing is mixing a filter pigment with your media.
Make the spheres of the tail (the container for the media fully transparent.
Then to avoid the coincident surface problem, scale the spheres a little smaller
then the comet sphere.
 #declare Nr = 1;
 #while (Nr>0)
 sphere{ <0,0,0>,0.26 pigment{rgbt <1,1,1,1>}
        hollow
 interior{
  media{
   intervals 3
   samples 1,1
         translate <Nr,0,0>
Date: 28 May 2018 15:44:33
Message: <5b0c5c21$1@news.povray.org>
> code of like
>   #declare Nr = 1;
>   #while (Nr>0)
>          hollow
>   interior{
>    media{
>     //intervals 3
Never use ANYTHING but the default of 1 for intrvals !
>     samples 1,1
Increase this. You only get a single sample whitch is not enough.
The default is : samples 10.
Also, the second value is always silently discarted.
>           translate <Nr,0,0>
>   #end
For media, the defaults are :
method 3
intervals 1
samples 10
confidence is NOT used
variance is NOT used
Only the first value of samples is ever used if you provide two.
Using intervals >1 greatly impaire your rendering speed.
Using intervals with a value larger than 1 is only adviseable if using
method 1 or 2.
As your spheres overlap, you see the boundaries. It would be beter to
use a single larger, and fully transparent, sphere and modulate the
media density instead.
