POV-Ray : Newsgroups : povray.general : Photon scattering from global medium after object Server Time
17 Nov 2025 23:08:30 EST (-0500)
  Photon scattering from global medium after object (Message 1 to 3 of 3)
Subject: Photon scattering from global medium after object
Date: 29 Apr 2018 08:15:01
Message: <web.5ae5b6c02d1ee56fc3fb37760@news.povray.org>
I've been trying to produce a scene with a laser illuminating a solid sample
from above. The laser is focused with a lens onto the sample surface. The laser
itself is implemented as a cylindrical light source with refraction and
reflection on, and scattering turned on in global medium to enable me to see the
laser.
I can see the scattering of the laser up to the lens, but cannot see the laser
afterward - see https://i.imgur.com/bpgSD0t.png. However, I can see the focused
laser spot on the substrate surface, so the photons must be getting through,
they're just not visible. I can solve this by defining a cylinder between the
substrate and the lens which also scatters light, but I'd like not to have to.
If anyone has any suggestions on how to solve this, please let me know! The
scene file is as follows:
#version 3.7;
#include "glass.inc"
global_settings {
    ambient_light rgb<1, 1, 1>
    assumed_gamma 1.0
    photons {
        spacing 0.005
        autostop 1
        media 200
        max_trace_level 200
        radius 0.0025
background{rgbf<1, 1, 1,1>}
   location <-5,3.,-5>*1.3
   look_at <0, 0, 0>
// illuminate scene
light_source{
   <-5,3,-5>*1.4
   color rgb <1, 1, 1>*2
   adaptive 1
   jitter
   shadowless
// enable photon scattering in global medium
media {
    scattering {
        1,
        rgb <0.1, 0.1, 0.1>
        extinction 0.0000001
    samples 100,200
// laser
light_source {
    <0, 10, 0>
    color Green*4
    cylinder
    point_at <0, 0, 0>
    radius .1
    falloff .5
    tightness .5
    photons {
        reflection on
        refraction on
// material properties for solid
#declare F_substrate = finish {
    phong 0.01
    phong_size 1000
    specular 0.5
    diffuse .4
#declare N_substrate = normal {
    bumps 0
    turbulence 0
    scale 1
#declare I_substrate = interior {
    ior 2.42
    caustics 2
    dispersion 1.041
    dispersion_samples 50
#declare M_substrate = material {
        pigment {rgb<0,0.4,0.7> transmit 0.55}
        finish {F_substrate}
        normal {N_substrate}
    interior {I_substrate}
// bi-convex lens
#declare R = 3;
#declare Over= 0.2;
intersection {
    sphere {
        <0,0,0>,
        R
        translate <0,-R+Over,0>
    sphere {
        <0,0,0>,
        R
        translate <0,R-Over,0>
    cylinder {
        <0,-R,0>
        <0,R,0>
        0.5
        pigment { color rgbf <0.98, 1.0, 0.99, 0.75> }
        finish { F_Glass3 }
    interior { I_Glass3 }
    translate <0,3,0>
    photons {
        target
        reflection on
        refraction on
    rotate<0,200,0>
// substrate
box {
    <-2,-0.2,-4>, <2,0,4>
    material { M_substrate }
    photons {
        target
        reflection on
        refraction on
Subject: Re: Photon scattering from global medium after object
Date: 29 Apr 2018 17:21:56
Message: <5ae63774$1@news.povray.org>
> laser.
I'm short on time at seeing this post so unable to run your scene, but
the normal set up with photons is for the media to be inside a clear,
hollow container with an interior defining media. The container would
specify 'photons {target}' to get the photons shot into the media.
You've got global media and what you see is I believe the normal media
to light scatterings - not the forward photon interaction type.
There is an 'optics.pov' scene shipped with POV-Ray. It has a few minor
issues - mostly from trying to be fast I suspect - but it adequately
demonstrates a photons and media set up.
Bill P.
Date: 29 Apr 2018 18:50:01
Message: <web.5ae64bf955ee5e9ac3fb37760@news.povray.org>
> > laser.
> Bill P.
Hi Bill,
Thanks for your fast reply - adding a hollow box around the entire scene does
exactly as you suggest it would.
Thanks for the help!
J
