POV-Ray : Newsgroups : povray.general : #declare really is anxious about its semicolon Server Time
22 Dec 2025 16:31:55 EST (-0500)
  #declare really is anxious about its semicolon (Message 1 to 7 of 7)
Subject: #declare really is anxious about its semicolon
Date: 7 Oct 2017 05:10:01
Message: <web.59d898b6dd6c5614a6573c40@news.povray.org>
Greetings, all.  I do not know whether this is a misbehaviour, so I shall post
about it here rather than in the bugs group.
The following line fails to parse, with "All #declares of [etc] require
semi-colon ';' at end if the language version is set to 3.5 or higher".
  #local A = #if (1) 123 #end ;
If you shift the semicolon to before the #end, it's good.  Or, this:
  #local A = #if (1) 123+ #end 0 ;
The example here is trivial of course but in my case the "123" was actually a
vector coming out of the mother of all macros, so finding the root cause took
some head-scratching.
I can see why it happens:  POV is attempting to prevent the parser from diving
into the rabbit hole when the semicolon truly is missing.
(I just noticed that the error message could use a polish-up too, depending on
how fussy you are about English.)
Maybe it will help others who find themselves in the same jam.
Subject: Re: #declare really is anxious about its semicolon
Date: 7 Oct 2017 06:28:00
Message: <59d8ac30$1@news.povray.org>
hi,
parentheses help:
#local A = (#if (1) 123 #end) ;
regards, jr.
Date: 7 Oct 2017 21:35:00
Message: <web.59d98021d7b90bfb4a6573c40@news.povray.org>
jr <cre### [at] gmailcom> wrote:
> parentheses help:
Uh, I feel silly for not trying that.  Thanks JR.
Date: 11 Oct 2017 06:30:00
Message: <web.59ddf1c3d7b90bfb89df8d30@news.povray.org>
That would seem to make sense (at least to me) for the following reason: If the
#if is 'true', then 123 is the value-- and a regular #local or #declare has the
semicolon after that VALUE itself.  Still, your example is an interesting one--
I've never used an #if() block *as* an Rvalue. (Hmm, what happens to #local A if
the #if is 'false'?)
I'm curious: In this successful example (shifting the semicolon), did you try
leaving out the #end statement altogether? If so, did the #local still work OK,
or did all hell break loose? ;-)
Date: 11 Oct 2017 06:43:53
Message: <59ddf5e9$1@news.povray.org>
Am 11.10.2017 um 12:26 schrieb Kenneth:
Please don't try this at home; a containment lab would be recommended
for such experiments ;)
As a matter of fact, there are known situations where leaving out
closing stuff (`#end`, closing parentheses, closing braces) in an
include file may indeed cause POV-Ray to crash hard.
And no, I'm not doing anything about it, because for each of these cases
I fix, I tend to discover two more that are twice as difficult to get
rid of.
It's a hydra thing, and I've decided to stop exhausting myself fighting
it. As long as it just lies there dormant, only swallowing the
occasional unwary passer-by once a year, I'm fine ;)
Date: 11 Oct 2017 06:45:00
Message: <web.59ddf55bd7b90bfb5cafe28e0@news.povray.org>
Indeed.  There are lots of interesting things one can do within SDL that I would
have never thought to attempt - instinctually dismissing them as invalid.  I'm
sure there are some I haven't seen and no one's tried yet.
I just came across this neat little trick using conditionals that has the same
"I didn't know you could write things that way!" flavor:
http://www.econym.demon.co.uk/isotut/splines.htm
(at bottom of page)
"This is achieved by mutiplying one x spline function by (v<=pi) and the other
by (v>pi). The comparison operators return 0 for false and 1 for true, so the
sum switches from being one spline to the other when v becomes pi.
Similarly the z spline functions are multiplied by (cos(v)<=0) and (cos(v)>0),
which switch when v=pi/2 and switch back when v=3*pi/2."
Just thought I'd share while it was on my mind.
I need to try it with something like (cos(v)>=pi/2) | (cos(v)<pi)
to see if I can only invoke a certain range.
I was trying to noodle it out using select - but that seemed quite hard to
figure out how to specify a range.
Ooooh - unless I use the conditional as the first parameter....   <lightbulb>
Date: 11 Oct 2017 12:30:01
Message: <web.59de4634d7b90bfb89df8d30@news.povray.org>
Geez, now I know why this looked familiar: it's because I usually write such
code on separate lines. Like so...
#local A =
#if (1)
123;
#else
0;
The semicolon placements 'look' correct this way. I've done similar stuff in the
past.
Or, for the #else, if not zero, then maybe...
#else Let_POVRay_Decide // thus instructing the program to pick something that
it likes, of its own free will. Uh, it does *have* a built-in 'free will'
function, right?????????   ;-)
