POV-Ray : Newsgroups : povray.general : Feature ... suggestions Server Time
21 May 2024 12:20:38 EDT (-0400)
  Feature ... suggestions (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Feature ... suggestions
Date: 6 Mar 2017 16:01:03
Message: <58bdce0f@news.povray.org>
Am 06.03.2017 um 21:32 schrieb Bald Eagle:
> clipka <ano### [at] anonymousorg> wrote:
>>> Then it would be easy to read variables as Complex[n].real and Complex[n].imag
>> Doesn't sound like array-related to me at all, rather a feature of
>> 2-dimensional vectors.
>> You realize that those would be aliases for `.x` and `.y`, right?
> Yes, and yes.
> ...red, .u, .x, and .real would all be the same.
> ...green, .v, .y, and .imag would all be the same as well.
Hmm... I personally think `.r` and `.i` would be neater.
We could also have `i` as a vector constant `<0,1>`, much like `y` is a
vector constant `<0,1,0>`.
Then again, how about having a /genuine/ complex number type instead?
You know, stuff like:
    #declare Foo = 3 + 4*i;
    #declare Bar = Foo * Foo;
Note how the latter operation wouldn't give the right answer when using
2D vector arithmetics as currently implemented.
>> You mean, something like, say, a... /macro/ ?!
>> Yeah, I think it would be neat if POV-Ray had something like that ;)
> OOOOH!   YES!   Macros would be _cool_.  Can we have macros?  PWEEEEEZE!
> :P
Good news: It just so happens that the newest beta already features them ;)
Date: 6 Mar 2017 16:42:35
Message: <58bdd7cb$1@news.povray.org>
>> Yes, and yes.
Thank goodness. My brain was boiling.
>> :P
+1 for the set up. ;)
Regards
Date: 15 Mar 2017 12:55:01
Message: <web.58c971405968649ec437ac910@news.povray.org>
> Why, yes, of course: Start your scene with
>     #version version; // sic!
>     #if (version >= 3.71)
>         #define Tau_Is_Reserved = true;
>     #else
>         #define Tau_Is_Reserved = false;
>     #end
>     #version 3.7; // minimum version
I haven't had a lot of time to think this through, but was wondering if a "fix"
such as this could be conveniently added into an include file like "consts.inc"
> The reason behind this is consistency of 2-dimensional arrays with
> arrays-of-arrays:
That's a great way to explain that.
I'll have to try coding things in macros more often, as it seems to be an
excellent way to clarify a good _mechanism_ by which to do something and
identify a good way to structure the code.
> > Command aliases.  A way to tell the parser to treat all instances of a statement
> > as a command to do "X"  - just like in a Unix shell.
I actually wanted to add a bit of clarification about this:
Writing a macro is similar to what I was thinking, but the real core of the idea
is to have REAL aliases.
https://en.wikipedia.org/wiki/Alias_(command)
Invoking a macro would have a different syntax than the SDL directive.
If I wanted to use, say, "define" instead of "declare",
my thought was to have something along the lines of  #alias {define, declare}
With a macro, I can't write
#define Q = 12345;
and have the parser recognize it.
I'm not pushing for this as a new feature, I just wanted to clearly state my
original suggestion.
And I do realize what a radioactive fustercluck The Parser is.
Date: 15 Mar 2017 14:23:45
Message: <58c986b1$1@news.povray.org>
Am 15.03.2017 um 17:52 schrieb Bald Eagle:
>>     #else
>>     #end
Since such a file would come with a particular POV-Ray version, what use
would it be?
"In computing, alias is a command in various command line interpreters
(shells) [...]"
Q: Is POV-Ray a command line interpreter?
A: No. It is an interpreted programming language.
=> "alias (command)" not applicable to this context.
    __
 ~ (__() ~ ~
Can of worms, opened.
Date: 15 Mar 2017 15:06:50
Message: <58c990ca$1@news.povray.org>
On 3/15/2017 6:23 PM, clipka wrote:
>      __
>   ~ (__() ~ ~
I like it. :)
Regards
Date: 16 Mar 2017 04:02:48
Message: <58ca46a8$1@news.povray.org>
>>      __
>>   ~ (__() ~ ~
> I like it. :)
Now, why did he not make a regular POV-Ray scene of this, I wonder?
Shame on the POV-Ray developer indeed! ;-)
Date: 16 Mar 2017 04:17:52
Message: <58ca4a30$1@news.povray.org>
>>>      __
>>>   ~ (__() ~ ~
>> I like it. :)
It is the new ascii art, output. ;-)
Regards
Date: 21 Mar 2017 10:05:00
Message: <web.58d132625968649ec437ac910@news.povray.org>
> > Yes, and yes.
I like it.   A dedicate complex number system would be very nice.
I'm still more of a fan of .real and .imag.
(I'm actually a bigger fan of _both_ so folks can choose to use one or the
other)
Date: 21 Mar 2017 10:15:00
Message: <web.58d134b05968649ec437ac910@news.povray.org>
What would it take to get a "Point" or "Vector" object{} ?
I thought it might be useful as a "tag" to follow objects around ("Where did my
xyz go???")
The corners of a box could be defined with those vectors/points, and then when
it was transformed, the actual corners of the box - not the bounding box could
be easily accessible by the user.
It would be handy to just define that and plop it into a union to be transformed
like any other object{}, with the same exact syntax - especially for new users
who would have a hard time struggling with all of that vtransform stuff - it's
cumbersome and confusing until you've used it enough times to get the hang of
it.
Date: 21 Mar 2017 20:29:31
Message: <58d1c56b$1@news.povray.org>
Am 21.03.2017 um 15:12 schrieb Bald Eagle:
> xyz go???")
> it.
What you suggest would be inconsistent with the existing primitives.
Remember that
    #declare Foo = sphere {...}
    #declare Bar = union { object{Foo} ... translate ... }
will /not/ modify `Foo`, but rather add a nameless copy of it to `Bar`; so
    #declare Foo = point {...}
should, for the sake of consistency, not modify `Foo` either, making the
whole thing pretty useless.
