POV-Ray : Newsgroups : povray.general : Height field box Server Time
14 Jan 2026 22:05:47 EST (-0500)
  Height field box (Message 1 to 4 of 4)
Subject: Height field box
Date: 28 Jul 2015 07:40:01
Message: <web.55b769dbc3914df6858f08a30@news.povray.org>
I'm trying to render some data using the height field technique, which is
working great.  However, I would really like to be able to remove the box sides
of the height field, so I just see the surface.  The issue is that the box sides
are colored with the color gradient, which is very messy looking.  Also, I want
to plot some of this surface with semitransparency based on height - which works
well, but then you can see the sides of the box through the semitransparent
part, which ruins the effect I was after.
Any ideas gratefully received.
Subject: Re: Height field box
Date: 28 Jul 2015 12:50:01
Message: <web.55b7b1d925cae44a96aeed0d0@news.povray.org>
You can convert height fields into meshes which represent the surface only.
Shapes.inc has some interesting macros to achieve this (HF_Square is the one you
can use, most likely). I propose to play around with that.
Best regards,
Michael
Date: 29 Jul 2015 17:42:15
Message: <55b948b7@news.povray.org>
Try subtracting a second instance of the HF using difference,
(scaled wider and moved downward by a tiny value). Alternatively,
intersect with a box that is slightly smaller than the HF, this
should allow you to assign a separate texture to the sides.
Date: 31 Jul 2015 12:23:09
Message: <55bba0ed$1@news.povray.org>
Am 28.07.2015 um 13:39 schrieb StavroMueller:
clipped_by with a slightly smaller box should be perfect for the job.
