POV-Ray : Newsgroups : povray.general : Simulating Red and Blue Shift Server Time
12 Jul 2025 10:54:00 EDT (-0400)
  Simulating Red and Blue Shift (Message 1 to 8 of 8)
Subject: Simulating Red and Blue Shift
Date: 31 Mar 2015 08:10:00
Message: <web.551a8e0e42443f295189b500@news.povray.org>
I have a cylinder (open, hollow) that has a PNG graphic file as texture. That
image consist only of white dots (blurred edges) and the rest is transparent,
and I want to simulate light speed (or a wormhole travel, whatever).
The texture moves along that cylinder.
Outside of that cylinder is another one with a color_map (red to white to blue).
QUESTION
How can I achieve that of that PNG texture only the white color allows a part of
the outside color_map can shine through? "Filter" and "transmit" seem to be
rejected when using an image. Any idea?
SCENE SOURCE CODE
#declare Warp = texture
 pigment
  image_map
   png "Warp - 001.png"
   map_type 1
   interpolate 2
  rotate < 0.0, 0.0, 90.0 >  //
  rotate < 0.0, 90.0, 0.0 > //
  scale < 10000.0, 10000.0, 10000000.0 >
  translate < 0.0, 0.0, (50000.0*clock) >
 finish { ambient 1.0 }
#declare LightShift = texture
 pigment
  gradient z
  color_map
   [ 0.0 pigment Blue ]
   [ 0.5 pigment White ]
   [ 1.0 pigment Red ]
  scale < 1.0, 1.0, 1000000.0 >
background { Black }
cylinder // Warp
 < 0.0, 0.0, -1000000.0 > < 0.0, 0.0, 1000000.0 > 10000.0
 hollow
 open
 texture { Warp }
cylinder // Warp Light Shift
 < 0.0, 0.0, -1000000.0 > < 0.0, 0.0, 1000000.0 > 10000.01
 hollow
 open
 texture { LightShift }
Subject: Re: Simulating Red and Blue Shift
Date: 31 Mar 2015 08:23:59
Message: <551a91df$1@news.povray.org>
I don't know if this can help you, but when using images you can use the
following terms:
transmit all or filter all
followed by a value, for instance 0.5, inside the pigment block
containing the image.
Date: 31 Mar 2015 08:30:00
Message: <web.551a9342fbd1e7355189b500@news.povray.org>
Or is there any other way to change just the whites in a distance from white to
blue (-z) and to red (+z)?
Date: 31 Mar 2015 08:55:10
Message: <551a992e$1@news.povray.org>
On 31.03.2015 14:08, Sven Littkowski wrote:
> That image consist only of white dots (blurred edges) and the rest is transparent
It sounds like you might be better of changing the image so that
the background is opaque and the dots are transparent? Then the star
color would be determined by the cylinder texture.
Date: 31 Mar 2015 09:53:51
Message: <551aa6ef@news.povray.org>
> Hi,
Another idea: Have you thought about using an absorption media inside
the cylinder? you might be able to simulate the light shift that way.
Date: 31 Mar 2015 16:35:00
Message: <web.551b040bfbd1e7355189b500@news.povray.org>
I like both ideas:
- transparent stars inside black image
- medium inside cylinder
But would a media not slow down the rendering? And it is only the stars that I
want to change the colors from white to red and blue, not the black. But how
would such a media be made? Can you give a sample code?
For working on the suggestion with transparent stars, I will change now the
graphic. Should easily be possible.
Steven
> > Hi,
> Thomas
Date: 31 Mar 2015 16:45:00
Message: <web.551b0705fbd1e7355189b500@news.povray.org>
Heck, this idea is so simple, I wonder why I didn't get it... :-D
Date: 1 Apr 2015 03:33:01
Message: <551b9f2d@news.povray.org>
On 31-3-2015 22:31, Sven Littkowski wrote:
> I like both ideas:
I was thinking about something like this (not tested) for a cylinder
oriented along the z-axis:
cylinder {
   <0, -0.5, 0>,<0, 0.5, 0>, 1
   pigment {rgbt <0,0,0,1>}
   hollow
   interior {
     //redshift
     media {
       absorption <0,0,1>
       density {
         cylindrical
         density_map {
           [0 rgb 0]
           [1 rgb 1]
     //blueshift
     media {
       absorption <1,0,0>
       density {
         cylindrical
         density_map {
           [0 rgb 0]
           [1 rgb 1]
   scale MyScale
it is possible to vary the absorption value of course as needed and/or
use a density block inside the media
Drawback might be that you may not be able to use the two media at the
same time as they coincide. You will have to build in a switch for when
to use redshift or blueshift.
In terms of dropping render speed, that would be minimal. Scattering
media is what influences speed most.
