![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Here is a simplified version of a macro I wrote:
#macro my_macro(picture_name)
#local my_hf = height_field {picture_name};
When I call the macro with some picture name :
my_macro("the_pict_name")
I get the following error message :
"Parse Error: Expected 'map file spec', string identifier found instead"
I get no error when I replace the line inside the macro with :
#local my_hf = height_field {"the_pict_name"};
I've tried to put the picture with my application include files and in other
folders of my system include files with the same result.
By the way, I use Pov_Ray 3.7 unofficial on a mac.
Any idea to solve this problem ?
Thanks for your help.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> #end
Can you try to add the "optional" file type before the filename ?
(if it works, you would need to specialise your macro on file type)
something like
height_field{ png picture_name }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 02.02.2015 um 23:27 schrieb Le_Forgeron:
> something like
Sounds like a bug to me. If height field's file type is optional when
using a string literal for the filename, it should just as well be
optional when using a string variable.
Shall we draw straws who gets to fix this?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 03.02.2015 um 02:25 schrieb clipka:
>> something like
Never mind. Fixed this already.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 02.02.2015 um 22:56 schrieb Alexis:
> #end
As a workaround until the brand new fix is available in a Mac release, try:
#local my_hf = height_field { concat(picture_name,"") };
Don't ask why...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Don't ask why...
OK, I don't ask why, but I thank you: it works!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
