POV-Ray : Newsgroups : povray.general : height_field name in a macro Server Time
14 Jan 2026 22:04:43 EST (-0500)
  height_field name in a macro (Message 1 to 6 of 6)
Subject: height_field name in a macro
Date: 2 Feb 2015 17:00:00
Message: <web.54cff22e70575c0d9fbf62e70@news.povray.org>
Here is a simplified version of a macro I wrote:
#macro my_macro(picture_name)
  #local my_hf = height_field {picture_name};
When I call the macro with some picture name :
  my_macro("the_pict_name")
I get the following error message :
"Parse Error: Expected 'map file spec', string identifier found instead"
I get no error when I replace the line inside the macro with :
  #local my_hf = height_field {"the_pict_name"};
I've tried to put the picture with my application include files and in other
folders of my system include files with the same result.
By the way, I use Pov_Ray 3.7 unofficial on a mac.
Any idea to solve this problem ?
Thanks for your help.
Subject: Re: height_field name in a macro
Date: 2 Feb 2015 17:27:22
Message: <54cff9ca$1@news.povray.org>
> #end
Can you try to add the "optional" file type before the filename ?
(if it works, you would need to specialise your macro on file type)
something like
height_field{ png picture_name }
Date: 2 Feb 2015 20:25:09
Message: <54d02375@news.povray.org>
Am 02.02.2015 um 23:27 schrieb Le_Forgeron:
> something like
Sounds like a bug to me. If height field's file type is optional when
using a string literal for the filename, it should just as well be
optional when using a string variable.
Shall we draw straws who gets to fix this?
Date: 2 Feb 2015 21:07:42
Message: <54d02d6e@news.povray.org>
Am 03.02.2015 um 02:25 schrieb clipka:
>> something like
Never mind. Fixed this already.
Date: 2 Feb 2015 21:14:28
Message: <54d02f04$1@news.povray.org>
Am 02.02.2015 um 22:56 schrieb Alexis:
> #end
As a workaround until the brand new fix is available in a Mac release, try:
    #local my_hf = height_field { concat(picture_name,"") };
Don't ask why...
Date: 3 Feb 2015 03:50:00
Message: <web.54d08b2f835b497b9b490fcd0@news.povray.org>
> Don't ask why...
OK, I don't ask why, but I thank you: it works!
