POV-Ray : Newsgroups : povray.general : Optical cloaking Server Time
17 Nov 2025 04:14:06 EST (-0500)
  Optical cloaking (Message 1 to 4 of 4)
Subject: Optical cloaking
Date: 1 Oct 2014 01:25:00
Message: <web.542b8fbb7b612d485e7df57c0@news.povray.org>
Maybe someone with free time could look into this and model it.
That would be cool.  :)
http://www.rochester.edu/newscenter/watch-rochester-cloak-uses-ordinary-lenses-to-hide-objects-across-continuous-range-
of-angles-70592/
Subject: Re: Optical cloaking
Date: 9 Oct 2014 03:00:01
Message: <web.543631939d3a84f4211620b20@news.povray.org>
 Sure thing, free time used up now!  :) Just a hack but I think it's basically
what they're doing if I understood it right. Objects avoiding the narrow
refracted area are not seen. No idea how each lens is shaped but this scene file
seems to do the trick, aside from edge distortion which could possibly be
reduced or eliminated by either increasing lens size within rings or thickening
the rings.
// BEGIN SCENE
/* imitating cloaking lenses, BGH 2014.77 */
/* NOTE: use first command line when PhotonsMedia=yes for faster render */
//cmd: +w160 +h120
//cmd: +w512 +h384 +a
#version 3.7;
#local PhotonsMedia=no; // side view with light beams?
#local Overview=no; // a look from above front?
global_settings
 assumed_gamma 1
 max_trace_level 11
#if (PhotonsMedia=yes)
  photons {
    //count 333333
    spacing 0.3
    media 333, 1
    autostop 0
    jitter 0.3
#else #end
#if (PhotonsMedia=no)
light_source
 -99*z,1
 rotate <45,45,0>
 media_interaction off
 photons
  reflection off
  refraction off
#else #end
light_source
 -33*z,3
 parallel
 spotlight
 radius 0.1
 falloff 0.13
 point_at 0
 media_interaction on
 photons
  reflection off
  refraction on
#else #end
// view
camera
 location <50,0,15>
 look_at <0,0,15>
 angle 45
#else
#if (Overview=yes)
 location <0,12.5,-25>
 look_at <0,0,5>
#else
 location <0,0,-25>
 look_at <0,0,0>
 angle 33
 up y
 right 4/3*x
// room
box
 -1,1
 scale 100
 material
 texture
  pigment
   gradient x
   color_map
    [0.1 rgb <0.1,0.1,0.9>]
    [0.15 rgb <1,1,1>]
 texture
  pigment
   gradient y
   color_map
    [0.1 rgb <0.1,0.9,0.1>]
    [0.15 rgbt <1,1,1,1>]
 interior
  media
   scattering
    1, <0.1,0.01,0.1>
   method 3
   intervals 1
   samples 33
#else #end
 translate -33*z
 hollow on
 photons
  target
  //collect on
  //reflection off
  //refraction on
#else #end
// test object between lenses
box
 -1,1
 scale <9,0.5,0.1>
 material
  texture
   pigment
    rgb <1,0.01,0.01>
 translate <0,1,10>
// lens 1
union
 difference
  cylinder
   -1*z,1*z,3.33
  cylinder
   -1.01*z,1.01*z,3
  material
   texture
    pigment
     rgb <0,0,0>
sphere
 0,1
 scale <5,5,1>
 clipped_by
  cylinder
   -1.01*z,1.01*z,3
 material
  texture
   pigment
    rgbt <1,1,1,1>
   finish
    emission 0.1
    diffuse 0
   interior
    ior 2.5
photons
 target
 collect on
 reflection off
 refraction on
 hollow on
#else #end
 translate <0,0,0>
// lens 2
union
 difference
  cylinder
   -1*z,1*z,3.33
  cylinder
   -1.01*z,1.01*z,3
  material
   texture
    pigment
     rgb <0,0,0>
sphere
 0,1
 scale <5,5,1>
 clipped_by
  cylinder
   -1.01*z,1.01*z,3
 material
  texture
   pigment
    rgbt <1,1,1,1>
   finish
    emission 0.1
    diffuse 0
   interior
    ior 2
photons
 target
 collect on
 reflection off
 refraction on
 hollow on
#else #end
 translate <0,0,15>
// lens 3
union
 difference
  cylinder
   -1*z,1*z,3.33
  cylinder
   -1.01*z,1.01*z,3
  material
   texture
    pigment
     rgb <0,0,0>
difference
sphere
 0,1
 scale <5,5,1>
sphere
 0,1
 scale <10,10,1>
 translate <0,0,-0.25>
 clipped_by
  cylinder
   -1.01*z,1.01*z,3
 material
  texture
   pigment
    rgbt <1,1,1,1>
   finish
    emission 0.1
    diffuse 0
   interior
    ior 1.1
photons
 target
 collect on
 reflection off
 refraction on
 hollow on
#else #end
 translate <0,0,25>
// END SCENE
Date: 10 Oct 2014 10:00:01
Message: <web.5437e6549d3a84f45e7df57c0@news.povray.org>
It does seem to happen like that, doesn't it?
> the rings.
There were some videos of the lab setup, and it seems you've got the arrangement
put together accurately.  Nice job!
I haven't ever used photons, and with my slow little laptop it may be a while
yet before I ever do.  That slowed the render down by a factor of 100 or
1000...!
Thanks for indulging my curiosity with your skills
Date: 13 Oct 2014 22:20:00
Message: <web.543c87569d3a84f4f4c45c8c0@news.povray.org>
Not so accurate as you might think, I'm sure you noticed they had 4 lenses and I
only used 3. Just was trying to make it easier to create, and in part wanted to
see how simple it could be done. Photons aren't needed anyhow, I only wanted to
see same thing the real equipment was showing-- and only partly succeeded.
The original experiment probably required refinements to their apparatus to get
a more perfect result.
Not so much skill as experience... 20 years now and so much I still can't do but
always wish I could. Admiring the skills of others is half (and more) of the fun
I've had with POV-Ray!
A big thanks to you for telling of this idea!
