![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I understand that you can turn radiosity effects for emission media on and off
in the radiosity block, but what I'm wondering is whether there's a way, if I
have two objects with emission media, to have the media in ONE object have
radiosity effects and the other not.
Basically, I have a scene with a blue glow-y media object that uses radiosity to
light other objects in the scene, but I also want to create some white media
clouds that *don't* cast light into the scene...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 24.07.2014 20:51, schrieb jceddy:
If the object containing the media-to-be-ignored is just a simple media
containers, it's as simple as specifying "no_radiosity" on the object.
In more complex cases, e.g. if the object also has a semi-transparent
surface that should affect radiosity, you could use two copies of the
object: One with the media and "no_radiosity", and one without the media
and with "no_image no_reflection no_shadow" instead.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Perfect, thanks!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
