POV-Ray : Newsgroups : povray.general : Why my lathe object is broken? Server Time
25 Nov 2024 12:36:23 EST (-0500)
  Why my lathe object is broken? (Message 1 to 10 of 14)
Subject: Why my lathe object is broken?
Date: 24 May 2014 00:40:01
Message: <web.538021778197fb3f4277cb5c0@news.povray.org>
I'm a beginner of Pov-Ray and I'm trying to create a lathe object in Pov-Ray,
and it looks broken somehow. Could someone give me some suggestion on how to fix
it?
The problem is indicated on this image:
http://i.stack.imgur.com/8cerL.png
Any suggestions or comments are appreciated.
Here is the code I used to create the scene:
global_settings {
  max_trace_level 5
  assumed_gamma 1.0
  radiosity {
    pretrace_start 0.08
    pretrace_end   0.01
    count 35
    nearest_count 5
    error_bound 1.8
    recursion_limit 2
    low_error_factor .5
    gray_threshold 0.0
    minimum_reuse 0.015
    brightness 1
    adc_bailout 0.01/2
#default {
    pigment {rgb 1}
    finish {
      ambient 0.0
      diffuse 0.6
      specular 0.6 roughness 0.001
      reflection { 0.0 1.0 fresnel on }
      conserve_energy
light_source { <050,250,250> 1 }
background { rgb <0,.25,.5> }
camera{
    location <250,250,250>
    look_at <0,100,0>
lathe{
quadratic_spline
38,
<32.8000,284.0000>,
<37.8000,276.0000>,
<43.3000,267.0000>,
<49.3000,257.0000>,
<53.8000,248.0000>,
<58.3000,236.0000>,
<61.8000,224.0000>,
<64.3000,212.0000>,
<65.3000,199.0000>,
<64.3000,186.0000>,
<61.8000,174.0000>,
<58.3000,166.0000>,
<53.3000,157.0000>,
<46.3000,149.0000>,
<38.8000,144.0000>,
<30.3000,140.0000>,
<23.3000,137.0000>,
<17.8000,135.0000>,
<13.8000,135.0000>,
<13.8000,129.0000>,
<10.3000,127.0000>,
<7.2500,122.0000>,
<5.7500,116.0000>,
<4.7500,109.0000>,
<4.2500,101.0000>,
<3.7500,88.2000>,
<3.7500,70.3000>,
<3.7500,53.8000>,
<4.7500,39.8000>,
<6.7500,25.8000>,
<8.2500,20.3000>,
<11.3000,16.8000>,
<17.3000,14.3000>,
<25.3000,11.3000>,
<33.8000,9.2500>,
<41.3000,7.7500>,
<48.3000,5.7500>,
<48.8000,0.2500>
texture{
       pigment{color White}
       finish { phong 0.5}}
Subject: Re: Why my lathe object is broken?
Date: 24 May 2014 01:56:24
Message: <53803488@news.povray.org>
You need to use the sturm keyword in the lathe
Regards
Date: 24 May 2014 10:35:01
Message: <web.5380ad05952f32a84277cb5c0@news.povray.org>
Hi Stephen,
It works , thanks a lot!
But there is still one broken part remains. I created a zoom in of the
broken part here
http://imgur.com/j1ys4Nb
Do you know why that happens?
The 2d plot of the data I used in the lathe object is shown here
http://i.stack.imgur.com/rrF7B.png
Thanks a lot for your help.
> Regards
>      Stephen
Date: 24 May 2014 12:44:49
Message: <5380cc81$1@news.povray.org>
On 24/05/2014 15:33, xslittlegrass wrote:
 > Hi Stephen,
 > broken part here
Not really but I suspect that it may have something to do with the
spacing of the plotted points.
Have you tried a cubic curve?
And less points. Remember that the curve does not necessary pass through
the points. They are control points.
Regards
Regards
Date: 24 May 2014 14:35:00
Message: <web.5380e5ca952f32a81e36f4d20@news.povray.org>
I tried a cubic curve and it does look better. I agree that the "broken" may
caused by the data points.
Thanks a lot for your help :)
>  > Hi Stephen,
>  > broken part here
> Regards
>      Stephen
> Regards
>      Stephen
Date: 24 May 2014 16:18:05
Message: <5380fe7d@news.povray.org>
It is a pleasure. :-D
I have posted a couple of screenshots in p.b.images along with the lathe
code I modified, a bit. As an example to show what I did.
Regards
Date: 27 May 2014 19:32:32
Message: <53852090$1@news.povray.org>
>  > Hi Stephen,
>  > broken part here
For a quadratic_spline, the FIRST  point is a controll point, all others
are actual points that are actualy used and, also, serve as controll
points for the next point but not for the previous one. The curve is
controlled from the second to third point but not from the third to
second points.
In most cases, using the cubic_spline gives beter results.
In your case, it will shorten the object by one interval.
In some cases, using less points can help.
Date: 28 May 2014 22:20:00
Message: <web.5386983c952f32a81e36f4d20@news.povray.org>
> Regards
>      Stephen
What is p.b.images?
Best,
xslittlegrass
Date: 29 May 2014 01:51:45
Message: <5386caf1@news.povray.org>
>> Regards
>>       Stephen
> What is p.b.images?
> Best,
> xslittlegrass
Sorry, povray.binaries.images on this newsgroup.
http://www.povray.org/resources/newsgroups/
http://news.povray.org/povray.binaries.images/
http://news.povray.org/povray.binaries.images/thread/%3C5380fd72%40news.povray.org%3E/
If I remember correctly. Bishop3D's trial allows you to save scenes with
up to 4 objects. That would allow you to work on a lathe and save it.
You would need to install PovRay 3.6 to get an immage but you can
inspect the code and copy and past into your 3.7 scene.
Regards
Date: 29 May 2014 17:32:46
Message: <5387a77e$1@news.povray.org>
>>>> "broken" may
>>> Regards
>>>       Stephen
>> What is p.b.images?
>> Best,
>> xslittlegrass
Use version 3.7. Version 3.6.x is obsolete.
Next, it's just a mather of refering the correct path.
