POV-Ray : Newsgroups : povray.general : File I/O Server Time
17 Apr 2026 13:40:41 EDT (-0400)
  File I/O (Message 1 to 8 of 8)
Subject: File I/O
Date: 17 Apr 2014 11:20:01
Message: <web.534ff08a911c57344e8159130@news.povray.org>
Here I am again!
#fopen MyFile "niks.txt" write
  #declare i=1;
  #while (i <= 5)
     #write (MyFile, i,",")
     #declare i=i+1;
     #end  // while
  #fclose Myfile
  #fopen MyFile "niks.txt" read    // Here parse error!
  #declare i=1;
  #while (i <= 5)
     #read (MyFile, i)
     #declare i=i+1;
     #end  // while
  #fclose Myfile
This piece of code gives a parse error on the indicated line:
Cannot read from file niks.txt because the file is open for writing only
What is wrong here?
I'm using Windows 7
Paul
Subject: Re: File I/O
Date: 17 Apr 2014 11:54:13
Message: <534ff925$1@news.povray.org>
Le 17/04/2014 17:17, pbrants nous fit lire :
> Here I am again!
>   #declare i=1;
>   #while (i <= 5)
>      #declare i=i+1;
>      #end  // while
>   #fclose Myfile
>   #declare i=1;
>   #while (i <= 5)
>      #read (MyFile, i)
>      #declare i=i+1;
>      #end  // while
>   #fclose Myfile
> What is wrong here?
> I'm using Windows 7
You closed Myfile, but opened MyFile. Typo! (Camel vs Pascal)
Date: 17 Apr 2014 13:11:20
Message: <53500b38@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
> >   #fclose Myfile
Which raises the question of why POV-Ray doesn't give an error if you
use #fclose with an undefined identifier.
Date: 17 Apr 2014 18:10:00
Message: <web.53505012830820894e8159130@news.povray.org>
> > Here I am again!
> >   #declare i=1;
> >   #while (i <= 5)
> >      #declare i=i+1;
> >      #end  // while
> >   #fclose Myfile
> >   #declare i=1;
> >   #while (i <= 5)
> >      #read (MyFile, i)
> >      #declare i=i+1;
> >      #end  // while
> >   #fclose MyFile
> > What is wrong here?
> > I'm using Windows 7
Sorry, it was a typo indeed, but it gives the same error with the typo
corrected!
Paul
Date: 17 Apr 2014 18:20:01
Message: <web.53505324830820894e8159130@news.povray.org>
Sorry again, it was a typo in the original program, all works OK now!
Paul
Date: 17 Apr 2014 18:21:22
Message: <535053e2@news.povray.org>
>> > Here I am again!
>> >   #declare i=1;
>> >   #while (i <= 5)
>> >      #declare i=i+1;
>> >      #end  // while
>> >   #fclose Myfile
>> >   #declare i=1;
>> >   #while (i <= 5)
>> >      #read (MyFile, i)
>> >      #declare i=i+1;
>> >      #end  // while
>> >   #fclose MyFile
>> > only
>> > What is wrong here?
>> > I'm using Windows 7
> corrected!
> Paul
What is the content of niks.txt if you open it in text editor?
Ger
Date: 17 Apr 2014 22:20:01
Message: <web.53508a8983082089c2d977c20@news.povray.org>
> corrected!
> Paul
I didn't see that typo for about half an hour(!), while playing with your code.
Prior to noticing it, I was trying everything under the Sun-- eventually
re-writing your code verbatim. I was just getting ready to post the same
'solution.' ;-)
BTW, the #write and #read blocks can have *different* 'file handle identifiers'
and still work OK (I've never seen any problems when doing so.)
#fopen ABC "niks.txt" write
#write(ABC, ... )
#fclose ABC
#fopen XYZ "niks.txt" read
#read(XYZ, ...)
#fclose XYZ
Date: 18 Apr 2014 03:17:41
Message: <5350d195$1@news.povray.org>
>>> Here I am again!
>>>    #declare i=1;
>>>    #while (i <= 5)
>>>       #declare i=i+1;
>>>       #end  // while
>>>    #fclose Myfile
>>> What is wrong here?
>>> I'm using Windows 7
> corrected!
IF I read your code above, you corrected the typo in the #read but not
in the #write section...
As a side note, be aware that in your #read section, you use the
parameter i for two different things at the same time. Except if
intended, you may get strange results. An alternative would be:
#while (defined (MyFile))
   #read (MyFile, i)
   do here what you want to do with i
#end  // while
#fclose MyFile
