POV-Ray : Newsgroups : povray.general : Max components in blob? Server Time
30 Sep 2024 00:08:46 EDT (-0400)
  Max components in blob? (Message 1 to 5 of 5)
Subject: Max components in blob?
Date: 21 Aug 2013 17:25:01
Message: <web.52152ff8b80bae894b81c8b60@news.povray.org>
I get the following error:
Possible Parce Error: There are more than the maximum supported components in a
blob.
Fatal error in parser: Uncategorized error.
Render failed
What is the maximum size?
I create an array and initialize some of the elements.
I scan the array and add a blob sphere{} component for some of the initialized
array elements.
I also #write to a file the blob component, later I can choose to include the
file.
array [480][60][348], array and blob works
array [720][90][522], array works, blob fails
Win vista 64
8Gb memory
Suggestions?
Stephen S
Subject: Re: Max components in blob?
Date: 21 Aug 2013 17:35:01
Message: <web.5215325cdd1a2b454b81c8b60@news.povray.org>
> blob.
> Render failed
> array elements.
> file.
> Win vista 64
> 8Gb memory
> Suggestions?
> Stephen S
POV-Ray 3.7.0.rc7.msvc10.win64
Date: 21 Aug 2013 17:55:00
Message: <web.521536b6dd1a2b454b81c8b60@news.povray.org>
> blob.
> Render failed
> array elements.
> file.
> Win vista 64
> 8Gb memory
> Suggestions?
> Stephen S
Looking further:
The include file has 1439767 lines of entery, starting with
blob{threshold .2
sphere{ <0.0140553,-2.98281,0.000647176>,0.231891,.008}
sphere{ <-0.00691917,-2.98312,0.0420482>,0.251227,.008}
Stephen S
Date: 21 Aug 2013 19:39:47
Message: <52154fc3@news.povray.org>
Am 21.08.2013 23:24, schrieb StephenS:
> blob.
> Render failed
The maximum number of internal(!) components per blob is 1,000,000; note
that while each spherical component is represented by a single internal
component, each cylindrical component is actually represented by three
components internally (the cylinder itself + the two end hemispheres).
Date: 21 Aug 2013 21:00:00
Message: <web.52156273dd1a2b454b81c8b60@news.povray.org>
> > blob.
> > Render failed
Thank you.
I will limit the size of the initial array to start with, and work from there.
Stephen S
