POV-Ray : Newsgroups : povray.general : Output Image METADATA of critical settings from POV-Ray? Server Time
19 Nov 2025 17:39:31 EST (-0500)
  Output Image METADATA of critical settings from POV-Ray? (Message 1 to 5 of 5)
Subject: Output Image METADATA of critical settings from POV-Ray?
Date: 16 Jul 2013 11:30:00
Message: <web.51e565cf133566aff7137200@news.povray.org>
Sure would be nice if there were a way for POV-Ray to encode a lot of the
critical settings (command line quality/AA/etc. options) as well as possibly
camera/lookat and all light vector locations, clock values into the JPG/PNG
image similar to the way the digital cameras put all the ISO/focus/etc info
tagged in there (even using simple metatags would be nice).  This would allow me
to keep track of some limited link to at least a rudimentary amount of the
settings used to generate an image many months later amid so many test
renders...
Appologize if this is already covered...a quick search yielded only the
following:
    http://wiki.povray.org/content/Reference:File_Output_Options
        This metadata contains the POV-Ray version, render date/time (GMT),
platform (e.g. x86_64-pc-win), and compiler used to build the POV-Ray
executable.
which seems relatively limited in details...
Subject: Re: Output Image METADATA of critical settings from POV-Ray?
Date: 16 Jul 2013 11:49:05
Message: <51e56b71@news.povray.org>
Le 16/07/2013 17:26, Jeff nous fit lire :
> renders...
> following:
> executable.
The problem is that metadata are limited, on some format, to only 4
lines of exactly 80 characters (ascii only). there is no place for all
you have requested.
Date: 17 Jul 2013 20:34:20
Message: <51e7380c$1@news.povray.org>
>> the critical settings (command line quality/AA/etc. options) as well as
>> possibly camera/lookat and all light vector locations, clock values
>> into the JPG/PNG image similar to the way the digital cameras put all
>> the ISO/focus/etc info tagged in there (even using simple metatags
>> would be nice).  This would allow me to keep track of some limited link
>> to at least a rudimentary amount of the settings used to generate an
>> image many months later amid so many test renders...
> you have requested.
(a) That is not true of either PNG or JPG files.  There is no reason this
information could not be included in those file formats.
(b) I personally don't care about other archaic image file formats that
have those sorts of comment limitations, but even if for some reason other
folks do, you can pack a lot of information into 320 characters.  I
suspect simply listing the source filename and non-default command-line
options needed to reproduce the output would probably fit easily in that
space for all but a few extreme cases, so even that's not really a valid
reason not to do it..
FWIW, I agree with Jeff that including render settings information in the
output would be very useful, and I see no reason it couldn't be included,
at the very least, in PNG/JPG files, and possibly others.
-alex
Date: 18 Jul 2013 03:57:40
Message: <51e79ff4$1@news.povray.org>
>> you have requested.
It's not 320 characters. It's 4 lines of 80 (and no, that's not the same
thing). Btw, it's only 7 bits-ascii.(indeed, only 32-126, not even sure
about 127)
>  I
Please provide an *exhaustive* list of render settings that would be
very useful.
But 3.7 is feature-frozen, so it won't happen in that release.
Do you want human readable or machine readable too ? (some format have
metadata in tagged forms)
Just because nobody complains does not mean all parachutes are perfect.
Date: 20 Jul 2013 10:21:09
Message: <51ea9cd5@news.povray.org>
> very useful.
How about including the command line parameters themselves? It
is a rather compact notation and can be easily used to reproduce
the render.
