POV-Ray : Newsgroups : povray.general : passing custom parameter Server Time
25 Feb 2026 21:58:41 EST (-0500)
  passing custom parameter (Message 1 to 5 of 5)
Subject: passing custom parameter
Date: 2 Jan 2013 07:35:01
Message: <web.50e427e8922af2f62324a6090@news.povray.org>
I want to render a scene multiple times with different rotation on each
rendering, and I want to execute my pov script from my website (java), so I want
to call same script with a custom parameter, and use that parameter for rotation
angle value in the script.
I also tried to use +O (output) parameter, as we can use similar value for both,
say on first term we can pass 1, which will create 1.png with 1*X rotation, term
2 will create 2.png with 2*X rotation and so on.
However I am not getting, how to do that in Pov-Ray, any help would be greatly
appropriated.
Thanks in advance.
Subject: Re: passing custom parameter
Date: 2 Jan 2013 09:13:09
Message: <50e44075$1@news.povray.org>
Le 02/01/2013 13:31, bhupesh nous fit lire :
> Hi,
> appropriated.
> Thanks in advance.
You would need to build on the fly the INI file, to use the
"Define=foo=44" capability (not available from the command line) to set
the value of variable foo to 44. (should work with 3.7 version, at least)
Either that, or you create also on the fly some file that get #include
by your main script. Content of such file could be "#define foo=44;"
Now, if all you have to set is just one single parameter (and not a
collection of them), you can instead use the animation sub-system to set
the clock value,
look at +K, +KI, +KF, +KFI, +KFF, +SF, +EF, +KC vs -KC
> http://wiki.povray.org/content/Documentation:Animation_Options
Date: 2 Jan 2013 09:15:09
Message: <50e440ed$1@news.povray.org>
On 01/02/2013 07:31 AM, bhupesh wrote:
> Hi,
> appropriated.
> Thanks in advance.
povray has an animation loop here's some examples in the tutorial section:
http://wiki.povray.org/content/Documentation:Tutorial_Section_3.7#Making_Animations
and here's other control options:
http://wiki.povray.org/content/Reference:Animation_Options
Date: 2 Jan 2013 09:20:22
Message: <50e44226@news.povray.org>
   IIRC, that works from the command line too, at least on the unix version.
Jaime
Date: 2 Jan 2013 09:23:34
Message: <50e442e6$1@news.povray.org>
Le 02/01/2013 15:20, Jaime Vives Piqueres nous fit lire :
Right. but no shortcut:
povray -Ibb.pov Declare=foo=23
