What solutions do you guys use to render your Povray animations?
I see there are render farms you can rent by the core/hour.
Is there a peer 2 peer solution? IMP seems to be offline.
Any ideas??
> Any ideas??
Generally, I just resign myself to leaving my computer on for a long time.
Keeping in mind that I've never rendered anything terribly long...
There was, at one point, if memory serves, a distributed network solution - a
quick search gives several results including HTTPov, which seems to be defunct
as the website is gone, but it also seems to be available on github.
Another distributed solution is PVMPov which is available from Sourceforge...
And this link http://homepages.ihug.co.nz/~wrooney/present/povclust.html
tells you how to set up your own Beowulf Cluster (might be kinda old... it seems
to have been designed for v. 3.1 but might still work with modifications)
other than that, I have no idea.
A.D.B.
p.s. - seeing as how the server seems to be gone, it might be a good idea to
remove the link to HTTPov from the news page.
> Any ideas??
The server and client code for IMPFarm is still on sourceforge.
http://sourceforge.net/projects/impfarm/
> > Any ideas??
I just tried impfarm they are now gone!
>>> Any ideas??
You have to run your own server now. That code is also on sourceforge.
