POV-Ray : Newsgroups : povray.general : Isosurface help Server Time
19 Nov 2025 02:25:04 EST (-0500)
  Isosurface help (Message 1 to 10 of 14)
Subject: Isosurface help
Date: 23 Jul 2012 15:10:01
Message: <web.500da13cc397323e7f523b7e0@news.povray.org>
Hey guys!  I just had a quick question...
I was trying to generate the graph of this function (in Cartesian coordinates):
-z + 1.00003 = (3x^2 + 3y^2)/(200000)
However, when I render the following code, nothing shows up except for the
plane:
#version 3.6;
global_settings {
  max_trace_level 256
  ambient_light White
  assumed_gamma 1.0
  location <10,10,0>
  look_at <0,0,0>
  // rotate <0,0,-clock*90>
light_source {
  <1000,1000,0>
  color White
plane {
  y, -10
  pigment { hexagon Green, White, Blue }
isosurface {
  function {
    -y - ((3*pow(x,2) + 3*pow(z,2))/(200000)) + 1.00003
  // contained_by { box { -2,2 } }
    color Red
I'm assuming that even though z = -x (in POV-Ray), it doesn't really matter for
the equation since x (in the equation) is squared.  Thanks in advance!
- Chaanakya
Subject: Re: Isosurface help
Date: 23 Jul 2012 16:00:01
Message: <web.500dacf9fb628f717f523b7e0@news.povray.org>
> plane:
> #version 3.6;
> global_settings {
>   max_trace_level 256
>   ambient_light White
>   assumed_gamma 1.0
> camera {
>   location <10,10,0>
>   look_at <0,0,0>
> light_source {
>   <1000,1000,0>
>   color White
> plane {
>   y, -10
> isosurface {
>   function {
>   pigment {
>     color Red
> - Chaanakya
Even more strangely, when I use the equally valid function
function {
  y + 3*pow(x,2)/200000 + 3*pow(z,2)/200000 - 1.00003
I get a cube.  I think there's something fundamental about isosurfaces that I'm
not understanding?  That is, how should I convert the function z = -3x^2/200000
- 3y^2/200000 + 1.00003 into an isosurface?
- Chaanakya
Date: 23 Jul 2012 16:43:20
Message: <500db768@news.povray.org>
Am 23.07.2012 21:58, schrieb Chaanakya:
>> plane:
>> isosurface {
>>    function {
>>    pigment {
>>      color Red
> function {
Do un-comment the "contained_by" line!
At x=0,z=0 you have y = 1.00003, which is outside the default
contained_by object (box{1,1}), and even at the maximum x and z
(x=1,z=1) you have y = 1.00000, which just barely touches the box.
I.e. the surface you defined is (for practical purposes) all outside
default container; so the inside of the default container is either
completely outside the isosurface (first version) so that you don't see
anything, or completely inside (second version) so that you simply see
the container's shape.
Date: 23 Jul 2012 16:55:00
Message: <web.500db981fb628f717f523b7e0@news.povray.org>
> >> plane:
> >> isosurface {
> >>    function {
> >>    pigment {
> >>      color Red
> > function {
I'm trying to figure out exactly what container I should use - if I use box {
<-1,1,-1>,<1,1.00003,1> } I get nothing (I understand why).  If I use box {
<-1,0.9,-1>,<1,1.00003,1> } I get a box.  How do I get the elliptic paraboloid
to show up?
Thanks!
- Chaanakya
Date: 23 Jul 2012 17:03:43
Message: <500dbc2f$1@news.povray.org>
> to show up?
Use a bigger box.
Regards
Date: 23 Jul 2012 17:13:34
Message: <500dbe7e$1@news.povray.org>
Am 23.07.2012 22:52, schrieb Chaanakya:
>>>> plane:
>>>> isosurface {
>>>>     function {
>>>>     pigment {
>>>>       color Red
>>> function {
> to show up?
At the current dimensions, the curvature of the isosurface is simply too
small to be noticeable
You'll need to use a much larger bounding container (and move back the
camera a whole lot) to see anything. Something like
contained_by{box{-20000,20000}}.
(BTW your elliptic paraboloid seems pretty circular to me.)
Date: 23 Jul 2012 19:55:01
Message: <web.500de3eefb628f713eebe80d0@news.povray.org>
> >>>> plane:
> >>>> isosurface {
> >>>>     function {
> >>>>     pigment {
> >>>>       color Red
> >>> function {
> > to show up?
I think I figured out another way of doing what I want to do using spheres.  I
will try it out and report back.
Date: 23 Jul 2012 20:00:01
Message: <web.500de548fb628f713eebe80d0@news.povray.org>
coordinates):
> > >>>> plane:
> > >>>> isosurface {
> > >>>>     function {
> > >>>>     pigment {
> > >>>>       color Red
> > >>> function {
I'm
-3x^2/200000
> > > to show up?
Is there any way of creating e.g. a hemisphere using CSG?  Or for that matter,
is there any way of 'cutting off' a part of the sphere (e.g. below a certain y
value)?
Date: 23 Jul 2012 20:20:01
Message: <web.500dea29fb628f713eebe80d0@news.povray.org>
coordinates):
> > >>>> plane:
> > >>>> isosurface {
> > >>>>     function {
> > >>>>     pigment {
> > >>>>       color Red
> > >>> function {
I'm
-3x^2/200000
> > > to show up?
I'm essentially trying to get a 0.00003 unit chunk out of the top of the sphere.
 I found an example for the hemisphere and I will try to work with that (I kind
of get how to do it, but I can't seem to get the chunk I need experimenting with
the box in the intersection).
Date: 23 Jul 2012 20:55:01
Message: <web.500df1bafb628f713eebe80d0@news.povray.org>
coordinates):
> > > >>>> plane:
> > > >>>> isosurface {
> > > >>>>     function {
> > > >>>>     pigment {
> > > >>>>       color Red
> > > >>> function {
I'm
-3x^2/200000
> > > > to show up?
I have a problem.  When I cut a chunk out of the sphere, it still has a circular
base.  I would like a square base.  How would I achieve that?
Thank you very much in advance!  (and sorry for spamming the thread like this
:P)
- Chaanakya
