POV-Ray : Newsgroups : povray.general : torus, inward/outward tilted Server Time
15 Jan 2026 09:05:22 EST (-0500)
  torus, inward/outward tilted (Message 1 to 7 of 7)
Subject: torus, inward/outward tilted
Date: 17 Jul 2012 05:55:01
Message: <web.500534b792b607dd47437ba70@news.povray.org>
Hi all...
I am getting stuck on constructing a piece of an assembly.
This piece I want is a sector of a torus-ish element.
So let's describe this torus-ish thing...
Scale a normal torus in the y-direction:
  #declare myTorus= torus {24, 0.4 sturm on scale <1, 2, 1>}
Now I want to tilt the complete (scaled) torus inward (AND preserving the 2:1
ratio of the cross section of the tube)
I tried several things, like shearing with matrix  (which does indeed tilt the
torus: if applied on quarter of torus, and then connect 4 of these quarters
again
to get full torus again. You have a nice inward tilted torus).
However - no matter what i tried - it leads to a very flat torus - so no longer
preserving the 2:1 ratio of the cross section of the tube).
I would be happy for any advice on how to make a torus which has 2:1 ratio of
its tube preserved and can be tilted any degrees (0 to 90) inward/outward.
Best regards,
Peter
Subject: Re: torus, inward/outward tilted
Date: 17 Jul 2012 10:20:06
Message: <50057496$1@news.povray.org>
Am 17.07.2012 11:49, schrieb peter puzzelaar:
> again
You won't get far with the torus primitive, but here are a few possible
approaches:
* Use an isosurface; you'll need to figure out a function that will
yield a rotated ellipsis, and combine that with another function to
generate a surface of revolution.
* Approximate the shape using a sor or lathe object.
* Approximate the shape using a mesh.
Date: 17 Jul 2012 10:49:37
Message: <50057b81@news.povray.org>
>> ratio of
>> inward/outward.
> approaches:
* Use a poly of fourth order. Might raise to higher order as you deform
it. (polynomial syntax is to be preferred, IMHO)
Guess what ? there is even a basic torus in the wiki page:
> http://wiki.povray.org/content/Documentation:Tutorial_Section_3.2#Poly_Object
Now, If I could only understood the "inward tilted" thing applied to a
torus...
Date: 18 Jul 2012 03:10:00
Message: <web.5006611b61ba12ab47437ba70@news.povray.org>
> torus...
actually the inward/outward is superfluous (depends only if you look at the
torus from top or bottom).
here is a code snippet for a the tilted torus...
camera {location <0, 36, -48> look_at <0, 0, 0>}
#declare myTiltedInwardQuartTorus =
intersection {
  torus {24, 0.4 sturm on scale <1, 2, 1> matrix < 1,0,0,  1,1,1,   0,0,1,
0,0,0>}
  box {<-25, -1, -25> <0, 1, 0>}
// inward tilted torus
union {
  object {myTiltedInwardQuartTorus}
  object {myTiltedInwardQuartTorus rotate <0,  90, 0>}
  object {myTiltedInwardQuartTorus rotate <0, 180, 0>}
  object {myTiltedInwardQuartTorus rotate <0, 270, 0>}
  texture {pigment {color rgb<0.8, 0.8, 0.2>} finish {ambient 0.2 phong 1}}
Regards, Peter.
Date: 19 Jul 2012 13:45:01
Message: <web.5008456861ba12ab85de7b680@news.povray.org>
Render the following scene file.  It will show you why your 2:1 ratio isn't
preserved.
____________________________________________
  #version 3.6;
  camera { location <6, 0, -6> look_at 0 }
  #declare Section = disc
  { 0, z, 1
    pigment
    { object
      { union
        { cylinder { -x, x, 0.05 }
          cylinder { -y, y, 0.05 }
        White Red
    finish { ambient 1 diffuse 0 }
    rotate -45 * y
  object
  { Section
    translate <-3, 0, -3>
  object
  { Section
    scale <1, 2, 1>
    translate <-1.25, 0, -1.25>
  object
  { Section
    scale <1, 2, 1>
    matrix <1,0,0, 1,1,1, 0,0,1, 0,0,0>
    translate <1.6, 0, 1.6>
The very process of shearing causes the y-axis to lengthen, which breaks the 2:1
ratio.
In addition, the minor and major axes of the cross section's ellipse do not
remain aligned with the x and sheared y axes, distorting the ratio even further.
 This also causes the actual tilt angle to be slightly more than the shear
angle.  (E.g., with a shear of 1:1, or 45 degrees, the elliptical cross section
will be tilted slightly more than 45 degrees.)
Patching four sheared quadrants together doesn't work very well.  This is better
illustrated if you change your torus major radius from 24 to 6, and change the
camera location from <0, 36, -48> to <0, 9, -12>.  Instead, try playing with
this isosurface function:
  #include "functions.inc"
  #declare fn_Tilted_torus = function
    (x, y, z, P0_RMajor, P1_rMinor, P2_yScale, P3_tilt)
  { f_torus (x, y / P2_yScale, z, P0_RMajor + y * P3_tilt, P1_rMinor)
The above function does a shear, so it's subject to the same distortions to the
cross section.  It's surely possible to write a function that rotates instead of
shears, but the math is more complicated.  (It can be done with linear
transformations, but the matrix will not be the same for all points.)
Date: 21 Jul 2012 13:20:01
Message: <web.500ae40961ba12ab85de7b680@news.povray.org>
Go to http://lib.povray.org/searchcollection/index.php and type tiltedtorus into
the Find Keywords field.  See if that's what you're looking for.
Date: 28 Jul 2012 16:40:01
Message: <web.50144d6461ba12ab47437ba70@news.povray.org>
Thanks for the help and good advice...
This is what i conjured up (and it worked).
#declare MyTorus =
lathe {
  cubic_spline
  9,
  <T_rad*1.87-0.4*sqrt(2), -0.4*sqrt(2)>,
  <T_rad*1.87            , -0.4*sqrt(2)>,
  <T_rad*1.87+0.4*sqrt(2),  0          >,
  <T_rad*1.87+0.4*sqrt(2),  0.4*sqrt(2)>,
  <T_rad*1.87            ,  0.4*sqrt(2)>,
  <T_rad*1.87-0.4*sqrt(2),  0          >,
This will create a torus with major radius = T_Rad and the points of the lathe
are chosen in such a way that an oval with axes of ratio 2:1 is created.
Again thanks for all help...
Peter
