POV-Ray : Newsgroups : povray.general : wrapping text on a cylinder Server Time
30 Sep 2024 06:19:29 EDT (-0400)
  wrapping text on a cylinder (Message 1 to 4 of 4)
Subject: wrapping text on a cylinder
Date: 9 Jul 2012 10:10:01
Message: <web.4ffae627439edae99949baae0@news.povray.org>
I know this has been talked about numerous times and I have found the following
example...
camera { location <-1.5,4.5,-10> look_at 0 angle 35 }
light_source { <10, 40, -50>, 1 }
plane { y, -2 pigment { checker rgb 1, rgb .5 } }
cylinder
{ -y*2, y*2, 2
  pigment
  { object
    { text { ttf "timrom.ttf", "POV-Ray", 2.1, 0 scale <.1,2,1> }
      pigment { rgb <1,.9,.8> }
      pigment { rgb <.8,.4,.1> }
    warp { cylindrical }
    rotate y*160
  finish { specular 1 }
....which works nice except I want the text to be rotated 90 degrees.  Can this
be done or do I have to wrap an imagemap?
Subject: Re: wrapping text on a cylinder
Date: 9 Jul 2012 11:32:52
Message: <4ffaf9a4$1@news.povray.org>
Am 09.07.2012 16:09, schrieb joe:
> example...
> .....which works nice except I want the text to be rotated 90 degrees.  Can this
Simply rotate the text object you're using in the object pigment. (As
this may move the object out of the space that's visible when wrapping,
you may need to also apply an additional translation to fix it.)
Date: 9 Jul 2012 12:45:01
Message: <web.4ffb0a03f6fae4fb9949baae0@news.povray.org>
> > example...
Ok... thanks.  I was having a rough time finding the text after rotation.  I'll
keep playing.
Date: 12 Jul 2012 14:05:01
Message: <web.4fff10cbf6fae4fb85de7b680@news.povray.org>
> keep playing.
Try it this way:
  #include "shapes.inc"
  pigment
  { object
    { object
      { Center_Object (text { ttf "timrom.ttf", "POV-Ray", 2.1, 0 }, x+y+z)
        scale <.1,2,1>
        rotate <whatever>
    rotate y*160
