POV-Ray : Newsgroups : povray.general : Rotating an object so it is tangent to a spline. Server Time
10 Apr 2026 19:38:30 EDT (-0400)
  Rotating an object so it is tangent to a spline. (Message 1 to 5 of 5)
Subject: Rotating an object so it is tangent to a spline.
Date: 13 Oct 2011 10:55:00
Message: <web.4e96fac5c8ea8b465ae2687f0@news.povray.org>
Hello,
I am making a very basic test animation of a cannon shell being fired from a
gun.
After a bit of fiddling around, I have sorted out the path of the shell, and can
do pretty much anything I want with it.
However I have not figured out how to rotate it so that it is always tangent to
it's path.
I have written another "still" scene where the path is defined by a spline, but
the
closest I could get to a tangent was this:
#declare S=1;
#declare N=80;
#declare C=0;
#declare A=45;   //firing angle; in animated scene it is defined otherwise.
#declare AR=radians(A);
#declare V=100;  //muzzle velocity m/sec
#declare G=10;   //gravity m/sec, rounded up for simplicity
#declare Path1 = spline {
  linear_spline
  #while(S<=N)
    #declare XV = (sin(radians(90.0)-AR)*V*C);
    #declare YV = (sin(AR)*V*C-G*pow(C,2));
    S/N, <XV, YV, 0>
    #declare S=S+1;
    #declare C=C+0.1;
#declare Cnt=1;
#declare Max=20;
sphere_sweep {
  linear_spline Max
  #while(Cnt<=Max)
    #declare Point = Parabola1((Cnt-1)/(Max-1));
    Point, 0.5
    #declare Cnt=Cnt+1;
  pigment { Blue }
  translate x*-250
  scale 1/25
#declare P = 0.0;
cylinder {
  x*50, x*-50, 1
  pigment { Green }
  rotate x*(A-(2*P*A)      //this rotates the cylinder depending on its position
  translate Path1(P)
  translate x*-250
  scale 1/25
While this doesn't look too bad for 45 degrees, any higher or lower and the fact
that it is not tangent becomes apparent.
I have looked at math.inc, and I think that VAngle() and VRotation(), or some of
the Vector Analysis macros might be what I'm looking for, but how to get a
usable value from them is currently beyond my mathematical capabilities.
If I've made anything unnecessarily complex, which is often the case, :-(
could someone point me in the right direction?
Otherwise it looks like I'm in for some fairly complicated math.
D103
Subject: Re: Rotating an object so it is tangent to a spline.
Date: 13 Oct 2011 14:13:24
Message: <4e972a44@news.povray.org>
Le 13/10/2011 16:52, D103 nous fit lire :
> Hello,
> gun.
> it's path.
> the
what about creating the cylinder at the right position & orientation
first ? (instead of creating it and moving it)
tangent to spline Path1 at P is something like looking at P+epsilon.
#local CurPoint=Path1(P);
#local Soon=Path1(P+epsilon);
cylinder { CurPoint+50*vnormalize(Soon-CurPoint),
           CurPoint+50*vnormalize(CurPoint-Soon), 1
(assuming you want the center of cylinder on spline)
Date: 13 Oct 2011 21:20:00
Message: <web.4e978d143f98dc0e78641e0c0@news.povray.org>
That should be m/sec^2.
Date: 14 Oct 2011 00:10:01
Message: <web.4e97b4fd3f98dc0e5ae2687f0@news.povray.org>
Thanks very much, I have tried this and I think that with a little tweaking it
will meet all of my requirements for both test scenes, and the animation as
well.
I think I will retain the use of a spline as well, as it will allow me to have
several shells in the air at the same time, especially with a shell flight time
of ~24 seconds.
Many thanks,
D103
Date: 14 Oct 2011 00:15:01
Message: <web.4e97b6193f98dc0e5ae2687f0@news.povray.org>
Ah yes, so it should. Thankfully it's just an error in the notes, gravity is
calculated properly here:
Thanks anyway, :-)
D103
