POV-Ray : Newsgroups : povray.general : Starscape Server Time
11 Oct 2025 05:27:43 EDT (-0400)
  Starscape (Message 1 to 4 of 4)
Subject: Starscape
Date: 19 May 2011 02:50:01
Message: <web.4dd4bd8722f492289c4fb0ad0@news.povray.org>
I'm trying to create an interesting starfield using a sky_sphere.  I considered
using stars.inc, but (and I think I've encountered this problem before) the
pre-defined starfield pigments are not what I expected.  They don't even look
like stars.
This is the best I've been able to come up with so far:
sky_sphere {
          granite
          color_map {
               [0.00 rgb 0.0]
               [0.80 rgb 0.0]
               [0.85 rgb 1.0]
               scale 0.0001
I would like to add more color, and different size stars.  Perhaps some
clustering (might take a pigment_map).
Any help would be appreciated.
A.D.B.
Subject: Re: Starscape
Date: 19 May 2011 03:00:07
Message: <4dd4bff7$1@news.povray.org>
instead of granite, try something like this:
sky_sphere {
		crackle form <1,0,0>
		color_map {
			[0 rgb 5]
			[.1 rgbt 1]
		scale .01
imho it gives much better results.
cu!
ZK
Date: 19 May 2011 13:51:30
Message: <4dd558a2@news.povray.org>
> sky_sphere {
> pigment {
> color_map {
> [0 rgb 5]
> [.1 rgbt 1]
> scale .01
Not always, IME. The crackle-form-x pattern, while producing circular
points, often looks a little /too/ perfect.
I like good old granite myself, when used like so:
sky_sphere{
  pigment{
   granite
   scale 0.002/image_width
   poly_wave 28
   color_map{
    [0 rgb 0]
    [1 rgb 2]
The granite pattern tends to look more like star clusters. In my example
it's been scaled according to the size of the render window, which helps
a lot with these sorts of things (if it's not going to be animated, that
is).
It's all a matter of preference, though :)
Sam
Date: 19 May 2011 14:01:04
Message: <4dd55ae0@news.povray.org>
>> sky_sphere {
>> pigment {
But then again, with the crackle-form-x pattern combined with a low
metric value, you can do cool stuff like fake the appearance of glare at
each star:
sky_sphere{
  pigment{
   crackle form x
   metric 0.35
   poly_wave 1/32
   color_map{
    [0 rgb 8]
    [1 rgb 0]
Sam
