POV-Ray : Newsgroups : povray.general : non spherical sphere Server Time
19 Nov 2025 10:22:59 EST (-0500)
  non spherical sphere (Message 1 to 10 of 14)
Subject: non spherical sphere
Date: 30 Nov 2010 11:35:01
Message: <web.4cf52768a337373dcbe06a8f0@news.povray.org>
Hi everybody,
I have the following toy scene, but it does not produce the correct output: the
sphere is not a sphere but an egg! what am I doing wrong? anyone help me?
thanks!
here the scene:
#include "stones.inc"
#include "woods.inc"
#include "textures.inc"
background { color White}
 location <50,0,0>
  look_at <0,0,0>}
light_source {
   <20, 0, 0> color White
sphere {
<0,0,0> , 21
color rgbt <1,1,1,0.7> }}
Subject: Re: non spherical sphere
Date: 30 Nov 2010 13:18:22
Message: <4cf53fee$1@news.povray.org>
It could be due to the aspect ratio of your image. Read the docs 3.3.1
Camera, especially 3.3.1.1.5  Up and Right Vectors, 3.3.1.1.6  Aspect Ratio.
Try adding, "right  <1.33,0,0>" to your camera statement if your aspect
ratio is 4:3
Regards
Date: 30 Nov 2010 13:33:11
Message: <4cf54367@news.povray.org>
> Hi everybody,
> thanks!
> here the scene:
> camera {
>   location<50,0,0>
>    look_at<0,0,0>}
> light_source {
> sphere {
> <0,0,0>  , 21
> pigment {
> color rgbt<1,1,1,0.7>  }}
You render that at what resolution? With what aspect ratio?
If I render it with a classical 4:3 aspect ratio, then the sphere
actualy looks circular.
But, if I render at 100 by 50, I get an hirizontal elliptical image. If
you render a square image, or a prortrait, then you ger a vertical ellipse.
You can adjust the aspect ratio by adding the following to your camera:
up y
right x
This example is for a square image.
Some more examples follows:
up 2*y right x // for a 1:2 aspect ratio, tall and narrow.
up y right x*3/4 // 3:4 ratio, portrait.
up y right 3*x // for a 3:1 aspect ratio, prety whide image.
up y right x*4/3 // Normal 4:3 aspect ratio.
Another thing:
Whenever a sphere is NOT at the center of the scene, it will appears
elliptical. It's normal. Your scene is projected onto a plane. A sphere
define a cone and a cone-plane intersection at a non-perpendidular angle
is an ellipse.
Sample to illustrate that effect:
replace your sphere with this:
union{
sphere{0,3 pigment{rgb<0.1, 0.3, 1>}}
sphere{<0,9,0>,3}
sphere{<0,-9,0>,3}
sphere{<0,9,9>,3}
sphere{<0,-9,9>,3}
sphere{<0,9,-9>,3}
sphere{<0,-9,-9>,3}
sphere{<0,0,-9>,3}
sphere{<0,0,9>,3}
pigment{rgb<0.2,1,0.3>}
scale 2
Here, only the center (blue) sphere looks circular. The "distortion" is
normal and should be expected.
Date: 5 Dec 2010 19:15:01
Message: <web.4cfc2a39321c6322fc413f510@news.povray.org>
Another trick: If you're using the standard up y perspective camera, by adding:
to the camera statement, it will adapt to whatever aspect ratio you choose.
Date: 6 Dec 2010 13:22:11
Message: <4cfd29d2@news.povray.org>
  There are several reasons why you don't want to do that.
http://wiki.povray.org/content/Knowledgebase:Language_Questions_and_Tips#Topic_19
Date: 7 Dec 2010 08:40:00
Message: <web.4cfe38ac321c6322cbe06a8f0@news.povray.org>
Many thanks to your numerous replies!
But it did not work out. I render with Width=1280 Height=1024.
Btw: it looks quite spherical at the first glance, but if you measure you see
cleary that it is an egg!!
any other ideas?
thanks!
PS:I know that spheres which are not centered will become ellipses when
projected, but my sphere is perfectly centered.
Date: 7 Dec 2010 08:56:28
Message: <4cfe3d0c$1@news.povray.org>
Did you write that FAQ? You seem to promote it an awful lot.  It also seems
to assume you've already completed your scene, using "right
x*image_width/image_height" is very useful whilst developing a scene, as it
saves you having to adjust the camera block each time you want to render at
a different aspect (I assume nearly everyone renders to square pixels).
Date: 7 Dec 2010 09:02:00
Message: <4cfe3e58$1@news.povray.org>
> see
> any other ideas?
How are you measuring the dimensions of the sphere?
Date: 7 Dec 2010 09:20:45
Message: <4cfe42bd@news.povray.org>
If you are rendering the scene at the root of the thread, it cannot work
with +W1280 +H1024
1280 / 1024 is a 5:4 ratio.
Default (3.6) ratio is 4:3;
No Cigare!
You need (notice, 1 more line!):
 location <50,0,0>
  look_at <0,0,0>}
light_source {
sphere {
<0,0,0> , 21
A: Because it messes up the order in which people normally read text.<br/>
Q: Why is it such a bad thing?<br/>
A: Top-posting.<br/>
Q: What is the most annoying thing on usenet and in e-mail?
Date: 7 Dec 2010 19:45:30
Message: <4cfed52a$1@news.povray.org>
> seems to assume you've already completed your scene, using "right
> it saves you having to adjust the camera block each time you want to
> render at a different aspect (I assume nearly everyone renders to square
> pixels).
As long as only YOU render a scene, then, it's ok.
If you create your scene and you plan to have it rendered at various
aspect ratio, then it's also workable. You made it so that it's complete
even if parts are not visible, and it's modeled outside the visible area.
If you create a scene using a specific aspect ratio and publish it, then
it's not ok anymore.
