POV-Ray : Newsgroups : povray.general : A problem: about the image shape of the output. Server Time
12 Oct 2025 00:42:32 EDT (-0400)
  A problem: about the image shape of the output. (Message 1 to 10 of 11)
Subject: A problem: about the image shape of the output.
Date: 2 May 2010 10:45:01
Message: <web.4bdd8f6bf3a6f58aa6629d920@news.povray.org>
scene by POV-Ray. Because the field of view of the camera is 25 degrees and
POV-Ray uses the reverse ray tracing (rays are sent backwards from the camera to
the light source), then I thought the output scene should be a circle for this
case (camera vertically sees the object plane), ellipse otherwise. But the
this. Could someone explain the reason? Thanks!
Subject: Re: A problem: about the image shape of the output.
Date: 2 May 2010 11:05:45
Message: <4bdd94c9$1@news.povray.org>
Am 02.05.2010 16:43, schrieb POV-Zhstar:
The "angle" keyword is intended to be used for "zooming" in on an image
without having to fiddle with the other camera parameters - and that's
all it does. The value you specify here will be the /horizontal/ opening
angle of the camera frustrum, which will remain pyramidal in shape
(typically with a rectangular base) at least with the standard
perspective camera, i.e. the image will remain rectangular.
If you need a circular-shaped image, you'll need to post-process it in
your favorite image manipulation software.
Date: 2 May 2010 11:07:42
Message: <4bdd953e$1@news.povray.org>
POV-Zhstar wrote:
> I use the camera by setting the keyword ‘angle’ of 25 d
egrees, and generate a
 and
camera to
or this
the
> POV-Ray output an image of rectangle in shape. I can’t understa
nd why it is like
	I'm not sure why you would expect it to be circular or elliptic.
There is a drawing explaining the camera field of view and the
camera parameters on this page:
http://povray.org/documentation/view/3.6.1/246/
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Download 'us-ascii' (1 KB)
Date: 2 May 2010 23:45:01
Message: <web.4bde462d3f56d0c5582639f90@news.povray.org>
Thanks!
Oh, I thought it was in conical shape, which caused my puzzle.
Thanks. Could you give some suggestions about how to get such circular-shaped
image?
Date: 2 May 2010 23:50:01
Message: <web.4bde47c23f56d0c5582639f90@news.povray.org>
I want to see the rendered regions specificly of my camera with a prescribed
field of view in a conical shape.
Thanks! It helps a lot!
Date: 3 May 2010 02:24:59
Message: <4bde6c3b$1@news.povray.org>
Am 03.05.2010 05:42, schrieb POV-Zhstar:
> image?
Open image in your favorite Photoshop/Gimp/Whatever, mark a
circular-shaped area, invert the selection, cut away (make sure your
current layer allows for transparency; e.g. in Photoshop you may need to
duplicate the layer first, then discard the background layer).
Export the image with transparency (aka alpha channel), and you're there.
Date: 3 May 2010 04:40:01
Message: <web.4bde8aa93f56d0c55da9c9f20@news.povray.org>
Or put a hollowed out black cylinder in front of the camera
Date: 3 May 2010 09:20:01
Message: <web.4bdecd2e3f56d0c5a6629d920@news.povray.org>
Your method seems to can do. Could you elaborate it? Sorry I am a new user:)
Thanks!
Date: 3 May 2010 12:48:23
Message: <4bdefe57$1@news.povray.org>
> Thanks!
Try this:
union{
camera{location 0 look_at z}
cylinder{0, 10*z, 3 pigment{rgb 0} open}
rotate Some_Direction
translate Some_location
This create a camera identical to the default one, and link it with a
cylinder with an union. This enable you to rotate and move both toggether.
The open keyword removes the ends of the cylinder.
Lastly, you use rotate and translate to orient and locate the camera as
you want to.
If you want an elliptical opening, just unevenly scale the cylinder:
cylinder{0, 10*z pigment{rgb 0} open scale<4/3,1,1>}
You can also try with the fisheye camera. That camera will render a
circular image, if the hight and width are the same.
Date: 4 May 2010 23:10:00
Message: <web.4be0e1263f56d0c5582639f90@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> Try this:
> union{
> you want to.
> Alain
Thanks! This should what I want. I tried just with your method. But it shows the
following error:
Parse Error: No matching } in 'union', camera found instead
But I am sure there is no missing "}" in the scripts. What's wrong?
