POV-Ray : Newsgroups : povray.general : Speed of 3.7 beta vs. 3.6 Server Time
19 Nov 2025 17:39:31 EST (-0500)
  Speed of 3.7 beta vs. 3.6 (Message 1 to 9 of 9)
Subject: Speed of 3.7 beta vs. 3.6
Date: 26 Apr 2010 21:10:00
Message: <web.4bd63930df721a4a6015b4b80@news.povray.org>
Quite impressive. I just bought an Athlon II x4 (thank you AMD for maintaining
backwards compatibility!) and wanted to see how fast thing thing was. One
interesting test I did was to render a particular scene using 3.6 with 4
instances vs. 3.7. I was expecting the render times to be about the same. Yet,
3.7 took half the time that 4 instances of 3.6 did. What's allowing this speed
up?
Subject: Re: Speed of 3.7 beta vs. 3.6
Date: 26 Apr 2010 21:30:00
Message: <web.4bd63d7025ef90b66015b4b80@news.povray.org>
Also, it might be time to assemble a 16-core computer with
2 of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819105266&cm_re=magny-cours-_-19-105-266-_-Product
1 of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813151212&cm_re=socket_g34-_-13-151-212-_-Product
and gobs of RAM...
Date: 26 Apr 2010 21:50:01
Message: <web.4bd641a725ef90b6afa462b20@news.povray.org>
> up?
if it's a scene with radiosity, clipka contributed a lot of high-caliber
optimizations and cleanups for this feature.
Date: 26 Apr 2010 22:26:23
Message: <4bd64b4f$1@news.povray.org>
> up?
With 4 instances of 3.6, it takes 4 times as much memory. You may start
swaping. You need to parse 4 times, and only once with 3.7.
With 3.7, data collected by a core can be reused by the others, that's
impossible in 3.6 and multiple instances.
Date: 26 Apr 2010 23:35:02
Message: <web.4bd65a7f25ef90b66015b4b80@news.povray.org>
> > up?
No radiosity in the scene. Also, definitely no swapping since I have 4GB and the
scene only uses 200MB max. I thought it might be memory issues, but I then
compared the test scene on 3.6 running one instance vs. running 4 instances and
they all finished at the same time.
Date: 27 Apr 2010 00:35:01
Message: <web.4bd6690825ef90b6afa462b20@news.povray.org>
> > > up?
for a fair comparison, each instance of 3.6 should be rendering 1 corner of the
image divided by 4.  It's roughly what 3.7 does automatically (to as many cores
as you have).
Date: 27 Apr 2010 14:01:31
Message: <4bd7267b$1@news.povray.org>
> up?
Did you try with the non-SSE2 version of 3.7?
Date: 27 Apr 2010 21:40:01
Message: <web.4bd790d525ef90b65da9c9f20@news.povray.org>
> > up?
Custom compiles for 3.6 and 3.7 on Debian 5.0 x86-64 (gcc 4.3), so I would
assume they're both SSE2 enabled.
Date: 29 Apr 2010 03:25:00
Message: <web.4bd9336025ef90b65da9c9f20@news.povray.org>
I think I found the problem. Back when I was using the old processor, I compiled
3.6 with -march=k8. But when I switched processors I didn't think to recompile.
After recompiling with -march=barcelona, I got a 40% speed increase with 3.6!
The configure script for 3.7 uses -march=native so I think that might account
for why it seemed to be so much faster.
