POV-Ray : Newsgroups : povray.general : Does final_frame work as advertized? Server Time
18 Mar 2026 05:54:08 EDT (-0400)
  Does final_frame work as advertized? (Message 1 to 4 of 4)
Subject: Does final_frame work as advertized?
Date: 9 Jun 2009 00:45:05
Message: <web.4a2de78d9136926e78641e0c0@news.povray.org>
The documentation reads:
   final_frame
   This identifier reads the value set through the INI file
   option Final_Frame=n or the command-line switch +KFFn.
However, when I access the final_frame variable, it seems to return the subset
end frame value (+EF), not the final frame value.  I would like my frames to
render consistently, regardless of whether I'm doing the full run or just a
subset.
I'm using version 3.6.1 on Windows XP.
Subject: Re: Does final_frame work as advertized?
Date: 9 Jun 2009 10:30:01
Message: <web.4a2e719fb6b953e61a0422150@news.povray.org>
It works that way on my copy of 3.6, also. I haven't tried any of the newer
betas yet, so I don't know if this has been changed.
One workaround would be to add a line like "Declare=FinalFrame=##" to your
command line or INI file, where ## is the number you set in the KFF switch. You
can then access the variable FinalFrame globally, in place of using final_frame.
It's annoying to have to maintain the same number twice, but at least it'll do
what you expect. :)
>    final_frame
> subset.
Date: 17 Jun 2009 17:00:00
Message: <web.4a3958e1b6b953e6ccc08f5a0@news.povray.org>
>    final_frame
> subset.
This was addressed in
http://news.povray.org/povray.general/thread/%3Cweb.49d400119a8d90cf34d207310%40news.povray.org%3E/
you need to set +SF and +EF to render subset animations and leave +KFI as the
very first frame (Zero) and +KFF as the total number of frames
+SF and +EF are floating-point numbers specifying a percentage range.
ADB
Date: 18 Jun 2009 10:25:01
Message: <web.4a3a4e06b6b953e678641e0c0@news.povray.org>
That's exactly what I did.  The problem is that I need the value specified in
+KFF (as described in the documentation), but if I run a subset, final_frame
gives me the last frame of the subset, not the last frame of the entire run.
They can also be specified as frame numbers by omitting the decimal point.
