POV-Ray : Newsgroups : povray.general : Smooth spline curve Server Time
11 Jan 2025 07:09:03 EST (-0500)
  Smooth spline curve (Message 1 to 6 of 6)
Subject: Smooth spline curve
Date: 6 Mar 2009 05:10:01
Message: <web.49b0f611ad77d8bdc9ee64130@news.povray.org>
Hello again,
I wrote my macro for splines to be created from set of points given in array. It
works almost perfectly, but my idea is to have a curve following exactly my
points. I know splines work this way, but when I want a curve that is straight
initialy and turns to the right after some length I get a little left bend and
next expected right bend. Is it possible to create needed smooth (it means no
linear and quadratic splines can be used) curve?
Below is my implementation:
#macro createSpline(arr, stype, displacement, middlePoint)
  #local arrSize = dimension_size(arr,1);
  #local length = 0;
  #local i = 0;
  #while(i < arrSize - 1)
    #local length = length + vlength(arr[i+1] - arr[i]);
    #local i = i + 1;
  #local overallLength = length;
  #local length = 0;
  #local i = 0;
  spline {
    #switch (stype)
      #case (linear_spline_id) linear_spline #break
      #case (quadratic_spline_id) quadratic_spline #break
      #case (cubic_spline_id) cubic_spline #break
      #case (natural_spline_id) natural_spline #break
    0.00, arr[1] + displacement,
      #if(arr[i+1].y < 0)
        #declare middlePoint = length/overallLength;
      coef*length/overallLength, arr[i+1] + displacement,
      #local i = i + 1;
    1.00, arr[arrSize - 1] + displacement
I thought that using variable "coef" a little bit lower than 1 will solve the
problem but I was wrong? Any idea?
twister
Subject: Re: Smooth spline curve
Date: 6 Mar 2009 08:00:00
Message: <web.49b11dbbe24f50f3c9ee64130@news.povray.org>
If the issue needs to be better described, please let me know as it is very
important for me.
twister
Date: 6 Mar 2009 08:05:00
Message: <web.49b11efae24f50f38f505d3e0@news.povray.org>
Such effects are basically inevitable if you try to control a spline solely by a
set of points it is to "touch": You obviously give the spline full freedom over
the tangents at those points, and it *will* use this freedom, possibly in a way
you didn't intend. (Unless, of course, you already planned for this effect when
chosing the points.)
By taking a small left turn first, the spline reduces its overall "strain". So
what you can do to minimize this effect is move the last control point on the
straight line inward a bit, to get a softer transition into the curve.
There is nothing you can do in the macro code itself. This is a systematic
problem you will get with any spline type you can possibly imagine: Even if you
chose a spline type that gave you more control over the direction in a specific
point (e.g. Bezier splines), your macro still lacks the user input to decide
how to make any use of it.
Date: 6 Mar 2009 13:15:00
Message: <web.49b16737e24f50f3f50167bc0@news.povray.org>
I am working on a spline-generating macro too, so your question is an
interesting one. (I never actually tried to change the spline-type *during* the
spline--I guess I assumed that it would create the very problem you are trying
to work around. But it's an interesting idea.)
Just so that I understand your question correctly: When you switch between a
linear_spline type (for a non-curving straight line) and one of the non-linear
spline types (for an actual curve), are you trying to *minimize* the curve
transition there, or *maximize* it? Or are you trying to simply make the spline
curve *exactly* match the values and spline types you give it, at those
particular spline points? (In which case, clipka's explanation of the problem
is a good one.)
BTW, I only occasionally work with macros, so I'm still learning the finer
points of how to construct them. Before commenting further, I want to make sure
I understand your macro code itself.  Is dimension_size another macro of some
kind, that you are plugging in?  If so, does it return just a single value?
Ken W.
Date: 7 Mar 2009 13:10:00
Message: <web.49b2b733e24f50f3f50167bc0@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote:
> ...Is dimension_size another macro of some
Just discovered that dimension_size() is a POV-Ray keyword for finding the
'dimension size' (Duh!) of a pre-made array.  Oh well, I'm still learning...
KW
Date: 8 Mar 2009 17:35:00
Message: <web.49b439d7e24f50f3cf53e71a0@news.povray.org>
Of course I want to get a spline following exactly my points. I didn't even
think of combining two splines in one. I don't think it's possible.
For now because natural_spline doesn't give me solution I wonder how to connect
two separate straight lines with smooth curve as a part of of circle or
quadratic function in the way where you can not see where straight lines end
and curve begins. This is a mathematic problem that shouldn't be very complex.
So in the result I would like to create output points array - some kind of
spline substitution. Any ideas?
twister
