Hello again,
I wrote my macro for splines to be created from set of points given in array. It
works almost perfectly, but my idea is to have a curve following exactly my
points. I know splines work this way, but when I want a curve that is straight
initialy and turns to the right after some length I get a little left bend and
next expected right bend. Is it possible to create needed smooth (it means no
linear and quadratic splines can be used) curve?
Below is my implementation:
#macro createSpline(arr, stype, displacement, middlePoint)
#local arrSize = dimension_size(arr,1);
#local length = 0;
#local i = 0;
#while(i < arrSize - 1)
#local length = length + vlength(arr[i+1] - arr[i]);
#local i = i + 1;
#local overallLength = length;
#local length = 0;
#local i = 0;
spline {
#switch (stype)
#case (linear_spline_id) linear_spline #break
#case (quadratic_spline_id) quadratic_spline #break
#case (cubic_spline_id) cubic_spline #break
#case (natural_spline_id) natural_spline #break
0.00, arr[1] + displacement,
#if(arr[i+1].y < 0)
#declare middlePoint = length/overallLength;
coef*length/overallLength, arr[i+1] + displacement,
#local i = i + 1;
1.00, arr[arrSize - 1] + displacement
I thought that using variable "coef" a little bit lower than 1 will solve the
problem but I was wrong? Any idea?
twister
If the issue needs to be better described, please let me know as it is very
important for me.
twister
Such effects are basically inevitable if you try to control a spline solely by a
set of points it is to "touch": You obviously give the spline full freedom over
the tangents at those points, and it *will* use this freedom, possibly in a way
you didn't intend. (Unless, of course, you already planned for this effect when
chosing the points.)
By taking a small left turn first, the spline reduces its overall "strain". So
what you can do to minimize this effect is move the last control point on the
straight line inward a bit, to get a softer transition into the curve.
There is nothing you can do in the macro code itself. This is a systematic
problem you will get with any spline type you can possibly imagine: Even if you
chose a spline type that gave you more control over the direction in a specific
point (e.g. Bezier splines), your macro still lacks the user input to decide
how to make any use of it.
I am working on a spline-generating macro too, so your question is an
interesting one. (I never actually tried to change the spline-type *during* the
spline--I guess I assumed that it would create the very problem you are trying
to work around. But it's an interesting idea.)
Just so that I understand your question correctly: When you switch between a
linear_spline type (for a non-curving straight line) and one of the non-linear
spline types (for an actual curve), are you trying to *minimize* the curve
transition there, or *maximize* it? Or are you trying to simply make the spline
curve *exactly* match the values and spline types you give it, at those
particular spline points? (In which case, clipka's explanation of the problem
is a good one.)
BTW, I only occasionally work with macros, so I'm still learning the finer
points of how to construct them. Before commenting further, I want to make sure
I understand your macro code itself. Is dimension_size another macro of some
kind, that you are plugging in? If so, does it return just a single value?
Ken W.
"Kenneth" <kdw### [at] earthlink net> wrote:
> ...Is dimension_size another macro of some
Just discovered that dimension_size() is a POV-Ray keyword for finding the
'dimension size' (Duh!) of a pre-made array. Oh well, I'm still learning...
KW
Of course I want to get a spline following exactly my points. I didn't even
think of combining two splines in one. I don't think it's possible.
For now because natural_spline doesn't give me solution I wonder how to connect
two separate straight lines with smooth curve as a part of of circle or
quadratic function in the way where you can not see where straight lines end
and curve begins. This is a mathematic problem that shouldn't be very complex.
So in the result I would like to create output points array - some kind of
spline substitution. Any ideas?
twister
