I'm running Eagle3D that compiles using POV-Ray.
This is the error I'm getting:
Parse Error: No matching } in 'pigment', string identifier found instead
I'm calling this code I wrote:
#macro DIODE_SMD_CHIP_0805(color_sub)
union{
object{CAP_SMD_CHIP_GRND(2.0,1.25,1.3,rgb <0.8, 0.1, 0.2>)}
which references this default library that already works:
#macro CAP_SMD_CHIP_GRND(L,W,T,K)
union{
superellipsoid{<0.25-(L+W)/150, 0.25-(L+W)/150> pigment{color_sub}
scale<L/2,W/2,T/2> } //Grundkoerper braun
superellipsoid{<0.25-(L+W)/200, 0.25-(L+W)/200> scale<(K+L/100)/2,W/2,T/2>
translate <(L-K)/2,0,0> texture{col_silver}} //rechter Anschluss
translate <-(L-K)/2,0,0> texture{col_silver}} //linker Anschluss
rotate<90,0,0>
translate<0,T/2,0>
//2220
#macro CAP_SMD_CHIP_2220(color_sub)
object{CAP_SMD_CHIP_GRND(5.7,5.0,2.7,0.5)}
//1825
#macro CAP_SMD_CHIP_1825(color_sub)
object{CAP_SMD_CHIP_GRND(4.5,6.4,1.7,0.5)}
//1812
#macro CAP_SMD_CHIP_1812(color_sub)
object{CAP_SMD_CHIP_GRND(4.5,3.2,1.7,0.5)}
When I get the error, POV-Ray highlights this line:
Anyone know what I'm doing wrong?
ps - for reference, this is Eagle3D:
http://www.societyofrobots.com/electronics_Eagle3D_tutorial.shtml
It looks like you've declared color_sub to be a text string rather than
a pigment identifier.
E.g. you can't to this is you want to use color_sub as a pigment
identifier
#declare color_sub = "rgb <1,0,0>";
but you can do this instead
#declare color_sub = pigment {rgb <1,0,0>};
Mike Williams
Gentleman of Leisure
> identifier
Ok I ran this below code, but still got the same error:
union{
object{CAP_SMD_CHIP_GRND(2.0,1.25,1.3,0.5)}
and if I run this:
#macro DIODE_SMD_CHIP_0805(1)
union{
I get this error:
"Parse Error: Expected 'identifier or expression.', float function 'float
constant' found instead
ideas?
Subject: Re: Parse Error: No matching } in 'pigment', string identifier found instead
Date: 2 Feb 2009 08:07:22
Message: <4986a9ba@news.povray.org>
> union{
> #end
This macro uses the identifier "color_sub", but it hasn't been passed into
the macro as an argument, and it hasn't been #define'd or #local'd.
- Slime
[ http://www.slimeland.com/ ]
Subject: Re: Parse Error: No matching } in 'pigment', string identifier found instea=
Date: 2 Feb 2009 11:01:34
Message: <4986d28e@news.povray.org>
"societyofrobots" <nomail@nomail> wrote in message
news:web.498698f97b9bdab4e977d74a0@news.povray.org...
> union{
> #end
The change you've shown here doesn't materially change things because, when
this macro is called it simply creates a local variable named 'color_sub'
and uses that in preference to your previously declared value until the
macro ends. The important thing is the value that you pass into the
DIODE_SMD_CHIP_0805 macro when you call it (which you haven't yet shown in
your code snippets). The parse error from your first posting indicates that
the 'color_sub' macro parameter is being set in a way that is incompatible
with the way it is being used in the pigment statement within the
CAP_SMD_CHIP_GRND macro.
I think if you call the macro using:
DIODE_SMD_CHIP_0805(rgb <1,0,0>)
It should avoid this error.
You also need to take a look at the value you're passing as the 5th
parameter into CAP_SMD_CHIP_GRND. You pass in an RGB color value, which is
assigned to the parameter 'K'. Then, instead of being used in a pigment
statement this value is subsequently used to scale and translate objects,
which seems to me to be all wrong.
> and if I run this:
> union{
> #end
> I get this error:
The #macro directive is used to define a macro. The macro definition expects
a list of comma separated identifiers. In this case you've defined the macro
specifying a number (a float constant) instead of a valid identifier - hence
the error message.
If you wish to be passing one or more parameters into the macro then you
need to specify a comma separated list of valid identifiers. Then, when you
call the macro you can specify numbers or other values in each of those
parameter positions.
Chris B.
Date: 2 Feb 2009 11:05:47
Message: <4986d38b$1@news.povray.org>
"Chris B" <nomail [at] nomail com> wrote in message
news:4986d28e@news.povray.org...
Sorry. I meant 4th.
Counting up to 4 is clearly not one of my key strengths on a Monday morning.
Chris B.
Playing around with it, I managed to entirely avoid the macro call. Basically
using 100% Eagle3D code and nothing that I wrote.
Well, the code still had an error, meaning the parser bug is specifically in
this below code. It seems to not like pigment{color_sub}.
I suspect it has something to do with "neu Parameter K = Anschlussbreite", which
although I don't speak German, I assume it means a new parameter was added but
code not tested.
//Grundmakro fuer SMD-Keramik-Chip-Kondensator (neu Parameter K =
Anschlussbreite)
//basiert auf Makro von Walter Muecke
union{
rotate<90,0,0>
translate<0,T/2,0>
#macro CAP_SMD_CHIP_0805(color_sub)
Date: 18 Feb 2009 15:01:01
Message: <499c22ad$1@news.povray.org>
news:web.499bf5a7692c33e4832722510@news.povray.org...
> in
You're still not showing us the bit of code we'd need to see to help much.
If it's complaining about color_sub you need to say what value this local
variable is being set to.
In this case color_sub is set to a value when the CAP_SMD_CHIP_0805 macro is
called, so you need to find the place where this macro is called. If it's
the same error as before, then it's probably that a string is being passed
into the macro rather than a valid color value.
Chris B.
