POV-Ray : Newsgroups : povray.general : How to add a bump to an object? Server Time
12 Oct 2025 22:57:35 EDT (-0400)
  How to add a bump to an object? (Message 1 to 3 of 3)
Subject: How to add a bump to an object?
Date: 17 Nov 2008 17:20:00
Message: <web.4921ed67475bbc133b34ecfe0@news.povray.org>
I am stuck with the following problem: I have an egg-shaped object and I want to
pull on it locally, deforming it. I want the deformation to affect the entire
shape. The easiest way to visualize it is to think of an egg with a plastic
shell and liquid inside. Now bring a match close to one spot on the egg,
locally softnening the plastic and allowing water to bulge out the shape.
One approach would be to do a blob. However, blobs are too local and they only
work with spheres and cylinders not splined lathe objects like my egg shape.
Is there a way to programmatically add a bump to an object in a particular
direction?
Subject: Re: How to add a bump to an object?
Date: 18 Nov 2008 00:14:29
Message: <w85TYvBS0kIJFwau@econym.demon.co.uk>
>I want to
>direction?
I reckon that there are two basic approaches, neither of them easy.
You could model your egg as a smooth mesh and calculate the changes to
the vertices and normals as the shape changes.
You could model your egg as an isosurface and do isosurface blobbing
http://www.econym.demon.co.uk/isotut/combine.htm#blob
Hint: if you want a real egg shape, rather than just an ellipsoid, you
can use non-linear scaling on a sphere
http://www.econym.demon.co.uk/isotut/substitute.htm
Mike Williams
Gentleman of Leisure
Date: 18 Nov 2008 01:35:00
Message: <web.492261d42924023d3b34ecfe0@news.povray.org>
Thanks. The latter works great albeit slow.
