POV-Ray : Newsgroups : povray.general : changing includes during animation Server Time
12 Apr 2026 05:38:06 EDT (-0400)
  changing includes during animation (Message 1 to 6 of 6)
Subject: changing includes during animation
Date: 26 Mar 2008 10:35:01
Message: <web.47ea6c41461b9814be7bfb550@news.povray.org>
Hello everybody:
I'm working on an animation which is supposed to mix real video and povray
generated graphics. My question is:
I would like to change a call to an include statement, this is
on the first clock step -->#include "file1.png"
on the 2nd clock step -->#include "file2.png"
on the 3rd clock step -->#include "file3.png"
and so on.
The idea is that I dont know how to do it without writting hundreds of lines on
pov.
So the question is: is it possible to change the name of the files you call with
the include? Something like
#include "file"+clock+".png" ??????
Thank you very much folks.
Subject: Re: changing includes during animation
Date: 26 Mar 2008 10:45:46
Message: <47ea6faa$1@news.povray.org>
#include concat("file", str(clock, 0,0), ".png")
Read on the arguments for 'str' if you want decimal numbers or zero-padding.
Date: 26 Mar 2008 10:54:38
Message: <47ea71be@news.povray.org>
  No, not "clock" but "frame_number".
Date: 26 Mar 2008 11:15:43
Message: <uitku39hc86sjug6cjoib061c82fq3klpo@4ax.com>
On Wed, 26 Mar 2008 12:45:37 -0300, Nicolas Alvarez
Yes as Warp says, frame_number is better for this. It saves
calculating what the frame number (file number) should be. I use this
method to import numbered meshes into an animation.
Regards
Date: 26 Mar 2008 11:20:00
Message: <web.47ea76f7ce341c0bbe7bfb550@news.povray.org>
Thanks!!!!
As soon I finish the animation I will post a link.
Date: 27 Mar 2008 01:00:30
Message: <47eb37fe@news.povray.org>
kike wrote:
> Hello everybody:
#declare FileName=concat("file",str(frame_number,-3,0),".png");
Of course, you can't include .png files this way, but you can use them
in image_map statements.
The -3 part indicates that the file numbers are three digits, padded on
the left with zeros if need be.  If the number in the file name is not
padded, then replace the -3 with 0 .
John
