POV-Ray : Newsgroups : povray.general : Physics of an Explosion Server Time
20 Nov 2025 18:58:07 EST (-0500)
  Physics of an Explosion (Message 1 to 7 of 7)
Subject: Physics of an Explosion
Date: 13 Mar 2008 14:10:00
Message: <web.47d97bdddd275636704837900@news.povray.org>
Not sure if this is the proper place to put this, but...
I need help with the physics of a mid-air explosion.  I have a ship travelling
in an atmosphere, at about 4000 units per clock.  It is supposed to explode in
mid-air, but I am wondering how the resulting debris would travel.  Would it
travel both to the ground and to an eventual stop, or what.
Any knowledge would be most appreciated.
Thanks in advance,
  --Nimish
Subject: Re: Physics of an Explosion
Date: 13 Mar 2008 15:15:18
Message: <47d98b56@news.povray.org>
The solid fragments will fly off in all directions, with the total
momentum equal to the total momentum of the ship before the explosion.
Acceleration will be be comprised of an amount from gravity (constant
acceleration, straight down), plus a component of drag (directly
opposite current motion, directly proportional to velocity, directly
proportional to cross-sectional area, inversely proportional to mass).
Remember that velocities and accelerations are all vector values.
Choose the right coefficient of drag and you will have a convincing path
of motion for each particle.
The fireball is gaseous, and while it may have a large mass, it will
also have a very large wind resistance, and less gravity, so its
trajectory will depart from the solid fragments very quickly.
You will probably need to do some math to step through each frame
leading up to the frame that you're rendering.
John
Date: 13 Mar 2008 15:43:38
Message: <47d991fa@news.povray.org>
"Nimish Ajmani" <nomail@nomail> wrote in message
news:web.47d97bdddd275636704837900@news.povray.org...
> travelling
> explode in
> it
     If the explosion occurs in 'mid-air' as we know it on Earth, then the
debris will travel to the ground in solid form, but will buckle on impact
with Earth and cause a large dent in the Earth's surface and kill most.
       ~Steve~
> Thanks in advance,
>  --Nimish
Date: 13 Mar 2008 16:05:41
Message: <47d99725$1@news.povray.org>
>> travelling
>> explode in
>> it
> acceleration, straight down), plus a component of drag (directly opposite
> current motion, directly proportional to velocity, directly proportional
> to cross-sectional area, inversely proportional to mass). Remember that
> velocities and accelerations are all vector values. Choose the right
> coefficient of drag and you will have a convincing path of motion for each
> particle.
> The fireball is gaseous, and while it may have a large mass, it will also
> have a very large wind resistance, and less gravity, so its trajectory
> You will probably need to do some math to step through each frame leading
There is also blast shadow, objects behind other objects will pick
up less of the momentum from the blast, and be thrown in slightly
different directions because of deflection of the gaseous wave.
Date: 13 Mar 2008 20:05:00
Message: <web.47d9ce78b836d3fa704837900@news.povray.org>
Thanks for all the help, especially to John.
I think I got the effect programmed right, now I just have to wait for a final
result.
I'll post that result probably in the animations section when it is finished.
Date: 14 Mar 2008 06:00:00
Message: <web.47da5a85b836d3fa731f01d10@news.povray.org>
> result.
For a first approximation I'd add a velocity in a random direction to each
fragment's forward velocity at the point of the explosion, and then let gravity
control them from then on. As others mentioned, any fireball or smoke/fine
particle cloud will likely stay virtually stationary at the point of the
explosion until it dissipates. With some tweaking this would probably look good
enough for most purposes. A simple wind resistance factor (a decelerating force
proportional to existing speed squared) could also be calculated for each
fragment for added realism.
I hope it looks good, this is something I keep meaning to try!
Date: 14 Mar 2008 08:30:01
Message: <web.47da7cfeb836d3fa704837900@news.povray.org>
I posted a preliminary test over in the animations section.  If you all would
take a look and comment, I would be most grateful.
Thanks again for all your help, and Thanks in advance for more help.
 -Nimish
