POV-Ray : Newsgroups : povray.general : TerraPOV Server Time
26 Dec 2025 14:33:46 EST (-0500)
  TerraPOV (Message 1 to 10 of 12)
Subject: TerraPOV
Date: 13 Nov 2007 08:50:01
Message: <web.4739ab70b2f747afe8ba46670@news.povray.org>
> Oh, I like this one, moody, not so colorful.
> And you don't even need to worry how your sun looks ;)
> Now put some water and terrain below that sky!
As everyone may guess, the sky is not my only subject of study. I am also
working on water (not as difficult as the sky), and terrains (not quite easy to
automate).
These are different and 'orthogonal' works. I think I ended up with something
operatable for skies. I already have something for terrains and the main
principles and features are OK (as embryos). Water is not really a problem
(still water I mean ..).
My idea is to gather all in a single system (with many parameters ...), allowing
of course to add user defined objects in scenes with provided placement macros.
The triplet sky-terrain-water would then be a framework for scenes, with tools
and predefined stuff and so.
As I got inspired by Terragen, I have named this projet TerraPOV.
Thanks to those who encouraged me for my skies. I keep you informed.
    Friendly
        Bruno
Subject: Re: TerraPOV
Date: 13 Nov 2007 09:31:03
Message: <4739b527$1@news.povray.org>
   I hope you have more success than I with my "Project Tierra".... I have
it stalled, waiting for large amounts of free time to expend... :)
   BTW, if the rest of the elements come with the same quality as the skies,
it can be a great system!
Jaime
Date: 13 Nov 2007 09:51:00
Message: <4739b9d4$1@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> schreef in bericht
news:4739b527$1@news.povray.org...
Well... The Earth was not built in seven days...  :-)
> skies, it can be a great system!
I agree.
Date: 13 Nov 2007 10:50:00
Message: <web.4739c699a0e33012726bd13c0@news.povray.org>
I thought that it was done in 6 days :)
> I agree.
> Thomas
So do I, they are really very good skies.
Date: 13 Nov 2007 11:05:07
Message: <4739cb33$1@news.povray.org>
"Stephen" <mcavoys_AT_aolDOT.com> wrote in message
news:web.4739c699a0e33012726bd13c0@news.povray.org...
>> > have
Opinions differ ...  :o)
Chris B.
Date: 13 Nov 2007 11:20:01
Message: <web.4739ce86a0e33012726bd13c0@news.povray.org>
> >> > have
So they do. But since it was before my time I'll leave it to my elders to
correct me. :)
Date: 13 Nov 2007 11:55:01
Message: <web.4739d6ada0e33012e8ba46670@news.povray.org>
> Jaime
Thank you Jaime!!
Coming from you it is a great encouragement for me!
I am not finished yet with skies. For example, I must integrate single-cloud
macros (with or without DF3 generation step), with optional flat bottoms. I
already have some results. I also would like to define a typology for clouds
and the corresponding settings in order to define "macro-settings". I also have
to deal with the Sun appearance and halo (not very successful until now).
For cumuli, the problem is different than clouscapes and quite tricky. I think
I'll have to do with single clouds. But I am afraid that the turbulence feature
is not completely appropritate for the 'roundness' of cumuli. I tried with the
current system, but it is not suitable for cumuli and I could never get
acceptable results (mainly because the density is based on standard patterns).
Perhaps a particle system will be necessary, but I absolutely do not master
that. Advice/ideas welcome.
For terrain, the embryo is close to be operational for the basic features.
'*' mean implemented
'+' means partielly implemented
'-' means not yet implemented.
The engine can (will) provide several views:
    *) Elevation view (see attached file in next p.b.i post), inspired by
Terragen: Grayscale with iso-levels and decorations, including text.
    *) Scene view
    -) Sky dome generation view
    -) Local view of the scene from above with all objects.
It can define the terrain either as
    *) pigment-based function (user-defined), allowing overhangs (isosurface)
    *) Height field out of pigment function
    *) Height field out of image_map
    *) Image_map generation from pigment function
It can (will) define the sky as
    *) Media, like the skies I already posted. Allows cloudscape to cast shadows
    -) Sky-dome image map (probably a sphere)
    -) DF3 generation for single clouds.
It provides (or will) for
    +) Placement macros and utilities
    +) Predefined textures (thanks for contribs)
    *) Water
    -) Embeded SDL-code (TBC)
    +) Adding user-defined objects, one main interest of TerraPOV.
One big piece will also be to incorporate vegetation. It can use POV-Tree, and
stuff from PlantStudio or so. I would like to provide for pattern-based
placement macros (I already have something for that).
I want all be declarative, so that a MMI can be easily plugged. For example, for
the last version of my sky system, and for the sky that is currently rendering:
// ======================== DECLARATIONS ===============================
#declare QUICK = no;
// Sun
#declare SUN_ELEVATIONS = array [5] {10, 20, 5, 0.5, -0.5};
#declare SUN_HEADING = 20;
#declare SUN_POWER = 4;
// Atmosphere
#declare Ta = 110*km;
#declare Ha = -1*m;
#declare BASE_SKY_COLOR = rgb <0.45, 0.65, 1>;
#declare k = 1.2;
#declare DENSITY_BASE_POWER = 4;
#declare DENSITY_POWER_FACTOR = 1;
#declare ATMO_INTERVALS = 3;
#declare ATMO_SAMPLES = 5;
#declare ATMO_QUICK_INTERVALS = 1;
#declare ATMO_QUICK_SAMPLES = 5;
// Layers
#declare USE_LAYER_1 = no;
#declare USE_LAYER_2 = yes;
#declare USE_LAYER_3 = yes;
// Layer 1: high low-density clouds
#declare L1_H = 8000*m;
#declare L1_T = 300*m;
#declare L1_SCATTERING = 2.5;
#declare L1_SCATTERING_COLOR = White;
#declare L1_ABSORPTION = 0.5;
#declare L1_ABSORPTION_COLOR = White;
#declare L1_INTERVALS = 3;
#declare L1_SAMPLES = 5;
#declare L1_QUICK_INTERVALS = 1;
#declare L1_QUICK_SAMPLES = 5;
#declare L1_DENSITY = density
    wrinkles
    scale <100,1,100>
    scale L1_T
    color_map {[0.63 rgb 0.0][1 rgb 0.2]}
// Layer 2: normal height quite opaque cloud cover
#declare L2_H = 1000*m;
#declare L2_T = 200*m;
#declare L2_SCATTERING = 1;
#declare L2_SCATTERING_COLOR = White;
#declare L2_ABSORPTION = 0.25;
#declare L2_ABSORPTION_COLOR = 0.5+0.3*(1-Pink);
#declare L2_INTERVALS = 3;
#declare L2_SAMPLES = 3;
#declare L2_QUICK_INTERVALS = 1;
#declare L2_QUICK_SAMPLES = 3;
#declare L2_DENSITY = density
    wrinkles
    scale <15, 1, 15>
    warp {turbulence 0.3 octaves 10 lambda 2.05 omega 0.63}
    scale L2_T
    translate <300, 0, 5000>*m*z
    //color_map {[0.35 rgb 0.][0.36 rgb 0.6][0.8 rgb 0.9]}
    color_map {[0 rgb 1][0.6 rgb 0.7][0.75 rgb 0]}
// Layer 3: Ground-to-Layer2 haze for scattering beams
#declare L3_H = -1*m;
#declare L3_T = L2_H-L3_H - 1*m;
#declare L3_SCATTERING = 1;
#declare L3_SCATTERING_COLOR = White;
#declare L3_ABSORPTION = 0;
#declare L3_ABSORPTION_COLOR = White;
#declare L3_INTERVALS = 5;
#declare L3_SAMPLES = 10;
#declare L3_QUICK_INTERVALS = 1;
#declare L3_QUICK_SAMPLES = 5;
#declare L3_DENSITY = density
    function {0.1}
// Camera
#declare VIEW_CAM = 0;
#declare FISHEYE_CAM = 1;
#declare CAM = VIEW_CAM;
// Radiosity
#declare USE_RAD = yes;
#declare BUILD_RAD_DATA = no;
#declare RAD_BRIGHT = 1 ;
#declare RAD_FILE_NAME = "sky_22.rad";
// ====================== END OF DECLARATIONS ==========================
    Bruno
PS: By essence, skies require intensively the media feature. What about media
with 3.7?
Date: 13 Nov 2007 12:55:27
Message: <4739e50f$1@news.povray.org>
> with 3.7?
What's your problem, too slow? Send me a zip with the scene and all
needed files (even the *standard* include files) and settings you want.
As long as you don't use radiosity, I can use tiled rendering on it to
spread it on a dozen machines.
Date: 13 Nov 2007 13:05:00
Message: <4739e74c@news.povray.org>
   For my cumuli I used the object pattern, using as object a conglomerate
of spheres, distributed in a loop to resemble the shape of a cloud, then
used this with media and turbulence. But as you said, I never got realistic
results with turbulence... it should be my fault, because Gilles used it
very well on his DF3 clouds.
   I would add "isosurface based on a external heightfield". I have some WIP
on this subject, and it is very handy, as you can control the general shape
of the terrain with a heightfield "guide" and then add overhangs with an
extra function. I even developed a method to add the overhangs only on the
vertical parts, although it is very trick (requires calculating a "slope
map" of the heightfield first).
   For the skydome imagemap (which can be very useful indeed), take into
account the possible output as HDR. This means getting a good balance
between the intensity of the sky and the sun.
>     *) Water
   Plane, heightfield or isosurface? For close-ups to the shoreline, an hf
or isosurface is very convenient.
POV-Tree, and
   I think it's better to let the user supply their own plants/trees, you
only need to provide the placement macros.
   Looks like the right direction to me...
> with 3.7?
   IIRC, it will get ride of the container artifacts you are going to meet
with individual clouds... ;)
Jaime
Date: 13 Nov 2007 17:55:01
Message: <web.473a2a4aa0e330125c32394c0@news.povray.org>
> > with 3.7?
Thanks for the proposal! I'll think of it if needed!
Concerning 3.7, I made a few tests and the results were different in brightness
and color. Maybe I'll try again... I also noticed that it was faster on the
contrary.
    Bruno
