POV-Ray : Newsgroups : povray.general : Testing whether a shape intersects with another Server Time
27 Feb 2026 12:12:19 EST (-0500)
  Testing whether a shape intersects with another (Message 1 to 10 of 12)
Subject: Testing whether a shape intersects with another
Date: 4 Nov 2007 09:00:00
Message: <web.472dcf35dc25d7085a2aacfe0@news.povray.org>
Does anyone know of a simple way to test whether one shape is inside another?
I'm looking to fill a random volume - say a radius 10 sphere, with other objects
randomly spaced about - say radius 1 spheres.  That's easily accomplished with
RAND and a loop with a test #if
(random1*random1)+(random2*random2)+(random3*random3) < 1 ...  then sphere is
inside and can be drawn.
Then I can make a hemisphere out of this object by amending the test to add an
#if random1 > 0, for example.
But what I'm really looking for is a way to make a transparent complex CSG
object, and then fill it with spheres or other objects using a test, "#if
inside_CSG_object".
Does anyone know a way of accomplishing this?  I've looked and looked, and I
realise I might be missing something very obvious...
Subject: Re: Testing whether a shape intersects with another
Date: 4 Nov 2007 09:38:35
Message: <472dd96b@news.povray.org>
web.472dcf35dc25d7085a2aacfe0@news.povray.org...
> I
What is obvious is that you did not make a research about the word "inside"
in the pov documentaion :-)
Marc
Date: 4 Nov 2007 10:40:01
Message: <web.472de695cc25c29c5a2aacfe0@news.povray.org>
> > I
> Marc
Thank you for your answer Marc, although it would have been nicer not to have
been put down for my lack of knowledge.  The inside function is exactly what I
was looking for; thank you for pointing me in the right direction.
If anyone else is searching for this, the inside function would be called in
this way:
#if ( inside(Obj, Point) )
Date: 4 Nov 2007 10:47:44
Message: <472de9a0@news.povray.org>
M_a_r_c napsal(a):
>> I
> Marc
what is obvious is that you missed he doesn't test for a point. He tests
for an object being inside another.
One idea is to choose a point where the inner surface is seen completely
when unoccluded and then trace it together with the other object. If all
of your rays hit the object you know it's not being intersected by the
other object, hoping not to miss anything. Then use inside() to know
whether it is completely inside or completely outside. There is no
general algorithm to find out if two objects have non-null intersection.
Date: 4 Nov 2007 11:05:00
Message: <web.472decd3cc25c29c5a2aacfe0@news.povray.org>
Jan Dvorak <jan### [at] centrumcz> wrote:
> M_a_r_c napsal(a):
> >> I
> > Marc
Jan, thank you very much for this suggestion, I think I'm going to go with
something very similar to this.
Philip
Date: 4 Nov 2007 11:26:04
Message: <472df29c@news.povray.org>
"PhilipIsPDR" <nomail@nomail> wrote in message
news:web.472de695cc25c29c5a2aacfe0@news.povray.org...
>> > and
>> > I
>> "inside"
>> Marc
> have
> what I
> was looking for; thank you for pointing me in the right direction......
Hi Guys,
I think Marc's smiley emoticon was a good indication that he intended to
convey irony ie. "Ok obvious, but we all miss the obvious now and then"
rather than as a "put-down". Remember, emoticons were invented to help avoid
humour causing offense when you can't see the senders face or hear their
voice. The alternative of avoiding all humour, just to be on the safe side,
would make life a little dull (IMHO).
Chris B.
Date: 4 Nov 2007 12:12:03
Message: <472dfd63$1@news.povray.org>
> have
> what I
I was just pulling your leg ;-)
Marc
Date: 4 Nov 2007 12:14:17
Message: <472dfde9$1@news.povray.org>
472de9a0@news.povray.org...
I never pretended I gave a whole solution but rather a direction to explore.
inside() is usefull isn't it?
Marc
Date: 4 Nov 2007 12:16:38
Message: <472dfe76$1@news.povray.org>
472df29c@news.povray.org...
> Hi Guys,
> avoid humour causing offense when you can't see the senders face or hear
> their voice. The alternative of avoiding all humour, just to be on the
> safe side, would make life a little dull (IMHO).
> Regards,
> Chris B.
Thank you for having got and put it right Chris :-)
Marc
Date: 4 Nov 2007 12:31:52
Message: <472e0208@news.povray.org>
Jan Dvorak nous apporta ses lumieres en ce 2007/11/04 10:46:
> M_a_r_c napsal(a):
>> "PhilipIsPDR" <nomail@nomail> a écrit dans le message de news:
>>> looked, and I
>> "inside" in the pov documentaion :-)
>> Marc
The thing to do is to make two objects: one for the actual rendering, and
another one, smaler, for the tests. If you want to fill your shape with spheres,
like marbles in a jar, the smaller object have dimentions that are that of the
containing object minus the radius of the spheres.
War is an instrument entirely inefficient toward redressing wrong; and
multiplies, instead of indemnifying losses.
Thomas Jefferson
