POV-Ray : Newsgroups : povray.general : Unable to generate PNG Server Time
27 Feb 2026 13:53:55 EST (-0500)
  Unable to generate PNG (Message 1 to 5 of 5)
Subject: Unable to generate PNG
Date: 6 Oct 2007 01:50:00
Message: <web.4707213d77fbc5c3ccd3f470@news.povray.org>
When I try to generate a PNG file from command line for the following .pov
file, I don't get anything. I think it's a bug.
box { < -0.5, 0.0, 0.0 > < 0.0, 8.0, 9.0 > texture {pigment { color < 1.0,
1.0, 0.8 > }}}
box { < -0.5, 0.0, -0.5 > < 7.5, 9.0, 0.0 > texture {pigment { image_map {
jpeg "terracotta5.jpg"} }}}
light_source {< 3.5, 4.0, 7.0 > color < 1.0, 1.0, 1.0 >}
camera { perspective right x*-2/3 sky z angle 50 location < 3.0, -8.0, 6.0 >
look_at < 3.0, 7.0, 6.0 >}
If I comment out the terra-cotta line, everything works. My command line is
"C:\Program Files\POV-Ray for Windows v3.6\bin\pvengine.exe" +W360 +H540 +FN
+O"C:pg\povray\bathroom.png" "C:pg\povray\bathroom.pov"  /EXIT
Many thanks in advance.
Subject: Re: Unable to generate PNG
Date: 6 Oct 2007 03:11:23
Message: <4707351b$1@news.povray.org>
Le 06.10.2007 07:46, Pahidla nous fit lire :
How is it that there is a \ after some C:, but not for +O ?
Relative path might surprise you.
Moreover, pov file should be input with -/+I option, not directly.
Direct is for ini file.
The superior man understands what is right;
the inferior man understands what will sell.
-- Confucius
Date: 6 Oct 2007 10:05:01
Message: <web.470794eea623b6043ccd3f470@news.povray.org>
> > "C:Program FilesPOV-Ray for Windows v3.6binpvengine.exe" +W360 +H540 +FN
> > +O"C:pgpovraybathroom.png" "C:pgpovraybathroom.pov"  /EXIT
> How is it that there is a  after some C:, but not for +O ?
> -- Confucius
Hi, the lack of some 's is an artifact of posting messages where you need to
replace  with \ and I forgot in several places.
Anyway, this issue is not about the syntax. I think it may be a bug, but I'm
not sure. Would someone not mind actually trying to replacate what I'm
saying and see that the png is/is not generated depending on whether the
terra-cotta line is/is not commented out.
Thank you very much in advance!
Pahidla
Date: 6 Oct 2007 17:21:18
Message: <4707fc4e$1@news.povray.org>
>> -- Confucius
Oops, I didn't see that you created another thread here. I gave you a
tentative answer in povray.newusers...
Vincent
Date: 6 Oct 2007 18:07:31
Message: <47080723$1@news.povray.org>
Is this in Windows Vista?
Microsoft decided that .ini files would all be
considered windows system files by Vista
when they are installed or accessed from
the Program Files directory.  POV will
not operate correctly when installed to
that directory under Vista.
Additionally, you should use +I"source.pov"
without that it's looking for an .ini I think.
